This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Dec 12, 2012, 03:12 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
2 takeoff solutions
Anyways, the T4I produced some more videos.
T4I vs cheap Sanyo (1 min 12 sec)
Extremely relaxing whispering for dogs (7 min 40 sec)
Recalibrating Marcy 1 continues. There are lots & lots of parameters in machine vision which have to be reconfigured if she is to fly with the lights on. Manely, the algorithm for daylight requires tracking multiple points of light while the algorithm for darkness tracked a single oval.
Also, the 1st calibration had a lot of errors.
There are 2 routes from this step. Reuse the original code which controlled attitude during the takeoff or use a hard coded lookup table of battery voltages to instantly jump off the pad without attitude control.
The lookup table would conceivably never fail, would be fast & simple, but it's never been done before. The problem is it takes off before vision has enough time to fully initialize. It relies on enough stability & camera field of view for the vision to initialize after it's taken off.
The attitude control was sort of like the uncontrolled lookup table. It could only detect attitude on the ground, so it leveled & searched for the right throttle for the given battery voltage on the ground. Then it had to resort to a similar uncontrolled throttle ramp to get off the stand before it tilted. It was complicated, slow & the throttle ramp tended to either overshoot or undershoot.
It's heading towards an attitude controlled system on the ground with a lookup table for the takeoff. The minds that existed in 2011 used well learned knowledge in all the takeoff issues to arrive at the attitude controlled takeoff.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Old Dec 12, 2012, 07:19 PM
DismayingObservation is offline
Find More Posts by DismayingObservation
Southern California
Joined Feb 2006
Jack, your blogs are incredible. Great video!
DismayingObservation is offline Find More Posts by DismayingObservation
For Sale HELICAM SOLUTIONS MARK IV RC HELICOPTER CAMERA MOUNT cost $2,700 Go4it FPV Equipment (FS/W) 3 Jul 24, 2012 12:34 AM
Video 707 aborted takeoff camera angle 2 demondriver Electric Plane Talk 0 Nov 14, 2011 09:22 PM
For Sale NIB Simprop Solution 2.0 - 2.835M semi-scale dckemper Aircraft - Sailplanes (FS/W) 0 Feb 15, 2006 09:28 PM
Sliding left on takeoff?........SOLUTION!!.... SargeNZ Micro Helis 7 Mar 27, 2005 09:44 AM
