Old Dec 11, 2012, 09:36 PM
email4nickp is offline
Find More Posts by email4nickp
Learning one crash at a time :
Australia, QLD, Gold Coast
Joined Dec 2012
Help!
Scratch built octocopter buying list
I'm building an octocopter and I'd like to check that I'm getting the right equipment before I start spending . I'm planning to lift a 1 kg camera on top of everything else.
Hobbyking X930
TURNIGY Plush 30amp Speed Controller
Slow Fly Electric Prop 11x4.7SF (4 pc - Green)
Slow Fly Electric Prop 11x4.7R SF (4 pc - Green Right Hand Rotation)
A28XL Brushless Outrunner 890kv
How does this sound and what camera mount would you recommend? I'm trying to keep the entire project under 600 dollars.
email4nickp is offline Find More Posts by email4nickp
Old Dec 30, 2012, 12:58 PM
fsanfilippo is offline
Find More Posts by fsanfilippo
Joined Sep 2012
octo copter
Hi nick
I am doing the same thing. I am going to cary about 6lbs of weight. need to know what the best electronics is to get.
fsanfilippo is offline Find More Posts by fsanfilippo
Old Dec 30, 2012, 03:48 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
I hope the picture HK shows for this motor is wrong, as it only shows 2 wires. It also doesn't mention mounting hole spacing for the motor. The frame has 16/19/25mm which is the most common so it's likely it would mount fine.
For FC it comes down to price/features. Even a KK2 can do octo fine
WendoNZ is offline Find More Posts by WendoNZ
Old Jan 03, 2013, 11:40 AM
Gusti..Iceland is offline
Find More Posts by Gusti..Iceland
Iceland, Westfjords, Bolungarvik
Joined Jan 2013
the x930 frame
hi guys,
I recently built the x930 with the following setup :
Motors
Esc.
I used the KK2 board. I have 2 x 3300 3S Turnigy LiPo´s connected parallel.
The build has plenty of power and good lift, I havent tried it fully but it´s able to go between 3-5 kg in my opinion. Im having problems with the KK2, cant seem to find the correct P and I gains but hopefully that´l be sorted soon and then I can publish the max payload.
I also have a FatShark FPV system on it and a Contour 1080i camera.
You can see the first flight here:
X930 Octocopter - Fyrsta flugið - Muninn (4 min 35 sec)
Best, Gústaf.
Gusti..Iceland is offline Find More Posts by Gusti..Iceland
Discussion Shopping list for scratch builders konaboy Foamies (Scratchbuilt) 12 Aug 15, 2012 03:05 PM
Discussion F-15 foam first time scratch build, parts list, help wanna go faster Foamies (Scratchbuilt) 5 Jul 27, 2012 11:03 AM
Build Log Designing for scratch-built FPV wing... PiperCub49 Flying Wings 15 Mar 09, 2012 09:15 PM
Build Log 2nd Scratch built plane ever! nickwasp Foamies (Scratchbuilt) 0 Feb 27, 2012 03:14 AM
