Old Dec 20, 2012, 06:48 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Whisky I pin the lamination strips over the plans, on layer at a time. Once all the layers are in place, thin CA is drizzled over the assembly. I make sure that the pieces are thoroughly saturated. The structured is done over waxed paper, so it is fairly easy to lift from the plans, once it has dried.
I fill in the structure with the straight pieces, before I pull the piece from the board.
Take a look at post 25, from the link I posted above. It should provide you with a general idea of what I'm trying to explain.
The CA hardened balsa is surprisingly easy to sand.
Hope this helps.
TomCrump is offline Find More Posts by TomCrump
Old Dec 21, 2012, 11:14 AM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Started to work on the landing gear only to realize I was out of brasing flux. So I ordered some. This was yesterday.
ace4rc is offline Find More Posts by ace4rc
Old Dec 21, 2012, 11:17 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Got the wing ply pieces cut. The last rib outboard is where the ailerons terminate so I made them out of ply for added strenght . And cut the template for the ribs. There are 28 ribs top and bottom.
Old Dec 21, 2012, 11:35 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thought I'd mention for those that have not thought about cutting ribs. These are symetrical so I like to add a stand tab to aid in the building process.
Old Dec 21, 2012, 07:14 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Here is the ribs all routed, band sawed, and drill pressed. I modified the rear stringer from a 1/4 x 5/8 rectangle to a 1/4" dowel. I would have had to hand sand all 28 holes and be near perfect. A round holes is much easier.
Old Dec 21, 2012, 08:51 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Fine! If ya'll insist. Here's some more building. The wings have been started. The bottom wing left half.
Old Dec 21, 2012, 09:05 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I had a conversation with someone earlier today about plan protectors. Thought I'd share here. I use painters plastic, see photo. So far I have not found any of our glues and adhesives stick to it at all. And it's cheap $20 for a 9' x 400' roll. My table is two feet wide so I will get 200 coverings out of a roll. That's a good deal!
Old Dec 21, 2012, 09:59 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
We do, we do!
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Dec 21, 2012, 10:28 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Well then let there be more! The other side added. But thats it. I have to cut some spars, leadine and trailing edges.
Old Dec 22, 2012, 08:03 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I have to commend you on your abilities. I recently cut out some ribs for a GP Sportster rebuild. I did not enjoy the process. LOL
Old Dec 22, 2012, 09:32 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's Tom. Do you use a router or cut each rib independent on a band saw?
Old Dec 22, 2012, 10:17 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Router ? I'd hurt myself. LOL
I used my bandsaw. From now on, I'll use a kit cutter, or stick to kits.
Old Dec 22, 2012, 10:30 AM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
Here's a *very* slick way of cutting ribs using a router table (post #1):
http://www.rcgroups.com/forums/showthread.php?t=1413655
EJWash
Old Dec 22, 2012, 06:59 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Not a real productive day model wise. But I think the left half is ready for some glue. I will get on that in the morning.
Old Dec 22, 2012, 07:00 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
It's early. You still hasve time to glue up that wing tonight !
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
