Old Dec 18, 2012, 12:14 PM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I'm pitching 2 cents into the well,here...........If you intend to sheet the turtle deck with 1/32 A/C ply,please add another stringer between those two on each side.
Use hard balsa,maybe 1/8 x 1/4..After a couple of years of the dope shrinking,mine began the 'starved horse' look....a couple of extra stringers woulld take care of that lil' problem.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Dec 18, 2012, 12:49 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's for the tip Earl. I'll look into it.
ace4rc is offline Find More Posts by ace4rc
Old Dec 18, 2012, 03:09 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Well Earl I've decided to do something a little different. A lot of gear is going in up under that front section so I decided to make it removable. I am going to take lithoplate cut it to the size of the panels. Then I will laminate 1/64 ply to the back side, except for the overlap. This will give me removable panels. I think. We'll see.
Old Dec 18, 2012, 03:55 PM
epoxyearl's Avatar
Joined Oct 2011
Doesn't the plan tell you to get a GROSS of screws or something like that?
The side panels are easily done,but man.fitting up the center top one around the cabanes is a head scratcher ! Everything tapers and is on an ANGLE!!!
Well fastened panels are as strong as glued in place ones,and access won't be denied.....
Old Dec 18, 2012, 04:51 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I can't find a number on the plans. A quick count there will be a couple hundred or so. What really suck's is they are slotted flush screws. I like the access part but I don't like the head scratcher part.
Old Dec 18, 2012, 05:03 PM
epoxyearl's Avatar
Joined Oct 2011
Full scale planes usually use flat head phillips screws,to prevent the screwdriver from slipping out.
Andy was wrong to use slotted screws,IMHO,but that was his choice,whatever his reason.
Maybe the plane he copied used slotted screws....a wise man doesn't.!
Old Dec 18, 2012, 05:08 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
That makes me fell much better because I am going to use panhead phillip's. On the detail stuff I like to make it just a little more pronounced.
Old Dec 18, 2012, 06:25 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Added some, whatever there called, to the fin and rudder. When dry I will finish it up.
Old Dec 18, 2012, 06:28 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Forgot to post this one about two hours prior to the last post.
Have the fin/rudder lamination laminated. I will give it an hour of drying to retain some shape then remove it and add glue.
Old Dec 18, 2012, 07:51 PM
epoxyearl's Avatar
Joined Oct 2011
They're called lam....in....a....shuns...( I've called 'em other names on occasion.)
Old Dec 18, 2012, 07:58 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Ah a wise guy. I was refereing to the internal pieces.
Old Dec 18, 2012, 08:00 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have done several laminations of this sort, but usually with balsa. When I read lightply I thought oh boy. But it went rather well.
Old Dec 18, 2012, 10:33 PM
epoxyearl's Avatar
Joined Oct 2011
After wiping the egg off my face,I thought you'd know I were joshing !!lol.
Ribs.
Old Dec 19, 2012, 07:45 AM
epoxyearl's Avatar
Joined Oct 2011
Skinny legs
Here's a photo of the Cessna style landing gear,although I prefer the Original Pitts style...I hate change.
I have 18 pics of the S1s,yours if you want them....PM your mailing address,and we'll get them on their way.
Old Dec 19, 2012, 10:16 AM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Those are very nice laminations. You've charmed those curves like a dancing cobra. Would appreciate if you'd share your technique on how you got those results.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 11:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 03:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Apr 01, 2008 12:15 AM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 03:08 PM
