Old Feb 08, 2013, 09:10 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
And I forgot to mention, that 1/2" I had to add to the ailerons made a big difference in the amount of servo movement. As it was, I was at the outer hole with 120% usage in the radio just to get a max deflection of 1/2". And after the rebuild the usage dropped to 95% with linkage adjustment. I like to be between 90-100% on servo travel. I can only use the outer hole on the control horns
because of how I set it up. I used standard servo horns and only one hole cleard well. I did not want to use the heavy duty because of size.
ace4rc is offline Find More Posts by ace4rc
Old Feb 09, 2013, 03:14 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Well the car shopping is a bust. I'm not paying those prices for a used vehicle. So we're going to wait a few moth's and buy the wife a new vehicle and give the son hers.
So come monday I will order the covering, tape, and paints. Over the next week or until the covering comes in I can really get this thing perfect. Starting with repalcing the two lower fuse aluminum panels. Not as close a fit as I would really like. When they are right I can apply some cockpit coming to the aluminum that will give a buffer around the cabanes. And I will, hopefully, get the fuse interior built and ready. Here's a shot of the cowl in place with the magnetic block's (depicted by black arrow) epoxied in place and curing. These few thing's are all that is left, so it will be ready for the Polylite.
Old Feb 10, 2013, 04:08 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Last cowl block's are installed, 1st pic. Second pic shows the three contact points per half. Black arrows rearward blocks and the red arrow is the forward block, it will also have a rotation pin just for good measure.
Old Feb 10, 2013, 04:42 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I'm gonna start magnetizing soon also.....doors, hatches etc.
Is that the final resting place for your fuel tank ? I just installed the Monocoupe tank in that orientation..
Mine's a little higher for a glow engine, but it is transverse.
Pitts is lookin' good.
epoxyearl is offline Find More Posts by epoxyearl
Old Feb 10, 2013, 05:30 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have been useing magnets for a couple years for everything and love it. Yes sir! That is the final resting place for the tank. Gas does not matter being there is a pump to pull the fuel. If I install a smoke system the tank will fit above the fuel tank.
Old Feb 11, 2013, 03:32 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The cowl mount turned out really well. Now is where I do what I call a final assembly prior to covering. This is when all the fine finishing comes in for me. When this assembly is complete everything will be fine tuned and ready to go. So! Without further adue.
I wrapped the bottom wing with painters plastic and installed it to the fuse, then added the belly pan to the wing. Mixed up a 50/50 epoxy and micro balloons and with a syringe I press the mixture in the joining seam's. This will give me a very tight joint. Tomorrow I can continue with the wing's.
I assume the struts have a rounded L/T edge being built from tube. If anyone knows different please chime in. I will be shapeing them tomorrow.
There won't be much of pics until I get to the covering. Not much to show that hasn't already been posted, just a redo.
Old Feb 12, 2013, 12:12 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The fuse is complete, other than the cockpit which will come later. And the lower wing is complete except for the control rod clevis to the upper wing. The bottom wing has been mounted to the fuse. I am adding a pic of the wing to fuse joint. I don't know if it will be visible as to how well the joint fits. But it is like a glove.
Old Feb 12, 2013, 12:27 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
that wing saddle turned out sweet!
whiskykid is offline Find More Posts by whiskykid
Old Feb 12, 2013, 12:46 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thanks whiskykid. Did you get the rest of the covering for yours?
Currently waiting on filler to dry on the top wing.
Old Feb 12, 2013, 01:01 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Curious as to what filler you've had the best results with. Long time ago I used resin (polyester) and micro-balloons. A bit too hard. Recently I've used the Hobbico filler and spackle. Looking to see what else may be out there.
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Feb 12, 2013, 01:25 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I use two different types. The container on top is a lightweight spackle and is used anywhere a soft fill is needed. The container on the bottom is a type of wood putty and is used for areas requiring a harder fill. The wood putty get's hard enough it can be drilled and tapped.
Old Feb 12, 2013, 01:37 PM
EJWash1 is offline
AMA 910957
EJWash1's Avatar
Joined Mar 2008
How is the wood putty's sandibility with balsa?
EJWash
team sleprock
whiskykid's Avatar
Joined Dec 2009
no covering yet! but was thinking bout heading ta town!
my bwife was a BAD lil girl rthis wk end, she went bought me a chinise extra 330 for my crg 20cc! ta fly while my ol extra in for overhual!
Old Feb 12, 2013, 01:44 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
EJ it's not. It gets very hard and the balsa would be all gone before the putty, think of it as a good hardwood.
Old Feb 12, 2013, 01:49 PM
epoxyearl's Avatar
Joined Oct 2011
Concerning filler
Guys,- I've been using the light weight spackle for years ,now...When it has been sanded to final shape, soak it with thin C/A. it will become plenty hard to stand up to hangar rash.
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
