Old Feb 05, 2013, 08:48 PM
ace4rc is online now
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
LOL Know what ya mean. The panels turned out nice enough to make up for the ailerons.
ace4rc is online now Find More Posts by ace4rc
Old Feb 06, 2013, 03:48 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The ailerons are rebuilt. Waiting for epoxy to cure on the control horn ply plate. When it's dry I will add the horns and be done with the rebuild.
Old Feb 06, 2013, 05:45 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Let's see: So, 2 mis-built ailerons = 1 "oh ". 2 rebuilt ailerons = 1 "atta-boy". So see, you're even!
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Feb 06, 2013, 06:25 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
ROTFLMAO
Cool thing is, in the process of redoing I got a better mechanical fit of the C/F control horn. The thing that the rod between the ailerons connect to, whatever it is called
Old Feb 06, 2013, 07:50 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
It's good that you trust us enough to tell us about your mistakes, and how you fixed them..
If I ever make a mistake, I'll give it a try...........lol.
Seriously, I'm loving the build..I only ever built the S-2 Pitts, but I'm right there with you.
epoxyearl is offline Find More Posts by epoxyearl
Old Feb 07, 2013, 10:51 AM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Earl, mistakes are a fact of life. And if by sharing I help someone else in their endeavour then it's all good.
Ok! The bottom ailerons are done, except for a final sanding.
QUESTION! Does anyone know what the control throws are. I have set it up at the RC Guys Pitts throw of 1/2" and it seems about right for the wing area along with four ailerons.
On to the top wing! Cross your fingers. LOL
Old Feb 07, 2013, 12:25 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Top ailerons have been cut out and L/T edge added. When dry I can add the hinges and control horn.
Old Feb 07, 2013, 04:20 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The top wing is done. And the magnets for the cowl came while finishing up the wing. So, onto the cowl mount.
Old Feb 07, 2013, 04:24 PM
epoxyearl's Avatar
Joined Oct 2011
Aileron throws of about 1/2" is a good place to start...If I remember correctly..
When I flew mine, NOTHING rolled fast enough ! I've slowed a little, myself.
Old Feb 07, 2013, 05:30 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's. I'll set three rates 3/8, 1/2, and 5/8. Hopefully that will give me from mild to wild. Of course low rates for the maiden.
Old Feb 07, 2013, 05:39 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The cowl block's are made and ready for the magnets. Then installing onto cowl.
I'll get to that tomorrow. I'm calling it a day. Maybe?
Old Feb 08, 2013, 08:29 AM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The magnet's have been epoxied into their block's. I will give them a full 24 hours before finishing up the mount.
Old Feb 08, 2013, 07:36 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have been going over this thing double checking and verifying what has been done and what is left to do. And if the cowl works out tomorrow it's ready for a final sanding and covering. And here I sit needing some fabric. It will have to wait for two weeks before I can order some. Going tomorrow to buy the youngest son a vehicle so I'll be a bit down on funds. But the bright side is it will only be two weeks.
Old Feb 08, 2013, 08:05 PM
epoxyearl's Avatar
Joined Oct 2011
A little time off will rejuvenate you. You've been hard at it for a while.I'd like to recommend looking for a spray can of zinc chromate primer for the aluminum sheets.
I didn't use the correct primer, and years later the paint cracked and peeled back in several places...When getting ready for the repaint, I found corroded places...It probably wouldn't have happened if I had used the "good stuff".
On the other ones, I used 1/32 " plywood....I can deal with wood.
Old Feb 08, 2013, 08:28 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's for the recommendation's Earl. I am useing stits paint so I use the stits primer. The oldest I have with it is three years and still looks as good as day one.
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
