Old Feb 01, 2013, 04:32 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Ya'll got it. It would take those little Tamiya paint bottles to the cleaners. And it still works.
ace4rc is offline Find More Posts by ace4rc
Old Feb 04, 2013, 04:45 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I hate waiting but must not hate it too much or I would order sooner. But then one would have to know ahead of time what needs ordered. Anyhow. The flexible exhaust pipe came so here it is. These are very bendable and super light. Good stuff!
And the 0 x 3/8 screws came so tomorrow I can get the aluminum panels fastened to the frame.
Old Feb 04, 2013, 05:24 PM
greyflight390 is offline
Find More Posts by greyflight390
greyflight390's Avatar
United States, CA, Modesto
Joined Feb 2009
Those look sharp.
For me I find that even the parts that are covered up need to look good, although not necessarily as good as the skin of the plane.
I just remade some completely hidden (with wing on) linkage parts on the rebuild I am doing because although there were perfectly functional, I could not stand their looks. They grated on me.
Ken
greyflight390 is offline Find More Posts by greyflight390
Old Feb 04, 2013, 06:46 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Those look a far cry better than the other method I did first. And much lighter. The pic is the first try.
Old Feb 05, 2013, 09:48 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The bottom ailerons are done, almost. Waiting on epoxy so I can finish sand and add control horn. So while waiting I started on the fuse panels and thought I would show a little.
Old Feb 05, 2013, 09:49 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
How I do it. I cut a strip of 1/16 ply, then measure and mark up for the screw holes and drill them out. In this case the screws are 1" apart with the first one on the strip at 1/4 from the end. Thats how they measure out from the plans. Then I tape the strip in place, triple check. Then drill the holes.
I started on the Pitts with #0-3/8 but the head size just looked to small to me. So I went with a #2 screw, it is a little larger than scale but looks better to me.
Old Feb 05, 2013, 03:01 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
And the right side. Now to remove all of them and drill the screw hole one size larger in the aluminum.
Old Feb 05, 2013, 03:03 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The panels were drilled for the screws. Now the bottomwing is done and ready for a good final sanding.
Old Feb 05, 2013, 04:36 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
all I can say is "WOW"!
whiskykid is offline Find More Posts by whiskykid
Old Feb 05, 2013, 06:01 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Well, I'll be a soamfsob!
Got the top wing on the board and commenced to measureing off of the plans. Made all the mark's and thought hmmmmm this looks different than the bottom. So I went and re-measured the bottom. I am a retard. Apparently when I did the bottom I made the first cut and continued to build from it instead of makeing the other cuts as marked. I guess after cutting the aileron off I must have turned everything over and commenced to build from that cut. I ended up with an aileron 1/2" smaller than it is supposed to be.
The first pic is where the pivot, hinge point, is suppose to be. The second pic displays the three marks (of which I did not use) the top mark is the wing T/E, bottom mark is the aileron L/E, and the middle mark is the pivot point or suppose to be.
So I get to build them again!
Old Feb 05, 2013, 06:04 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The ailerons are gone and the T/E of the wing has been rebuilt. Tomorrow when I get home from flying I will rebuild the ailerons and get them back on.
Old Feb 05, 2013, 06:34 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Well, best discovered now. Me, I'd have *maybe* found it just after covering the wing.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Feb 05, 2013, 06:42 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I hate making the mistake to begin with. Was just stoopid.
Old Feb 05, 2013, 06:50 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
and would probly make a pretty noticable flight difference!
Old Feb 05, 2013, 08:15 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
There's a saying in aviation: "Those that have, and those that are about to".
I'm with you. I beat myself-up when I make a mistake and should have measured a second, third, or even fourth time. Then I do something I'm proud of and it balances out.
EJWash
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
