Old Jan 07, 2013, 10:28 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Ace, that lady is looking good ! I had almost forgotten just how light she is on her feet.
You should take some pride in your build-that is well done,friend.
A couple of bare naked lady pics would be welcomed in the "show your naked wood" thread when you assemble it later,before covering.
I like structure !
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: "Everything OLD is New...
Old Jan 08, 2013, 06:12 AM
ace4rc is online now
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's Earl. I'll try and remember to do that. We have an event here called "Planes,Trains, and Automobiles". My club is part host to and I like to take a fully framed up with everything installed, ready to fly minus the covering, airframe to. I love to see peoples reactions to what actually goes into one of these planes.
ace4rc is online now Find More Posts by ace4rc
Old Jan 08, 2013, 10:13 AM
epoxyearl's Avatar
Joined Oct 2011
The AIR FORCE MUSEUM in Dover,Delaware is finishing up a CG-4a Glider,with one side covered and painted,the other fully exposed....What a great idea ! "you couldn't get me in that thing" is the phrase mostly overheard.,followed by 'what craftsmanship !'
Old Jan 08, 2013, 03:24 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Here's a shot of what I'm doing. The belly pan has been mounted, red arrows a dowel, yellow is a 4-40 into wing. The black arrows show how I use tape to get the contour for the balsa sheet.
Old Jan 08, 2013, 06:10 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Ok, I have one side on the pan on. Just a little tid bit on what helps hold balsa from springing back from a curved point. The black arrows denote where a 1/4" wide strip of 1/64 crosses the pan from side to side, the ply gets tack glued to the pan as each side goes on. The red arrows are where on the inside of the pan a small nylon cord will attach to the inside wall and the yellow arrows are where that cord will attach at the other end inside the pan. These little attachment cords hold the wall from slowly returning to original shape because the inside is hollow on account of the gear wire and gear blocks.
Old Jan 08, 2013, 07:59 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Woo Hoo! The belly pan is done. Tomorrow I will sand the fuse so I can install the lumber for the fuse panel's to attach to and start making the panels.
Old Jan 09, 2013, 12:15 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The fuse has been sanded, the stabilizer and fin have been sanded as well and installed. While that is drying I can get the rudder and elevator sanded.
Old Jan 10, 2013, 08:32 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have got a little bit done since the last post. The tailfeathers are finished, The balsa around the cockpit is installed. And the paper templates for the 1/64 ply has been cut and readyt for the aluminum. I have to finish sanding the top wing and mount it before I can make the fuse panels. That will ensure the best fit around the cabanes.
Old Jan 11, 2013, 10:22 AM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Been workin on the wing bolt area. The current set up requires a 2-1/4" bolt. I installed a new ply bolt plate as seen in red. This willreduce the bolt length to 1". And also gives me a good point for an alignment dowel.
Old Jan 11, 2013, 11:31 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
are you bolting from the top or the bottom? just curious.
don't forget to pin that bolt plate!
whiskykid is offline Find More Posts by whiskykid
Old Jan 11, 2013, 12:42 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Whisky the wing is pinned from the bottom as seen in the first pic. Then the belly pan goes on and covers the gear wire and wing bolts as seen in the second pic. And the new plate is pinned with two 1/16 dowels on each side.
Old Jan 11, 2013, 03:57 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
thanks ACE, not shure how I missed that earlier, I do remember you saying something about changing the wing mounting!
that turned out super clean! keep it up!
Old Jan 11, 2013, 07:54 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Thank's WK. And it's super easy to assemble as well.
Old Jan 12, 2013, 12:24 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have got the bottom center of the top wing sheeted along with the cabane mount's. When all that dries will do the other side.
Old Jan 12, 2013, 07:31 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Red arrow is center support for incedence. Yellow is for strut support to stop any twist. Green is for holding the wing horizontally level. The blue is for an even distance LE to LE. And the black is the same as the blue but for tip to tip.
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
