Old Jan 04, 2013, 03:16 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Well the bottom wing is sanded, sorta. Now to add the leading edge sheeting and sand some more. I might have the wings finished by monday. LOL
ace4rc is offline Find More Posts by ace4rc
Old Jan 05, 2013, 10:59 AM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Waiting for the glue to dry so I can iron the last piece of sheeting onto the bottom wing. Then will sand to shape and mount to the fuse.
Old Jan 05, 2013, 11:45 AM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
I used the AP glue iron-on method on 1/16" leading edge sheeting on a model. Slick!
How thick is the sheeting on your Pitts?
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Jan 05, 2013, 01:27 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
This sheeting is 3/32.I have used this method up to 3/16. I also use water, really helps.
Old Jan 05, 2013, 01:59 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
You mean you give it a spritz of water to soften the outside of the wood for easier bending?
EJWash
Old Jan 05, 2013, 06:11 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
That would be correct, spray and/or soak.
The wing is mounted. The water under the iron steams and really helps curve the wood by the expansion created. The steam also helps the heat penetrate easier/ quicker.
Old Jan 05, 2013, 06:40 PM
AMA 910957
EJWash1's Avatar
Joined Mar 2008
And here it was that I thought only the guys in the snowy regions built this fast.
Very nice!
EJWash
Old Jan 05, 2013, 07:03 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
And it stands on it's own two feet, so to speak.
Old Jan 05, 2013, 07:30 PM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
looking good ACE!
whiskykid is offline Find More Posts by whiskykid
Old Jan 05, 2013, 08:22 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
EJ, it don't feel like it's fast to me.
Thank's WhiskyKid.
Old Jan 05, 2013, 09:07 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
I have double checked everything and indepently everything is per plans. But the gear pitch too far forward when mounted, they should be inline with the bulkhead. So I am going to have to unbraze them, readjust, and braze'em back together.
Old Jan 06, 2013, 05:50 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
And the reason the gear pitch too far forward is because I built them square and true over the plan. I did not account for the angle they would be set on. So I have rebuilt them. Much better now. Near perfect I would say. I also added the center wire for the shock while I was at it. So they are done and mounted.
Old Jan 07, 2013, 01:23 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
The gear are done. In the pic you can see where the rear of the gear will slide into a slot and the front is hard mounted. Doing the gear this way accomplishes two thing's. One, they are removeable and two, if there is any give it will not break the wing. But simply slide rearward. I also posted a pic of the rudder and elevator servo mount.
One must take into account that I use 55% silver brazing wire and when setting the gear up it get's tied together with brass wire. I think it would have to be a real, real, real bad landing to have any effect on the gear.
Old Jan 07, 2013, 06:42 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Not much to show, but I have framed up the belly pan. Not quite done yet. The red arrow is the front former, yellow middle, and blue is the rear. The black arrow is where a 4-40 will go to secure the rear of the pan, the wing bolts fall in line with the spars so they are out. And the purple is where two 1/8" dowels will go to secure the front.
Old Jan 07, 2013, 06:44 PM
ace4rc is offline
ace4rc's Avatar
tampa,florida
Joined Nov 2007
Almost forgot, I set the top wing earlier just to get a view of it.
Build Log Pitts S1S for 100 watts scratch build Mike Tully Scale Kit/Scratch Built 73 Nov 24, 2013 10:32 AM
BH Pitts S1S ARF flycatch Non R/C Items (FS/W) 0 Dec 07, 2012 02:16 PM
For Sale Great Planes 1/3 Scale Pitts S1S michaelrc Aircraft - Fuel - Airplanes (FS/W) 2 Mar 31, 2008 11:15 PM
Build Log 33% Andy Sheber Pitts S1S F1 Rocket Giant Electric Planes 6 Sep 18, 2007 02:08 PM
