Old Dec 11, 2012, 03:22 PM
Cyberdactyl is online now
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
Help!
HK Board V2.1 issue
I finally have my quad setup and am testing it.
I'm using X-config and noticing my M4 channel responds only to throttle. The other channels seem fine and are responding as they should to board orientation. I have the pots all set to 50%. I'm using LazyZero's X config. I moved the ESC connector that was on to M4 to M3 and the M3 to the M4 to verify the issue is on the control board. I did accidentally put the connector on M4 backwards once (signal wire on the outboard). Would that brick the board? Do I need to reflash? Or could it be something else?
Cyberdactyl is online now Find More Posts by Cyberdactyl
Old Dec 12, 2012, 02:04 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
What version of code are you running?
Steveis is offline Find More Posts by Steveis
Old Dec 13, 2012, 09:26 AM
Joined Mar 2011
Never mind, I found the answer. It's an inherent issue with Kaptenincuk's (not Lazyzero) control board flashing code for the 4.7 series. It's colloquially now referred to as the "lazy M4".
Old Dec 13, 2012, 02:56 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Actually, it's not a problem with KK's code, it's a limitation of the AVR processor. The original KK board uses the internal clock oscillator on the chip and it's just not very accurate. Mostly it works, but it varies a bit with supply voltage and temperature and varies between chips too.
If you find you need heaps of trim to get your quad flying nicely, then check out pug398's variations that account for common trim problems: http://www.rcgroups.com/forums/showt...9#post21122836
I think some of these are also available in LazyZero's KK flashing tool.
mattcro is offline Find More Posts by mattcro
Old Dec 13, 2012, 03:00 PM
Joined Mar 2011
Yes, I am going to try KK47x1540M168 tonight as a matter of fact.
Help! Yaw problem with HK KK Board V2.1, KK firmware 4.7 count74 Multirotor Talk 2 Jul 18, 2014 04:37 PM
Discussion HK KK V2.1 board not arming Woodchuck12 Multirotor Electronics 6 Aug 24, 2012 02:43 PM
Sold HK Multirotor control board V2.1 soarsimon Aircraft - Electric - Multirotor (FS/W) 2 Jun 23, 2012 02:36 AM
Help! Which software version is + configuration for HK board v2.1? Arxangel Multirotor Talk 8 Mar 23, 2012 04:13 PM
Help! Problem with HK board v2.1 Arxangel Multirotor Talk 3 Feb 24, 2012 06:37 PM
