Old Dec 11, 2012, 01:41 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Question
Advise on wing twist for rubber powered wing
I've gotten into rubber powered free flight recently and have found myself enjoying it a lot. In fact, I currently have more free flight projects than RC. So I thought I'd take a stab at designing a penut size flying wing.
Here's a CG calculator link to my basic design: http://fwcg.3dzone.dk/?wing_span=14&...ow_mac_lines=0
I tried entering the values into the Pankin twist formula but ended up with non-sensical results (gave me 2000+ degrees of twist). So I thought I'd do the next best thing: ask other people's opinions.
I don't necessarily need precise calculations. Just want to poll you guys about what amount of twist feels about right for my wing design. TLAR would do just fine. My gut tells me that I'd want around 6 to 8 degrees.
So, what do guys think?
slebetman is offline Find More Posts by slebetman
Old Dec 11, 2012, 02:44 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
I guessed at some numbers but this is what my spreadsheet gives for 5% static margin at 12 mph:
Best glide 3 degrees twist and 8 grams
Minimum sinking speed 6 degrees twist and 10 grams
--Norm
nmasters is online now Find More Posts by nmasters
Old Dec 12, 2012, 03:13 AM
slebetman's Avatar
Joined Jun 2009
Thanks Norm, I guess you're better at guessing input values than I am. Must have messed up something. My airfoils are just hand drawn approximations of typical thick Horten style airfoil so I don't have exact coefficient values. So I just guessed them and I guess my guessing didn't work.
I think I'll start with 5 degree twist for now and just build a prototype. Then modify my plans based on test flight experience.
Not sure if I should start a build thread here or the free flight forum. The free flight forum looks very quiet lately.
Old Dec 12, 2012, 01:44 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
I assumed a flat plate at such small dimension so put in 0 for both ZLA and cm. It would be better to know the actual airfoil data but if you're hand drawing them it's hard to know. Also I think I typed in the weight numbers backwards. Maximum duration at minimum sinking speed is most influenced by span loading so 8 grams at 12 mph.
Best distance will be at a higher speed so slightly more weight, about 10 g.
The 12 mph guess was because I assumed that you would be flying indoors. Allowable weight goes up as the square of the speed so a little faster can carry a lot more weight.
Old Dec 13, 2012, 08:46 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
It's a wing.build it on here.
Stuart
Stuart A is offline Find More Posts by Stuart A
Question Balsa folding wing plane powered by rubber slingshot ? cyclops2 Hand Launch 7 Oct 31, 2012 08:50 AM
Question Top/Bottom or I-Beam spars in rubber powered plane wings??? Pauliwog Free Flight 16 Oct 01, 2012 12:12 PM
Discussion Rubber Powered Flying Wing cherobee 3D Foamies 1 Sep 15, 2012 09:49 PM
Discussion BOLT ON WING MOUNTING (converting from rubber band) Wylie Shaw Sailplane Talk 15 Aug 17, 2012 04:24 PM
