Old Dec 11, 2012, 12:43 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Question
Foam U2s ?
Who is still making them about the same size as the old Phase 3 ?
Bare frame is preferred.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 11, 2012, 04:50 PM
killickb is offline
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Hobby People still have 10, Phase3, black U-2's in stock.
killickb is offline Find More Posts by killickb
Old Dec 11, 2012, 11:15 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
That is the only foam U-2 that has been produced.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 11, 2012, 11:42 PM
Carlos G is offline
Find More Posts by Carlos G
Joined Feb 2011
Hi All,
FWIW, Lanier R/C had a foam U-2 model for a while. It was never meant to be a EDF model but rather an R/C glider or FF.
I still happen to have one in the box. Hmmm I wonder if....
Carlos G.
Carlos G is offline Find More Posts by Carlos G
Old Dec 12, 2012, 06:55 AM
cyclops2 is offline
Joined Mar 2003
Thanks Tom.
I ordered all the body parts to make a non-powered tow line glider. Want to sit under a umbrella with a cooler of food & tonics this summer.
Old Dec 12, 2012, 08:04 AM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Originally Posted by Carlos G View Post
Hi All,
Carlos G.
That model was called a U-2, but it did not resemble one at all.
Old Dec 12, 2012, 08:14 AM
cyclops2 is offline
Joined Mar 2003
It was wide winged. Long skinny body. & white
Sounds more like a hungry angel.
I never could convert that plane very well. Too fragile on landings less than perfect.
Ordered a Corona receiver Synth 4 ch. & 4 HS-55s for the hollow U2 glider.
Hoping I can thermal it with a gentile winch launch.
Old Dec 12, 2012, 10:21 AM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
The drag from the inlets is going to more or less kill the performaces as a pure glider. Clear fairings over the inlets will help, but I do not see it as a decent performing sailplane.....
Old Dec 12, 2012, 11:31 AM
cyclops2 is offline
Joined Mar 2003
I accepted the poor performance as a trade off to having a scale military aircraft.
Not sure about frontal drag with the 2 inlet covers being less draggy than the air flows in & out ?
On the fence about that one due to very slow speeds of a U2.
Ordered the wings also. So I will now be able to use very light spackle to fill in all those body & wing lines. Plus anything else that creats more drag. Will fill in all the aileron surfaces & go to a straight R E M set up with pull-pull strings for lighter setup.
It looks like a wing load of 6.4 oz. per sq. ft. as a non-powered glider.
The wing is sort of Clark Y with a reflex curve in the trailing portion. I do not know airfoils.
Old Dec 12, 2012, 02:57 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
On the fence about that one due to very slow speeds of the U-2.
Properly designed fairings to cover the inlets will indeed be less draggy than the open inlets. Leaving the ducting open means the entire duct area will create parasitic drag. Also, without a fan running, some air will pile up around the outside of the inlets, creating more drag. Then there is the drag of the rear of the aircraft being a couple of inches in diameter.
If you study the various popular PSS (power slope scale) jet designs, you will see that the designers usually greatly reduce the size of the inlets from scale to get rid of this problem. And none of them ever make the ducts flow through.
I own the powered version of the Phase III U-2 and it does not have a great glide performance power off. A decent glide, but not a great one.
Old Dec 12, 2012, 03:15 PM
cyclops2 is offline
Joined Mar 2003
Thanks again Tom.
Not many people posted about the flight characteristics.
Definately make up the inlet cones.
I was floored by the input currents of 33 amps or about 400 watts input power. I am seriously thinking of doing a pusher prop setup that I used in the GWS F-15. It allows simple COG with any weight parts.
Old Dec 19, 2012, 07:44 AM
cyclops2 is offline
Joined Mar 2003
Thomas
The Polar 1 liter plastic bottles are perfect for intake cones.
Thanks for the advise.
New Product (Acro Wot Mk2 Foam-E) The 80's British cassic is reborn in FOAM! richos Foamies (Kits) 7 Apr 19, 2015 12:30 PM
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 10, 2014 11:58 PM
Discussion Want to cut foam wings- Need Foam Supplier Aerobotix The Builders Workshop 1 Feb 27, 2012 07:55 PM
Video Three Lanier U2s wmcneal Electric Plane Talk 0 Mar 04, 2006 12:03 PM
Has anyone built one of the Lanier U2s for slope flying? McGrrr Slope 6 Oct 09, 2002 09:20 AM
