I've also tried with a recorder with no more luck (there) I've tried many combinations of switches (not all as I haven't done it mathematically), all I get is snow. It sometimes comes close, but not enough... Anybody got it to work with other hardware than F7 radio? |
Michigan
Joined Nov 2007
Michigan
Joined Nov 2007
I purchased the TX5805 camera but haven't received it yet, I wish someone would list all the frequencies and corresponding channels for it. I also purchased a 5.8G 25Mw 90deg. wide angle micro camera from ebay. I initially bought the V2 for my daughter since it's a little less twitchy than the V1. The websites sure don't help with the confusion on what's what with these. As I understand, The V1 is 6 axis and can do flips and rolls, The V2 is 3 axis and can't. The websites say otherwise, Here's the info off of Nitroplanes for the V2.
With a feel reminiscent to that of a hovering beetle, it is no wonder why Walkera chose to name their quad-copter the Ladybird. At only 4in x 4in and just 29 grams, this mini quad-copter is extremely nimble yet stable. Suitable for beginner to expert levels, the Ladybird is simple enough for novice pilots, but can also handle more advanced maneuvers. Equipped with Walkera’s 6 Axis Gyro technology, the quad-copter utilizes an accelerometer to detect movement and compensate for more stability. The Ladybird is usable in two different modes, beginner mode and 3D mode. Beginner mode limits how much the quad-copter can pitch and yaw by utilizing the 6 Axis Gyro. The 3D mode removes that limitation, allowing the quad-copter to “roll” or flip. The included 4 channel 2.4ghz transmitter allows for plenty of user settings along with a dual rate switch to control sensitivity and travel. And then under "Features". Features: Model level and Toy's price which is the best choice for the beginners. Adopted latest 3-Axis control system, flight more stable, 3D maneuvers more professional. 2.4G Frequency-hopping spread spectrum technology with strong anti-jamming , which can control more than 100M. Compatible with DEVO series radio evo 12S/8S/10/7/7E/6S/2402D.Cute and lifelike appearance similar to Ladybird. Then to top it all off there's a video of the V2 with the new Devo4 demonstrating the flight mode switch. I know from pictures that the V2 is missing the accelerometer and the update ports but maybe the new one has both the gyro and accelerometer on the same chip, IDK?. Also to add to the confusion, I have found a version called the Dexterous, I think this is a V1 with the ability to switch the roll function on and off. So it seems there are 3 or 4 different versions of the ladybird perhaps. So if I am correct, The V1 is 6 axis and old firmware, The Dexterous is 6 axis with new firmware and the V2 is supposedly 3 axis but what about the V2 video where they change flight modes?.
I also plan on making a charge harness for 3 1s packs and will use a 3b 110v charger for them as I have ordered 5 350mah 25c 1s batteries for it as well. |
Michigan
Joined Nov 2007
That is strange, Tony was using a different brand VTx and received video on the F7 so you think the TX5805 would be able to work with the VRx that was meant for the other VTx. I am beginning to think your 5805 has a bad antenna on it, Try placing your VRx about 6ft. off the ground and see if that helps, Also make sure no other 5.8g equipment is around. Most new cordless phones are 5.8g and there are 5.8g WiFi routers. You might want to try outside or in another location, That's about the only other thing that I can think of at the moment.
I have tried to gently shake the antenna, didn't make a difference. The base of the antenna seems well fixed, although I can't see well - it is under a heavy glue layer... I haven't removed the plastic protection yet to see if something faulty of the board. The TX heats a bit, but not as much as some mini camera/tx boards I have... |
Michigan
Joined Nov 2007
Not knowing if your VTx is faulty or not is going to make it impossible to verify what frequencies work. Maybe Tony could cycle through his F7 channels one by one and verify what frequencies each channel corresponds to. Also, Many report that the 5805 gets pretty warm under normal conditions. Most of the antennas that come with the VRx's are not very good so if you don't have anything other than what came with your RC305 it will be hard to eliminate that as a cause.
Michigan
Joined Nov 2007
| Thread Tools | |
| Discussion Walkera Mini CP (and Blade 130X) - sub micro FPV setup | Picofly | Micro Helis | 133 | May 11, 2013 10:39 AM |
| Help! Mini Multirotors sub-forum in the Multirotors forum Vote Please! | jesolins | New Forum Requests | 67 | Dec 17, 2012 12:20 PM |
| Discussion Walkera Mini CP sub-micro FPV heli (AUW 54g) | Picofly | Video Piloting (FPV/RPV) | 20 | Dec 15, 2012 06:30 PM |
| Help! New Mini and Micro Multirotor sub-forum to Multirotor forum Please Vote! | jesolins | Micro Helis | 11 | Aug 29, 2012 06:22 PM |
| Discussion Walkera Mini CP tail motor not going | Samw5 | Micro Helis | 4 | May 22, 2012 10:02 PM |
