Old Feb 18, 2013, 12:58 PM
centralfornia is offline
Find More Posts by centralfornia
Joined Dec 2012
Foxtech vtx modded to work w devo f7
Oioioi you are the man! I just soldered the 4th bx pad and now have solid video from my foxtech 400mw to my walkera devo f7! Lets see if. Can beat my 325m of solid video with a 200mw.
centralfornia is offline Find More Posts by centralfornia
Old Feb 18, 2013, 03:03 PM
OiOi is offline
Find More Posts by OiOi
Joined Apr 2009
Unfortunately, physics says, you won't get that much further. In theory, you should now get sqrt(2)=1.4 times further away than before.
BTW: Do you orient the video antenna correctly on your F7 when flying (upwards or downwards)?
OiOi is offline Find More Posts by OiOi
Old Feb 18, 2013, 06:06 PM
Joined Dec 2012
I point the foxtech skew planar up towards the sky on my f7. On my plane the clover leaf is pointed up as well. Should i change the antenna orientation on either one? Today I was Able to fly FPV solely screen on the f7 at ranges over 500 m without the reception breaking up! I really like the ease and portability of the f7 system I grab my craft and my devo f7 and am FPV'ing without any base stations wires or multiple batteries! I am really excited about pushing the limits of what I thought was only fly able at 30m .
Old Feb 19, 2013, 02:09 AM
OiOi is offline
Joined Apr 2009
No, then your antenna orientation is correct. Wish you nice FPV flying !
Yeah, it's really a bummer, that the stock antenna placement of the F7 is so terrible. I bet they will sooner or later bring out a F7pro or something like this with this issue fixed (which should never have happened...). Maybe they even put a SPW-Antenna on it for VRX so that in the end, it will look like yours now.
For the price of the F7, I would really expect something like that from Walkera in the first time.
Old Feb 19, 2013, 07:26 AM
Wartexx is offline
Find More Posts by Wartexx
Wartexx's Avatar
Nederland, Gelderland, Wijchen
Joined Aug 2005
I am actualy thinking about putting my rc305 inside my devo7 , to have it all in one package, or would I have a lot of signal loss with the TX antenna being zo close?
Wartexx is offline Find More Posts by Wartexx
Old Feb 19, 2013, 09:25 AM
Joined Dec 2012
I am top really disappointed with the factory form. I believe walkera did this so they could continue to use the same mold as their other transmitter layouts?
Old Feb 19, 2013, 09:34 AM
Flyingfool is online now
Find More Posts by Flyingfool
Flyingfool's Avatar
Belle Chasse Southern, Louisiana, United States
Joined Apr 2002
I have a 305 that is on band A from the factory (has a resistor on pin 8)
What would I have to do to make it switchable between band A & band E?
Randy
Flyingfool is online now Find More Posts by Flyingfool
Old Feb 19, 2013, 09:54 AM
OiOi is offline
Joined Apr 2009
First I thought the same. But they surely have a completely different front plastic mold, due to the display. It could only be, that they have the same backside mold, and wanted to safe a bit money on that.
But even then, if I were Walkera, I would have just made it like you. Just make an antenna Plug on the outside of the casing. That is a dead simple and cheap solution, and increases the usability of this transmitter a manyfold! Even if they then would just include a rubber ducky for it, everybody could easily replace it with some other antenna.
Hmm, if only your Pin 8 (BX) has a resistor, then you have a "B"-band module. For "A"-band, there will also be a resistor on the Pin 48 (S).
Exactly the same, as the mod I described for the RC305 with preset "E"-Band.
The only difference would be, that you first desolder the resistor(s) on the channel selection pins.
If you only want to be able to select between "A" and "E", then you can just solder a wire to every selection pin, as described, but then solder both wires to the unused 4th dip-switch. Like that both selection pins are either "1" or "0" (Band E or A).
Old Feb 19, 2013, 10:19 AM
Flyingfool's Avatar
Joined Apr 2002
I know for sure it is band A and it may have the resistor on pin 48 too as I am not home to check right now.
So having the two wires from the pins (pin 8 & pin 48) together won't cause any problems?
Thanks for the info! now to see if I can destroy my receiver with my bad ass eye sight.
Randy
Old Feb 19, 2013, 10:31 AM
OiOi is offline
Joined Apr 2009
Nope, these are just logic inputs of the RTC.
Old Feb 19, 2013, 04:47 PM
Wartexx is offline
Wartexx's Avatar
Joined Aug 2005
Have been flying around today without any problems:P Took a while to get the fail safe off btw... First I put the throttle to save L100 (-100%) , but that kept the engines running at a quite low speed , so it wouldn't fall down immediately. As I am afraid to burn the engines when it lands in the grass, still turning, I tried to get it to switch of completely. After a few tries, I found out that the 0 position for throttle was actualy right... Have been flying arround happily sinds then, flying arround our chimney and landing on roofs ^^. Only problem I have found is, the cg. Because of the added cloverleaf, the cg isn't in the center anymore. I have tried replacing the battery , but doesn't seem to work. When I give it full throttle, it pulls to one side... otherwise it flies great... The added weight of the 610 battery does seem to make it more stable though
Old Feb 20, 2013, 07:09 AM
OiOi is offline
Joined Apr 2009
What are your flight times like that?
BTW: I just realized that I didn't mention, that the TX5805 camera has the same lense mount (1/4") as the 808 #16 V2. So the 808 #16 V2 D Lens is a direct replacement without any fiddling needed for having a wide angle option (which I strongly recommend!).
Maybe it has already been mentioned. But just for completeness reasons I mention it (again).
Old Feb 20, 2013, 11:43 AM
Oso Grande is offline
Find More Posts by Oso Grande
Need more props..........
Oso Grande's Avatar
United States, TX, Houston
Joined Jan 2013
That's fantastic news. Flying my TX5805 around the house and yard last weekend would have been a lot less nerve wracking if the FOV was wider!
Oso Grande is offline Find More Posts by Oso Grande
Old Feb 21, 2013, 01:03 AM
Wartexx is offline
Wartexx's Avatar
Joined Aug 2005
Indeed great news! Will have a look for a lens tonight,
any idea where you can buy them?
My flight times are 8-9 minutes, havent acurately measured it.
Old Feb 21, 2013, 02:55 AM
OiOi is offline
Joined Apr 2009
Just search for "Lens D Module" on ebay. It costs $12 incl shipping.
Unfortunately they don't just sell the lens alone, but only incl the camera and the keychain casing...
BTW: The lens of the 808 camera is glued to the camera. The easiest way to get it off, is to put some CA-Debonder on the place, where the glue is, wait a few minutes, then you can easily screw it off. But then first clean the thread, before screwing it into the TX5805 cam.
Discussion Walkera Mini CP (and Blade 130X) - sub micro FPV setup Picofly Micro Helis 172 Nov 10, 2014 06:35 AM
Discussion Walkera Mini CP tail motor not going Samw5 Micro Helis 7 Sep 14, 2014 09:12 AM
Help! Mini Multirotors sub-forum in the Multirotors forum Vote Please! jesolins New Forum Requests 67 Dec 17, 2012 12:20 PM
Discussion Walkera Mini CP sub-micro FPV heli (AUW 54g) Picofly FPV Talk 20 Dec 15, 2012 06:30 PM
Help! New Mini and Micro Multirotor sub-forum to Multirotor forum Please Vote! jesolins Micro Helis 11 Aug 29, 2012 06:22 PM
