Old Dec 11, 2012, 08:04 AM
wbender is offline
Find More Posts by wbender
Bill
Central NY
Joined Apr 2010
#38 Model Airplane Building Clinic >> “Park Scale Models Monocoupe 90A"
This is the build log for the Park Scale Models Monocoupe with sport wing.
http://www.parkscalemodels.com/shop/item.aspx?itemid=2
This is part of the group build along started here:
http://www.rcgroups.com/forums/showthread.php?t=1704076
Better late then never
Bill
wbender is offline Find More Posts by wbender
Old Dec 11, 2012, 08:16 AM
wbender is offline
Bill
Central NY
Joined Apr 2010
Here are pictures of the kit contents.
Old Dec 11, 2012, 08:58 AM
wbender is offline
Bill
Central NY
Joined Apr 2010
I've gotten started. Here are the fuselage formers made up. The formers in one fuselage side and then the second side installed. Really need to be careful when putting the second side on, the formers can be fragile .
Bill
Old Dec 11, 2012, 10:39 AM
wbender is offline
Bill
Central NY
Joined Apr 2010
The top & bottom stringers are in place.
Bill
Old Dec 12, 2012, 02:35 AM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
I built my 'Coupe w/flap wing 5 years ago. Got it all covered and just needed to decide on final trim scheme. Put it on the shelf "for a while" and a few days ago finally pulled it out again. I think I'm going to simplify the scheme and recover the wing and tail feathers. Gotta come up with a new motor too as I gave away all the IPS gearboxes I was planning to use with a Medusa 12mm motor. Will probably go with an outrunner now as I can't find any IPS stuff anymore.
I'll watch your build as it's been so long I can't even remember my build!
Joe
turbojoe is offline Find More Posts by turbojoe
Old Dec 12, 2012, 05:53 PM
dmbaerry is offline
Find More Posts by dmbaerry
dmbaerry's Avatar
United States, NC, Burlington
Joined May 2012
Looks like a great start
dmbaerry is offline Find More Posts by dmbaerry
Old Dec 13, 2012, 08:55 AM
wbender is offline
Bill
Central NY
Joined Apr 2010
Thanks for the interest and encouragement.
I've gotten a little further, have assembled the landing gear assembly, servo/firewall mount, and firewall. Unfortunately when I went to join the servo/firewall mount to the landing gear assembly I discovered that the tabs on FW2 are not centered and of course I have then wrong with relation to FW3 &FW4. Now trying to decide if I should trim the tabs on FW2 or if that would weaken the assembly too much.
Old Dec 13, 2012, 10:42 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
How much needs to be trimmed off. If its not that much the. It shouldn't be anything to sorry about and you could always add a filler piece or fill the gap with some epoxy.
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Dec 13, 2012, 03:32 PM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
De-bond and re-assemble.
loNslo is offline Find More Posts by loNslo
Old Dec 17, 2012, 08:50 AM
wbender is offline
Bill
Central NY
Joined Apr 2010
I decided to trim the tabs to fit. I was nervous about debonding the assembly, I used a lot (probably more than was needed) of CA and wondered if I was able to debond it would I weaken the plywood pieces. Here is what the assembly looks like all put together.
Bill
Old Feb 14, 2013, 11:54 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Bill,
How is she coming along?
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Feb 20, 2013, 04:36 PM
wbender is offline
Bill
Central NY
Joined Apr 2010
I got side-tracked for a while and then forgot to take pictures as I went along. I am almost to the covering stage and here are some pictures to show my progress.
I followed the plans and they had the wrong spot for part TA3, which is the "guide" for the aileron cable. The control horn on the sport wing is in the center of the full lenght aileron so I had to cobble a "guide" in the correct position. Now I am not sure if I should attach the struts in the normal position or if I should go to the other side of the rib. Concern is the way it is now, the aileron cable has a "hump" in it right before it exits the wing, not sure if that will put too much stress on the single aileron servo.
Bill
Cool Model Airplane Building Clinic ~ Building A Kit Murocflyer Parkflyers 484 Mar 14, 2013 02:37 PM
Sold Monocoupe 90A (Park Scale Models) - $200 shipped (lowered price) rexnuktia Aircraft - Electric - Airplanes (FS/W) 7 Apr 24, 2011 09:39 AM
Sold Zeke's Park Scale Models Monocoupe 90A Bob SF Aircraft - Electric - Airplanes (FS/W) 0 Nov 13, 2010 09:34 AM
For Sale scale park model monocoupe 90a cheerio2003 Aircraft - Electric - Airplanes (FS/W) 1 May 23, 2010 01:14 PM
Sold FS - Park Scale Models-Monocoupe 90A zbrubaker Aircraft - Electric - Airplanes (FS/W) 2 Dec 14, 2006 12:37 PM
