Old Dec 10, 2012, 05:07 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Almost a disaster
As coordinated previously with Alan T, I am powering a geared brushed Astro 25 with two 3S 2220 mah lipos in series
(25 volts) using an Astro 211 ESC and using an Optima 6 Lite receiver, powering the servos with a Kool Flite UBEC and the receiver direct from the motor battery through the SPC port. The throttle signal output from the receiver is fed through a Li-Saver (not shown on diagram) from which provides a low voltage cutoff feature that the old ESC is lacking.
When I plugged in the motor battery, nothing worked except the UBEC got very hot and started to smoke faintly. I disconnected the battery and let the UBEC cool off. I found that I had the connector to the SPC port plugged in backwards which somehow caused the UBEC to get hot nearly letting the magic smoke out. I disconnected the battery and let the UBEC cool. When I plugged power lead back into the SPC port with proper polarity, everything worked normally and Kool Flight UBEC stayed cool. Moral: Make sure to get the plus and minus orientation of the SPC pigtail connector correct before applying power.
E-Challenged is online now Find More Posts by E-Challenged
Discussion Help! Disaster Assembling new Radian EddGee Sailplane Talk 13 Apr 21, 2012 06:30 AM
Discussion Training for disaster? Hixxer Simulators 1 Mar 19, 2012 05:37 AM
For Sale I HAD A disaster almost burn the house down :(, got some parts to help you guys out sherlockshah Aircraft - Electric - Jets (FS/W) 8 Nov 23, 2010 05:42 PM
Discussion Disaster Area's latest disaster Disaster Area Mini Helis 19 Dec 13, 2007 03:06 AM
