Old Mar 15, 2013, 05:02 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Originally Posted by Mike Smart View Post
Oh dear is that the Gening servos?
Im not sure how good they are. I had one that initially had a bit of an oscillation on the return to centre , but seemed to cure itself after some testing on the tester. Was gonna send it back but it cleared up.
jimbo320 is offline Find More Posts by jimbo320
Old Mar 15, 2013, 05:55 PM
PlaneButcher is offline
Find More Posts by PlaneButcher
Canada, ON, Toronto
Joined Oct 2012
Thought I would report back on how the motor is holding up after being epoxied back onto the ESC board. I hit the gym floor hard a couple times today and the epoxy is holding no problem. I have the new motor as a backup but not sure if I'll ever need it. Unless I order another mini as backup. But then again this mini seems almost indestructible. Damn fun plane to fly!
PlaneButcher is offline Find More Posts by PlaneButcher
Old Mar 16, 2013, 12:43 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Originally Posted by jimbo320 View Post
Thats real tough luck Kris. What servos do you have?
I went with the Genings digital servo's.
Kris... is offline Find More Posts by Kris...
Old Mar 16, 2013, 04:34 AM
jcansdale is offline
Find More Posts by jcansdale
jcansdale's Avatar
United Kingdom, Gunnerton
Joined Dec 2010
Originally Posted by Kris... View Post
...on closer inspection the elevator servo only now move's in a downward direction and even then it keeps locking up so looks like the servo is toast already.
Bad luck. I feel your pain!
Soon after building mine I started having problems with the aileron servo. Upon inspection I found there was a crusty bit of CA glue on the z-bend that was stopping it from moving completely freely. I scraped this off with an xacto blade and loosened up the hinges some more. Surprisingly it flew fine after doing this despite the fact I thought I'd stripped the servo.
My aileron servo did finally give up last week. I've now replaced it using dry UHU Por on the servo and the hole where it fits. It seems to hold well and will make it really easy if I ever need to replace the servo.
BTW, I've been trying one of the Desire Power 35C 300mAh batteries from ElectricWingman. It seems to hold its voltage a lot better than the Nanos (which really don't like the cold). Maybe you could add a few of these you your order.
Good luck!
jcansdale is offline Find More Posts by jcansdale
Old Mar 16, 2013, 05:32 AM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Thats a shame, so far those servos have been great in my Mini. Maybe I will have to order some spares in case, seems like there are no bargains after all
Mike Smart is online now Find More Posts by Mike Smart
Old Mar 16, 2013, 05:34 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Good luck!
There in no CA crud on the z-bends or control rods Jamie all the surface's move freely i always check this from past experience's
Will give the dry Por ago on the replacement servo. You were right about the E6000 though... when the servo locked up the Mini it came down pretty hard on its nose, usual you would expect some damage... a torn piece off EPP or some crumble damage, but there was no damage at all .... awesome stuff hehe
Old Mar 16, 2013, 05:42 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
I have ordered another Genings Mike maybe i just got a bad one, so lets see what happens ? if another one goes it will be Hitecs all round for me.
Old Mar 16, 2013, 05:45 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Kris, where did you add the e6000 on the model? Just around the nose quarters?
Old Mar 16, 2013, 06:15 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Around the nose area... landing gear and the top of the fuse area where you carry it,also on the tail and wing ends basically any part that is vulnerable and has the potential to touch on impact.
Old Mar 16, 2013, 06:37 AM
Mr Moff is offline
Find More Posts by Mr Moff
Joined Dec 2012
I've been using the gening servos in my mini for a month or so. About 300 flights so far with no problems.
Really liking them so far.
Danny.
Mr Moff is offline Find More Posts by Mr Moff
Old Mar 16, 2013, 08:25 PM
peterdawolf is offline
Find More Posts by peterdawolf
It's the Crack
peterdawolf's Avatar
United States, CA, Ventura
Joined Feb 2013
Originally Posted by cdee View Post
There are some (batteries) on the Twisted Site that are the perfect size. Any thing from a 180mAh to 250mAh 2s pack will work, and for those thinking about 3s... not necessary, the power combo motor rocks on the 250mAh 2s packs and 7x3.5prop.
cdee
Even though outside of recommendations, I don't mind flying it at all on Nanotech 35-70c 300mah lipo's. I did need to move the CG slightly further back by putting in the battery lengthwise. I think it's pretty good, although I may be slightly forward.
Planning to do a v2 of this one, because I have quite a bit of CA on the nose so far, the CG is probably moving a tad forward
Peter
peterdawolf is offline Find More Posts by peterdawolf
Old Mar 17, 2013, 09:52 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
I weighed my Hyperion 2s that I have from the crack yak.
My question is, is this going to he too heavy to use on the mini?
My total weight would be then be 98g of which 30g would be the battery.
Anyone fly the mini outdoors at this weight? How is it?
Cheers,
Jimbo.
30g Hyperion by slopeflyer12, on Flickr
Old Mar 17, 2013, 09:54 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
My total weight would be then be 98g.
I have some of these but didnt try then due to there weight.
Old Mar 17, 2013, 11:02 AM
jcansdale's Avatar
Joined Dec 2010
The motor and ESC would be able to take it and you'd have plenty of power. There's a guy on here who swears by 450s on the Mini, but it makes the wing loading too high for my taste.
Old Mar 17, 2013, 07:28 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
The Mini is such a great flying airplane... bunch of videos today. Going to post three on the blog but here is one for the Mini thread. Hope everyone had a good time this weekend!
CRAZY COOL 3D INDOOR MINI 031613 (4 min 16 sec)
I need a Twisted 100CC that flies like this and then we're all set
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Latest blog entry: Joe nall 2016 - epic vid
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3536 Jun 25, 2016 01:38 PM
Discussion Twisted Hobbys - Crack Yak Lite - Build Thread hercdriver7777 3D Foamies 1164 May 20, 2016 11:11 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
