Old Jan 31, 2013, 02:11 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Originally Posted by wishawhunk View Post
Nice 3 blade prop! I put a 10grams motor on mine but havent tested it yet.
BTW I got my refund from the motor I returned to Robotbirds. I wont be using them or BRC Hobbies again as A Sethi owns them both. Have bought from RB from mnay years and there is no loyality from their customers, and I bought a fair bit from him too! Ah well his lose.
h Well his lose.
Think the 10 will do better than that 5 you had on there. Got two 10g motors one on a mini flrefly and the other on a 22" yak they put good with a 6x3 prop.
Originally Posted by Aviefly View Post
Naa no chance of that, I don't like skinny chicks
How skinny you planing to go on your mini Avie?
KamikazePilot is offline Find More Posts by KamikazePilot
Old Jan 31, 2013, 02:17 PM
wishawhunk is offline
Find More Posts by wishawhunk
scotland uk
Joined Jan 2005
[QUOTE=KamikazePilot;23991862]Think the 10 will do better than that 5 you had on there. Got two 10g motors one on a mini flrefly and the other on a 22" yak they put good with 6x3
I changed it kam from a 5g to a 15g. The reason I got the 5g was because the info on the RB site, then to find out it the figuers was way off. The 15g I felt was a little heavy and inverted was very difficult. I am hoping this is 3rd time lucky with the 10gram motor ;-)
wishawhunk is offline Find More Posts by wishawhunk
Old Jan 31, 2013, 08:31 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Started the build yesterday Did about 4 hours. I'd say I'm about 50% done I'm nearly 100% sure this'll be ready for Saturday!
The build is going very nicely! The motor works, all the airframe parts fit together nicely, etc.. The only thing I'll say is that the HS-5035HD servos are just a tad on the small side. I've dabbed a little bit of CA onto all three of them just to reduce the amount of wobble. I've also wedged a small bit of card inbetween the sides of the aileron servo and slot to stop any slipping. One good thing I've noticed about these servos is that as they come with a very very long servo arm as well as other shorter ones, for the ailerons I can just use the Hitec one without gluing any wood piece on Only thing I've noticed is that this arm is a tad thicker than the kit's wooden one. Hopefully it'll accept the linkage. If not I'll just dremel it thinner I really like the size of this plane; perfect for where I fly Can't wait to give it a go
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jan 31, 2013, 08:47 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
I understand that you have to do full throttle and 0 throttle to get the motor to run to max throttle. I have done that, but during flight I have to go to 0 throttle every time to get it to go to full throttle....Confusing, I know. It will start to lose power, and if I don't throttle the stick all the way down, it won't go to max throttle. What am I missing? Also, one of my landing gear struts finally broke. I ended up taking them both off, and putting on some round carbon tube with wheels. Be a bit heavier now though.
J
jabsten is offline Find More Posts by jabsten
Old Jan 31, 2013, 09:04 PM
ericrcpilot is offline
Find More Posts by ericrcpilot
ericrcpilot's Avatar
United States, SD, Worthing
Joined Jul 2008
J
Sounds like a weak battery.
ericrcpilot is offline Find More Posts by ericrcpilot
Old Jan 31, 2013, 10:47 PM
Maylon is offline
Find More Posts by Maylon
United States, NY, Dansville
Joined Jul 2010
For the aileron servo, you still want to glue the provided wood one on to the Hitec arm, even if you don't need the length because it provides differential.
Maylon is offline Find More Posts by Maylon
Old Jan 31, 2013, 10:57 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Actually, it removes the differential induced by the aileron angle at the back of the wing.
It makes the servo arm intersect the control rod at a 90* angle as well as the ailreon control horn to control rod.
The result is equal aileron travel up and down which is 0* differential.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Jan 31, 2013, 11:54 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
No, it does it on all my new thunder power batteries.
J
Old Feb 01, 2013, 01:42 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
I've just been fondling my RTR very cute wee thing, my smallest motor so far.
How are you getting on getting the gear together Kris?
No mate going to see what you get then do the same Still cant find the motor/esc instock in the UK
Kris... is offline Find More Posts by Kris...
Old Feb 01, 2013, 07:40 AM
Joined Jan 2012
JC
Thanks for the help!
Do you guys think it's enough of a problem to warrant me cutting out the servo and then putting on the kit arm? I don't think I'll be able to take the arm off without yanking the servo out of its slot. Stupid me has already stuck the servo in with some uhu por and CA, so I'd have to cut the foam, haha!
Old Feb 01, 2013, 07:58 AM
jcansdale is offline
Find More Posts by jcansdale
jcansdale's Avatar
United Kingdom, Gunnerton
Joined Dec 2010
Can't you push the foam aside to get at the servo screw? Failing that you could enlarge the hole slightly so you can get to it.
jcansdale is offline Find More Posts by jcansdale
Old Feb 01, 2013, 08:15 AM
Joined Jan 2012
Didn't think of that Thanks! When I get home I'll have a look and see what I can do!
Old Feb 01, 2013, 08:36 AM
Twisted Do Nut!
Joined Dec 2010
I don't see why you wouldn't be able too. When I built mine I didn't add the arm till after I got the servo in. Looking forward to what you can do with the wee beastie Francis.
Old Feb 01, 2013, 10:51 AM
MOfroggy is offline
Find More Posts by MOfroggy
East Texas
Joined Nov 2008
JC
I wondered what all of those "curved" servo horns were about and now that you have explained it I think I get part of it but not all of it. I guess ideally the servo arm would interact with the surface control horn at exactly 90 through out it's travel but since it is going in an arc and it is hard to get the angle at 90 because of most plane designs it can't do that and the differential arm design tries to take as much of that out as possible. Is that anywhere close to right?
Is that why on my DX6i and DX8 there is an adjustment for Differential or is that about something else?
MOfroggy is offline Find More Posts by MOfroggy
Old Feb 01, 2013, 10:56 AM
Joined Jan 2012
Sounds good then!
Thanks, really can't wait to fly it! It's such a nice size
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3484 Feb 03, 2016 09:57 PM
Discussion Twisted Hobbys - Crack Yak Lite - Build Thread hercdriver7777 3D Foamies 1159 Feb 02, 2016 10:30 PM
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6623 Jan 21, 2016 12:34 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 07:36 PM
