Old Dec 18, 2012, 05:34 PM
lugnutz is offline
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
Originally Posted by JohnRB View Post
My Crack Yak Mini is almost finished. Only thing left is installing the receiver, battery and elevator & aileron push rods.
A few observations:
The video shows the tail skid being mounted on the bottom of the glued on vertical fin/rudder. The written instructions shows it being mounted to the bottom of the fuselage. I mounted mine as per the video. I don't think it makes any difference either way, however, but sets of instructions should agree.
The horizontal fuselage has holes for the landing gear. These two holes are not the same distance from the front of the plane, one is slightly farther back. Both the video and the written instructions show assemble the correct way. It might be a good idea to warn builders to not install differently.
I did not rush to finish as it was very gusty here today so even if it was complete I would not have attempted a maiden. I want a calm day to trim it out.
John
mounted tail skid on bottom of fuse near the rudder
lugnutz is offline Find More Posts by lugnutz
Old Dec 18, 2012, 05:37 PM
lugnutz is offline
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
Originally Posted by KamikazePilot View Post
You could glue it or use servo mounting screws like below. I added some tape to make it slide on the straight edge I use for cuts.
Just a few more things on the mini and it's done. Attach the rudder, install tail pushrods, and clean up the electronics, of course the lg as well.
wait until you fly it you are gonna love it
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
So how do you like it lugz?
Thanks Grav, but I got the idea from one of the guys here on rcgroups. He did something similar for 45 degree cuts. Figured Iíd use the same idea since I canít seem to cut 90s in my foam.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Dec 18, 2012, 05:39 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Me, too.
It's nice to be able to wiggle the rudder w/o moving the tail skid.
(If it were a tail wheel, I might go the other way.....)
pugsam is offline Find More Posts by pugsam
Old Dec 18, 2012, 05:43 PM
lugnutz is offline
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i flew it last night in my parking lot under the lights,got it all trimmed,flew like a dream,plenty of power and speed,then again everything is fast in the dark ,handles well and pretty snappy,i need some daylight time on her to get it really dialed,right now the wind is gusting up to 30 mph
Old Dec 18, 2012, 05:44 PM
lugnutz is offline
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
Originally Posted by pugsam View Post
Me, too.
yes if it were a wheel i would also mount it on the rudder
Old Dec 18, 2012, 05:48 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Sorry I missed a couple pages guys.
Top of fin lining up: You need to glue from the outside in when putting on the fin. Line up the bottom and roll on the bottom piece without doing the top half. Then lineup the top and roll it on toward the joiner. EPP shrinks, bends and expands depending on temp, humidity etc. It is easy to stretch or move it back into place.
Prop O-Rings: If you use the thin O-rings that come with the motor and kit you will need two of them. If you use a thicker O-ring you need to be careful that it is not so thick that it rubs on the stators inside the motor. The medium sized - Twisted O-Ring will work but you have to make sure it is not rubbing on the internal motor parts before you fly it. Two of the thinner bands wors well though.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Dec 18, 2012, 07:11 PM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Maiden in the bedroom
Just a quick hover in the bedroom to show how nice it looks.
Mini CRACK YAK Hovering in my bedroom (0 min 0 sec)
ducatirdr is offline Find More Posts by ducatirdr
Old Dec 18, 2012, 07:25 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
LOL
I had to call wifey over to watch that a second time, so we could share the hoot.
The dog gets an Oscar, too!
Old Dec 18, 2012, 07:33 PM
ducatirdr's Avatar
Joined Aug 2006
The dog is used to the way I fly. Notice how he hides behind me. Next time I promise to dial in more expo, edit and maybe clean my bedroom and make my bed.
Well, add more expo...
Old Dec 18, 2012, 07:59 PM
Twisted Do Nut!
Joined Dec 2010
That was great! I see a new trend of bedroom hovering videos...lol.
Smart dog you got there going for cover behind you. If it was me the dog would have left the house.
Old Dec 18, 2012, 08:12 PM
ducatirdr's Avatar
Joined Aug 2006
Full throw with 75% expo is PERFECT!
Mini CRACK YAK in the bedroom (1 min 16 sec)
I'm having fun with this thing. The 75% expo is perfect with full rates.
Old Dec 18, 2012, 08:50 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Hope you don't mind.....I entered your vid in an RCG hover contest........
http://www.rcgroups.com/forums/showp...postcount=1859
(They'll probably disqualify the entry, because they're a very legalistic and technicality-oriented gang. They'll likely make up some absurd rationale, like you didn't use the correct aircraft.)
Old Dec 18, 2012, 08:53 PM
Columbia SC
Joined Feb 2005
http://www.youtube.com/watch?v=bT69N...ature=youtu.be
Awesome!
Old Dec 19, 2012, 01:41 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Sweet that's what we want to see this thing doing
That 75% expo made all the difference in the second video. What did you have it set on in the first? Love the dog, clever little chap and wishing I had a room that size, it's about the size of my whole house
Aviefly is offline Find More Posts by Aviefly
Discussion Twisted Hobbys Crack Pitts 12 Build and Info Thread! cwojcik 3D Foamies 3540 Sep 14, 2016 06:47 AM
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Twisted Hobbys - Crack Yak Lite - Build Thread hercdriver7777 3D Foamies 1164 May 20, 2016 11:11 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
