Old Dec 13, 2003, 09:17 PM
Bill Germanson is offline
Find More Posts by Bill Germanson
Name it, I've crashed it
Bill Germanson's Avatar
JAX, FL
Joined Feb 2002
New House of Balsa P-51 Mustang
New Ziroli designed P-51 Mustang. Laser cut balsa kit. Top quality as always.
Specs:
Wing span 47 in.
Fuselage length 33.5 in.
Wing area 390sq. in.
Wt. with radio 38oz.
Wing loading 14 oz./sq. ft.
4 channel micro radio with 4 micro servos
Motor : Astro 803G geared 020 brushless
Can be seen here:
http://www.houseofbalsa.com/e/env/00...=products:k-72
Not the easiest kit that I ever built because of the a fair amount of sheeting but as you can see, worth the effort!!! But that sheeting gets you a removable cowl for battery access and a great Mustang air scoop. I had to buy a piece of black and a piece of white Monokote trim sheet but the kit comes with 2 full sheets of very scale decals (mylar). Even has the decal for the wing camera and gas caps...
I fly it with either 8-1950 FAUP's or 10-CP1300's and get a very nice 8-10 minutes flying with the Astro 020. Probably my favorite of all planes that I've built so far. Really gets looks and comments at the field. Still needs the landing gear covers and dummy exhaust but I couldn't wait to get it in the air.
Very tough plane. Cartwheeled it on a glitchie takeoff (antenna tucked in the plane) - Duh. Busted a little of the of the left wingtip where in other planes a lighter crash broke the plane in half. Just took a little CA and a little more of the chrome Monokote which after a repair is invisible at the seams.
I'll post a few bones shots also.
Bill Germanson is offline Find More Posts by Bill Germanson
Old Dec 13, 2003, 09:19 PM
JAX, FL
Joined Feb 2002
Cowl open - uses a piece of wire and a ball-point pen spring. Works great.
Yea, I went a little overboard with the red paint but I didn't stop until you couldn't see anything but red through the front scoop.
BTW - The P-51 comes with engine mount firewalls for both the Astro 020 and the Speed 400/480 bolt size/pattern.
JAX, FL
Joined Feb 2002
Underside - Dual aileron servos
Old Dec 13, 2003, 09:21 PM
JAX, FL
Joined Feb 2002
Wing off - Access to the other two HS-55 servos and the receiver. Also note the laser cut holes in the cockpit florring to help with air movement. The floor is lite ply.
Old Dec 13, 2003, 09:25 PM
JAX, FL
Joined Feb 2002
Note the rivet details. Cool trick Don from HOB told me about. Use a material marking wheel that you (your wife) goes and gets from a sewing shop. Juse run it on the chrome Monokote to get the dents that look very scale.
Old Dec 13, 2003, 09:26 PM
JAX, FL
Joined Feb 2002
Diving in
Old Dec 13, 2003, 09:27 PM
JAX, FL
Joined Feb 2002
Front
JAX, FL
Joined Feb 2002
Side
Old Dec 13, 2003, 09:28 PM
JAX, FL
Joined Feb 2002
Da Mustang Scoop!!!
Old Dec 15, 2003, 09:50 AM
JLSalas is offline
Find More Posts by JLSalas
JLSalas's Avatar
Santiago Pudahuel, Chile
Joined May 2003
Nice plane!. Could you tell me what comes with the kit and what you had to supply?
thanks.
JL
JLSalas is offline Find More Posts by JLSalas
Old Dec 16, 2003, 07:46 PM
JAX, FL
Joined Feb 2002
JL, Although the kit has outstanding quality in the balsa, vac formed parts, hardware and mylar decals, it is still a standard kit that requires you to provide the stuff like the wheels, prop, motor, esc, 4 servos, batteries, 1.5 rolls of covering, glues and the pilot if you want one. The instruction manual has a detailed list of what's required including the specifics on the part numbers from Dubro and so on.
If you want the detailed part list I would be happy to get the instruction manual and post the list here.
This is a link to the pdf details on the kit. Just saw that HOB is working on an Edge 540. Can't wait!!!
Old Dec 17, 2003, 08:00 AM
JLSalas is offline
JLSalas's Avatar
Joined May 2003
I thought that. It would be great if you can post that list. This could help to know the final price of this kit.
thanks!!
JL
Old Dec 17, 2003, 08:28 AM
JAX, FL
Joined Feb 2002
I'll get the info posted tonight.
Old Dec 17, 2003, 08:47 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Looks great - I like the crome covering (except the weight!)
I have got to get one of these with a Mega 15/25/4 turn in it.....
Old Jan 05, 2004, 12:17 AM
Greenflight is offline
Find More Posts by Greenflight
near Twin Cities
Joined Jan 2004
Another HOB P-51
Just thought somebody might like to see another HOB p-51.
This one flies scale like with a speed 480 and an 8 cell NiMh pack.
Still books right along on those low passes and pulls up for nice turns. This is an older one from the 70's or 80's. Looks great in flight. Getting ready to try brushless motors and LIpoly's now.
Greenflight is offline Find More Posts by Greenflight
Discussion House of Balsa P-51 Mustang dmiller746 Electric Warbirds 75 Mar 17, 2011 04:26 PM
House of Balsa P-51 Mega Power! Slope Nut Scale Kit/Scratch Built 3 Aug 06, 2002 11:58 AM
Balsa P 51 Mustang dener77 Parkflyers 2 Apr 20, 2002 03:11 PM
house of balsa P-51 Conversion HELP ME! rjones Sport Planes 3 Jan 23, 2002 02:58 PM
house of balsa p-51 ? dwoel Sport Planes 8 Sep 30, 2001 01:39 AM
