Old Dec 10, 2012, 01:15 AM
The fish is offline
Find More Posts by The fish
Joined Aug 2012
OSD stuck on loading...
I have osdpro firmware version 2.70 + logger v4 and for some reason after I played with the eagleeyes settings with the data recorder software, the system wont boot by itself.
It will load only with the USB cable... But when I unplug the USA, and plug the battery, it get stuck on load. here's a screenshot:
The fish is offline Find More Posts by The fish
Old Dec 10, 2012, 08:39 PM
The fish is offline
Joined Aug 2012
any ideas?...
Old Dec 10, 2012, 09:37 PM
The fish is offline
Joined Aug 2012
OK. after resetting the OSD and recorded and re installing the latest update it's back to work.
Too bad that i need to run all safety wizard, inputs and other settings again...
Old Dec 12, 2012, 02:01 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, and sorry for the trouble. Based on your description, I think that somehow the eLogger's "capture rate" got set to a very slow value (maybe 1 sample/minute) and your reset cleared that up. If anyone else sees something similar, please click "Hardware, Set Recorder Capture Rate" and choose 10Hz as a first step.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Feb 02, 2013, 07:40 PM
Soyrico is offline
Find More Posts by Soyrico
Soyrico's Avatar
United States, CA, Hollister
Joined Jan 2006
Thank you Billpa for the info. I had the same exact issue with my new OSD replacement today and spent over an hour trying to figure this out without any luck. The steps you provided solved the the problem right away.
Soyrico is offline Find More Posts by Soyrico
Old Feb 04, 2013, 05:55 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Ah, that's great news!
Site Sponsor
Help! New Nine Eagles SP 228p stuck on full throttle eimer Beginner Training Area (Heli-Electric) 10 Oct 21, 2015 04:15 PM
Discussion ailerons - stuck on or cut out? stallion explosi Foamies (Scratchbuilt) 6 Sep 16, 2012 01:27 PM
Discussion Trim button stuck on DX6i marklind Beginner Training Area (Aircraft-Electric) 13 Jun 22, 2012 10:51 AM
Sold Dragon OSD+ v2 FULLY LOADED! ROD GARCIA FPV Equipment (FS/W) 2 Sep 25, 2011 04:49 PM
