Old Dec 09, 2012, 10:09 PM
gva1956 is offline
Find More Posts by gva1956
United States, WA, Goldendale
Joined Apr 2012
Broken steering bracket Eflite 10-15 retracts
I installed the Eflite 10-15 size retracts in a fellow flyers new Red White Habu. After just two flights, one retracted stopped working completely and when examining the nose wheel I saw that the rectangular bracket that the steering arm rides in was broken. Did I install it wrong? Any thoughts would be appreciated.
gva1956 is offline Find More Posts by gva1956
Old Dec 10, 2012, 10:51 AM
dreisinger is online now
Find More Posts by dreisinger
United States, PA, Carlisle
Joined Oct 2011
NWS Clevis
When I installed mine per the manual, there was considerable binding when the nosewheel was retracted. It actually made the steering servo rock in its pocket. So I looked at it again and decided that either I mis-interpreted the directions or the directions were wrong. I turned it 180 degrees and re-attached it and it worked a lot smoother. As others on the Habu forum suggested, I also separated the NWS servo from the rudder servo and used a separate receiver channel. It's now on a mix and only functions when the gear are down. I suggest doing this if you have any un-used channels on your receiver.
Hope this helps,
Dave
dreisinger is online now Find More Posts by dreisinger
Old Dec 10, 2012, 10:41 PM
gva1956 is offline
Joined Apr 2012
Nws servo
Just to make sure I understand. You removed the nws servo and rotated it 180 degrees so the arm is now towards the tail rather then towards the nose?
Sold Eflite 10/15 size retracts EFLG100 NIB 85. Shipped ryramZ Aircraft - Electric - Airplanes (FS/W) 2 Jun 21, 2012 06:04 PM
Wanted eFlite 10-15 Retracts Tricycle timlq Aircraft - General - Miscellaneous (FS/W) 0 Jun 21, 2012 01:16 PM
Found Eflite 10-15 Size Tricycle Electric Retracts MikePS Aircraft - General - Miscellaneous (FS/W) 0 May 31, 2012 08:55 AM
Found Eflite 10-15 retracts EFLG100 shunyata Aircraft - General - Miscellaneous (FS/W) 2 Mar 24, 2012 12:46 PM
Found Eflite 10-15 retracts EFLG100 shunyata Aircraft - General - Miscellaneous (FS/W) 0 Mar 23, 2012 10:20 PM
