Another Video-Li'l Satan with Tee Dee(& troubleshooting the TD)
For some reason up til now, I've posted my previous videos in the 1/2A section.
But here's my Li'l Satan I built a year or so ago. It's flown with a Black Widow, and an RR1. But I got tired of 90 second flights. Here it is with a Tee Dee .049 fed by a pressure bladder and bolted on with an aluminum backplate mount like the ones Texas Timers sells. It's on 40' lines. I guesstimated the speed with a 42'(including my arm) radius using the video timestamps of a few semi flat laps, starting around 2:15 or so and I figured just about 69mph. The engine stumbles a few times. This one has a quirky needle valve right now. Maybe the venturi needs opening up some more. It has a 5.5x3 Master Airscrew on it. Fullscreen is enabled
Looks like fun - makes me wish it was not cold and windy here for the next 4 or 5 months
![]() 5.5x3 is a bit too much prop, try to finds a 5x3. And MA are sort of "heavy", try an APC. We used to like Cox black nylon 5x3 on the TD, usually survived crashes. The Grey ones were too brittle. These might be the same ones, even though they say "Grey" they look like the flexible black ones. http://coxengines.ca/cox-.049-propeller-grey-5-x-3.html What fuel are you running? Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
These are the black ones at the same vendor:
http://coxengines.ca/cox-.049-propeller-5-x-3.html The only thing I don't like about them is they're hard to balance. The hubs are either lopsided or the holes are off-center. That's why I switched to MA. I'm using Glowplugboy 24% nitro. I add castor to bring it up to 20% oil so that drops the nitro a bit. All of my other Tee Dees and my 3 Big Migs run good with this fuel. The Satan is in the hangar now with a 5-1/4x3 MA awaiting the next flight. And I have a couple of 5x3s and a black Cox 5x4 in the flight box too. This engine has a funny crease in the crankcase. It was like this when I got it, and could be causing a friction problem..If it gives me any more trouble, I'll swap it with another Tee Dee that I know runs good.
If another prop doesn't make it happy, I'll swap the NVA from another plane and see what happens. |
