Old Dec 09, 2012, 06:38 PM
topforce is online now
Find More Posts by topforce
USA
Joined Feb 2002
Help!
kk2.0 recurring problem #1 esc pinout
I have been flying kk2.0 boards for a while now with great success. I have 1 board that I have had problems with. At first I thought it was a bad motor or esc when this board was built into a spider quad. Now, I think the #1 pinout mabey has a problem. The board is currently built into an HK 550 hex, using HK blue series 30A ESCs, and turnigy 2632 1000 kv motors. The programming is for hex + configuration. Seems #1 motor will spin up, but in trying to get off ground it slows down and eventually stops. When throttled back to zero and started up again, it starts fine, but in the tipping and sliding around of trying to lift off, it will again slow down and stop.
It did this before when on the quad but that was in a 4X configuration so #1 motor was offset front and right which made handling very adverse. Now motor #1 is straight front and its very sketchy.
I had read on the HK forums that it could be an esc non compatibility problem. In building this hex, I used 3x new ESCs and motors along with 3x used ESCs and motors from the previous quad build. The #1 position this time is a new set of esc and motor.
Anybody have similar problem and figured out how to overcome?
topforce is online now Find More Posts by topforce
Old Dec 10, 2012, 11:52 AM
USA
Joined Feb 2002
Btt
Old Dec 10, 2012, 06:00 PM
runout74 is offline
Find More Posts by runout74
Ocala, FL
Joined Jul 2004
I was having trouble with my KK2.0 after a crash. Before the crash it flew perfectly. After the crash I couldn't get it to fly stable. Reflashing the firmware fixed the issue. I know it doesn't sound logical but it can't hurt.
Runout74
runout74 is offline Find More Posts by runout74
Old Dec 10, 2012, 06:02 PM
runout74 is offline
Ocala, FL
Joined Jul 2004
Also, does this happen with a fully charged battery?
Runout74
Old Dec 10, 2012, 11:04 PM
USA
Joined Feb 2002
Seems to drop 1 or 2 esc after the battery has been run a few minutes. Suggesting that the ESCs are not behaving the same. However this board has never been flyable.
Going to switch out the board with a known good one today and see if anything changes.
Old Dec 11, 2012, 05:19 PM
Cyberdactyl is online now
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
I think my problem is similar
Cyberdactyl is online now Find More Posts by Cyberdactyl
Old Apr 30, 2013, 06:49 PM
Texacate is offline
Find More Posts by Texacate
United States, TX, Austin
Joined Aug 2012
I just received my Turnigy micro quad with the KK2.0 board from HbyKng. I see the exact same symptom on the right, front motor. It flies fine for 30 seconds, then that motor starts to slow. Luckily I've been only a foot or two above the ground when the quad starts to dive into the ground.
I will definitely check if that motor/esc is connected to the M1 pin of the KK2 board.
Has anyone found a solution or root cause? It's it the motor, the esc, the KK2, the KK2 settings?
My debug work is just beginning.
Texacate is offline Find More Posts by Texacate
Help! KK2.0 with DJI ESC'S possible ? advera Multirotor Electronics 25 May 09, 2015 02:50 PM
Discussion HK KK2.0 Auto Level Problems Or Setup Issues Fidy$Trainer Multirotor Talk 60 Mar 17, 2015 07:06 AM
Question Problem with KK2.0 Board in Self-level mode p.a.h. Multirotor Electronics 8 Dec 16, 2013 12:31 PM
Question Esc Positive Wires to KK2.0 Board CH33ZEBURG3R Multirotor Talk 9 Dec 16, 2012 01:33 AM
Help! KK2.0 Yaw Problem installerblizz Multirotor Talk 7 Nov 10, 2012 12:40 PM
