Old Dec 09, 2012, 04:14 PM
Crash?No testing the durabilty
fOaMmaSh87's Avatar
Australia, WA, Malebelling
Joined May 2012
Micro motor glider
Hello all I'm trying to get my dad into this awesome hobby so i got him to buy himself a micro boomerang but that was hard to fly (even for me) so I'm planing on making him a micro motor glider for Christmas using an AR6400 and champ motor
I was going to use the guillows "Sky Raider" hand launch glider for this. Tips,suggestions,help?
Cheers Ben
fOaMmaSh87 is offline Find More Posts by fOaMmaSh87
Old Dec 09, 2012, 08:19 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
2s and BL motor
nemoskull is offline Find More Posts by nemoskull
Old Dec 09, 2012, 09:02 PM
Gravity is a harsh mistress.
Tim Wolff's Avatar
Lambertville, Michigan, United States
Joined Sep 2002
Originally Posted by nemoskull View Post
2s and BL motor
And get video
Tim Wolff is offline Find More Posts by Tim Wolff
Old Dec 09, 2012, 10:07 PM
fOaMmaSh87's Avatar
Joined May 2012
Ok but i would like to keep it 1s for simplicy.
Old Dec 10, 2012, 02:15 AM
jimjim06's Avatar
Sweden, Västra Götaland, Partille
Joined May 2009
Heres a tip:
Guillows Skyraider foam glider RC conversion (2nd gen, build and maiden) (10 min 42 sec)
Looks fast!
Good luck.
Tommy
jimjim06 is offline Find More Posts by jimjim06
Old Dec 10, 2012, 05:10 AM
fOaMmaSh87's Avatar
Joined May 2012
Wow to fast for my dad to learn on but still cool.
Cheers Ben
Old Dec 10, 2012, 10:05 AM
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
The best plane to learn on in my opinion is the Champ from Horizon, and if you have a compatible, programmable tx program in 15% down elevator at full throttle, a bit of expo (I actually use a lot) and if you can program a throttle curve, program it so its relatively flat in the cruise range.
That's about the easiest flying plane I have though a case could be made that the Easy Star might be better for learning since it too is a gentle but responsive plane and it's almost impossible to break a prop which is not true of the Champ.
The J3 cub is hard for beginners since it will tip stall if you fly it too slow. Beginners wind up banging the stick from side to side when what they should do is give it throttle.
The Carbon Cub flies well in the hands of some, but the AS3X requires you to use both sticks in a turn. If you use just aileron and elevator the yaw gyro will try to fight the turn and it goes nose high, bewildering the inept.
Yeah, I love my Champ. I also love my MiG. It flies exactly where you point it but at the speed it goes you can't think about it too much.
Dumb advice since I don't know what you have to spend or what gear you normally fly with, but if I wanted to introduce someone to the hobby I'd get my Champ pretty high and after a bit of talk hand them the box and talk them through a few circles and maybe even a loop.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Latest blog entry: A WASP named Brownie
Old Dec 10, 2012, 12:42 PM
richos's Avatar
Joined Mar 2008
Ok then go to Hobbyking and get a Sky 500 Ultra Micro Glider 500mm (Bind and Fly) $38.00 take the RX out and replace with the AR6400 its almost a plug and play swap-out (easy) job done
http://www.hobbyking.com/hobbyking/s..._and_Fly_.html
And have a read over here.
http://www.rcgroups.com/forums/showthread.php?t=1515126
Nine Eagles SKY 500 (2 min 23 sec)
richos is offline Find More Posts by richos
Old Dec 10, 2012, 03:37 PM
nemoskull's Avatar
Joined Sep 2009
the champ is pretty hard to crash. its a nice easy setup.
edit: if your dead set in using the glider airframe, ttry this:
make the plane, then you fly it and try to crash it. seriously. i did this once on to a design i was working with, and after going 2 ch and larger wings with short throws on the rudder, i could never crash it. best i could do was force a hard landing. of couse this was in no wind
its best to assume a newbie will try to crash, they (we?) all fly like that!
Old Dec 11, 2012, 01:39 AM
fOaMmaSh87's Avatar
Joined May 2012
I almost got my dad a champ but decided on a micro boomerang because it would give me a new experience. He could almost fly it but it was not very stable or tough the motor mount broke
after the first 5 flights (and i dont trust him with my champ) so I thought this would be cheaper and hopefully get a nice motor glider for my to fly and him to learn on.
Old Dec 11, 2012, 07:23 PM
United States, NJ, Frenchtown
Joined Mar 2003
WOW
I want.
I do not share ?
My Dad ?
cyclops2 is offline Find More Posts by cyclops2
Old Dec 11, 2012, 07:24 PM
Joined Mar 2003
Epoxy glue is great stuff to bond a father & son together.
New Product Gravity Hobbies micro motor glider DX220 RicoSuave17 Indoor and Micro Models 537 Aug 23, 2012 09:45 AM
Help! micro cessna motor VS micro cub motor flyguy99 Indoor and Micro Models 1 Mar 26, 2012 01:03 PM
Sold Gravity Hobbies micro motor glider DX220 new in box edge_pilot Aircraft - Electric - Micro & Indoor Airplanes 5 Jan 30, 2011 09:33 AM
Build Log micro Virus motor glider derk Indoor and Micro Models 18 Aug 10, 2010 08:58 PM
Motor/prop/battery suggestions for powering micro SPAD glider? surfimp Power Systems 0 Dec 17, 2003 02:05 AM
