Old Dec 09, 2012, 02:45 PM
hobiej is offline
Find More Posts by hobiej
Canada, AB, Calgary
Joined Sep 2012
Extending wires
Hello Everyone!
I'm sure this has been asked, and I'm sure I've read this here someplace, but I've been searching all morning....
What wires are better to extend if I have to? The wires going to the speed controller, or the wires going to the motor, I've seen it done both ways (I Think), and just though I would ask the EXPERTS on this great forum!!
The setup I am referring to is a new build I'm working on, I just unpacked the new Turnigy H.A.L Hex (love it BTW) and thought about ESC placement. I saw in the HAL thread, a bunch of pics showing the ESC's mounted inside the dome with the wires extended from there, My issue with that is I feel there is not enough cooling for them???
So I want put mine on the arms and extend from my power board, the opposite way.
Is there and benefit to either way?
hobiej is offline Find More Posts by hobiej
Old Dec 09, 2012, 08:41 PM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Extending the wiring between the battery and ESCs is the way to go. No problem as long as the wire gauge is large enough.
Just as long as we aren't talking several feet.
2400RDR is offline Find More Posts by 2400RDR
Old Dec 09, 2012, 09:08 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
deleted
jabram is offline Find More Posts by jabram
Old Dec 09, 2012, 11:33 PM
hobiej is offline
Canada, AB, Calgary
Joined Sep 2012
Excellent!! Thank you so much. No, not feet, just a few inches... 6 maybe. just enough to go up the length of the arms.
Everything I have shows to be 16 gauge, I'm ordering 14 gauge to be sure.
Thanks again guys
Old Dec 09, 2012, 11:39 PM
hobiej is offline
Canada, AB, Calgary
Joined Sep 2012
Originally Posted by jabram View Post
I purchased a spare H.A.L quad bottom plate, I plan to mount the spare bottom plate spaced away from the existing bottom plate and mount the landing gear on it, ESC placed between the 2 bottom plates and are not covered by the dome. Purchased spare screw pack and some nylon spacers. That way the extended wiring from ESC to motor can go neatly inside the arms and airflow to ESC is not restricted by the dome.
You want the cable from Lipo to ESC as short as possible, You want that wiring and the whole power distribution to be as far away from the magnetometer as possible.
You do not want to mount the ESCs surrounding the FC inside the dome as a LOT of people seem to do. That is simply wrong.
Reasons; the wiring from Lipo to ESC carries heavy currents which creates strong varying magnetic fields and will be right under, very close to the magnetometer making the magnetometer/Compass useless AND WORSE if you fly headfree the frame will yaw violently when you apply throttle to lift off as the magnetometer is severely affected by the strong magentic field around the Lipo to ESC wiring right underneath it.
The ESC cannot really tolerate long wires to Lipo, the capacitor on ESC will get hotter, will fail sooner, generally you will have more electrical noise.
Aim for ALL of these;
Keeping Lipo to ESC wiring as far away as possible from Flight Controller magnetometer,
keeping Lipo to ESC wires as short as possible,
Extend the wires from ESC to motor
Do not restrict cooling airflow around ESC.
So even if I say mount them on the arms, just on the outside of the dome, thats better than having them right under the dome, with all the noise just bouncing around in there messing things up??
That way I wont have to extend the wires from the lipo, just going to the motors.
I like your idea of the extra plate for mounting things on.....
Old Dec 10, 2012, 12:16 AM
jabram is offline
Joined Jul 2012
deleted
Old Dec 10, 2012, 12:23 AM
jabram is offline
Joined Jul 2012
deleted
Old Dec 10, 2012, 08:40 PM
hobiej is offline
Canada, AB, Calgary
Joined Sep 2012
Ok, 16 gauge it is! No sense on the extra weight, Thanks for all the input guys
Old Dec 26, 2012, 11:52 AM
alfi666 is offline
Find More Posts by alfi666
Joined Nov 2012
Sorry, don't take it personally, but most of this is incorrect.. and anyone who know electronics will confirm...
Magnetic field is generated when current is being switched on/off thru wire - the wires from ESC to motor are the ones which are used for switching the power (only 2 wires from the 3 motor wires are used at once).
Therefore, those wires are the one which generates electro-magnetic field. If you make those wires longer, the bigger the field will be. Also long wires may attenuate the back EMF from motor to ESC (which is used for sensing the motor position) and it may cause misfires (cracking noise in motor).
The wires from ESC to battery are always at the same voltage and not being turned off. Only the current is changing, but the changes are not as fast - the capacitor at the ESC is supposed to help with that.
And the last point is the weight - mounting the ESC close to the motor you have to prolong only 2 wires and not 3. (+1 thin wire for signal)
alfi666 is offline Find More Posts by alfi666
Old Dec 26, 2012, 12:26 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Not quite right either! A magnetic field is generated when a current flows in a conductor, so that includes the DC current from the battery. You might be thinking of a varying magnetic field inducing a current in a conductor (as in a transformer secondary or a generator).
Depending on the magnetometer frequency response, the field from the DC supply may cause more problems than the rapidly varying field from the motor wires.
The consensus (based on recommendations from some manufacturers) seems to be that it's better to extend the ESC-to-motor wires rather than the ESC-to-battery wires... whether it really matters I don't know.
mattcro is offline Find More Posts by mattcro
Old Dec 26, 2012, 01:01 PM
jmkirsch is offline
Find More Posts by jmkirsch
United States, NY, Rochester
Already typed this up but mattcro beat me to it Anyway:
Per the right-hand rule it doesn't matter if the current is being switched. It will still generate a magnetic field. If the direction of current is changing, the magnetic field's poles will change. The direction of current from the ESC to the motor changes to make the motor turn, so the field would be constantly switching.
As such, both the wires from the battery to ESC, and the wires from the ESC to motor will generate a magnetic field. The higher the current, the stronger the magnetic field.
References:
http://en.wikipedia.org/wiki/Electromagnet
http://en.wikipedia.org/wiki/Brushle...electric_motor
jmkirsch is offline Find More Posts by jmkirsch
Old Dec 26, 2012, 03:07 PM
mattcro is offline
KK Tri Flyer
mattcro's Avatar
Joined Feb 2012
If you keep your battery negative and positive wires close together (parallel) and don't have any large loops, then the magnetic fields created by each wire will tend to cancel and shouldn't affect compass/magnetometer too much. Likewise, keep the 3 wires from ESC to motor bundled together and there will be less stray magnetic field.
Old Dec 26, 2012, 04:32 PM
alfi666 is offline
Joined Nov 2012
mattcro: you're right, I forgot about static magnetic field (which certainly is generated by DC flow) as a static magnetic field wouldn't cause any inducted electricity and shouldn't therefore create inducted noise... however the magnetic field will be still present and magnetometer will be either way affected...
So the only option is to keep the magnetometer far away...
Old Jan 13, 2013, 03:18 PM
jabram is offline
Joined Jul 2012
deleted
Old Jan 13, 2013, 08:42 PM
Mochaboy is online now
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
If you want to increase the potential for ripple currents then by all means go ahead.
+1 for lengthening the wires from the esc to the *motors
Mochaboy is online now Find More Posts by Mochaboy
Found 16 AWG Turnigy(or alike) wire for extending escs acuralegendz Aircraft - Electric - Multirotor (FS/W) 13 Nov 16, 2012 11:43 AM
hello i trade 5 18" long sovro wire extender Xfox Non R/C Items (FS/W) 0 Nov 02, 2012 01:37 AM
Discussion Can I extend the control wire on my cc160hv? hidaven Power Systems 6 Oct 07, 2012 05:30 PM
Discussion What is the right wire for extending ESC wires to motors? armanm Multirotor Electronics 3 Sep 01, 2012 10:13 AM
Cool What to extend? Motor wires or Battery wires? L0stS0ul Castle Creations 16 Sep 18, 2006 03:39 PM
