Old Dec 09, 2012, 01:42 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
9104/9117 similarities/differences
OK, I've got this new Double Horse 9117 I just opened, and it's next to my D.H. 9104, and apart from the obvious operating systems, there are similarities, and there are differences too. Biggest difference is the swashplate, the 9104's is smaller, this would most likely explain why I keep getting separation with the 9104's swashplate with a 4 channel conversion, swash arms on the 9117 are MUCH longer, allowing more movement that the 3 channel swash. Apart from a few cosmetic differences, it appears a lot of parts are interchangeable between the 2, canopies are pretty much identical, mechanical things could be swapped (if needed) blades, etc. I have these much larger output brushed motors that were bastardized from a no-good R.C. boat that actually look like they might fit (more to come on that), but I guess if you have this 9117, and you've also got one or two 9104 sitting around, you'd have some parts for the 4 channel bird...at least mechanically...
matiac is offline Find More Posts by matiac
Old Jan 02, 2013, 05:37 PM
timg734 is offline
Find More Posts by timg734
Joined Dec 2012
can a person take the 9117 4 channel parts and install them on a 9104 to make it a 4 channel?i really would like to change my 9104 over and see how it flys
timg734 is offline Find More Posts by timg734
Question Differences Between Two Double Horses 9100 & 9104 msd58 Mini Helis 4 May 30, 2012 09:16 PM
Discussion Can different Brands of ESCs give different results on similar settings? fooyukvoon Power Systems 10 Jan 14, 2012 08:00 PM
Discussion 3 different motors, too similar to be different sgomes Power Systems 1 Jun 21, 2011 07:06 PM
Discussion Difference between similar sized electric and glow models super_nova 3D Flying 3 Dec 05, 2006 03:29 PM
Discussion Salvaging cells from different but similar packs Tom Frank Batteries and Chargers 21 Oct 07, 2006 01:46 PM
