Old Dec 09, 2012, 12:04 PM
BigD1961 is offline
Find More Posts by BigD1961
Team OFG (Old Fat Guys)
BigD1961's Avatar
United States, KY, Leitchfield
Joined Jul 2008
Magnum Reloaded kit.
Check out the thread over in scratchbuilt foamies for some information on the kit offered by WM Park Flyers.
http://www.rcgroups.com/forums/showt...0#post23482632
BigD1961 is offline Find More Posts by BigD1961
Old Jan 23, 2013, 06:54 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
I couldn't resist and ordered the kit and floats. I have all of the foam parts glued together. I used both Foam Tac and hot glue. You have to work with the wing tips to get them on correctly and hot glue worked best for those.
One thing I noticed with my floats is that one of the 4 side covers was 3mm thicker than the other three, and was smooth with mold dimples on it. Apparently they forgot to hot wire that side. I trimmed it down on my band saw so no biggie.
One thing I wasn't thrilled with was the texture of the foam. It is not smooth and almost has a texture like a corn cob. I inquired about sanding it down and it was suggested that I not do that as the foam had been hot wire trimmed which created a skin that aides in the foam strength. Oh well, as long as it flys well. I got the blue fuse and yellow wings. The colors do look nice and are very bright.
Even though this is a pretty simple build I did have a few questions that the instructions did not answer. The German to English translated instructions are pretty poor.
There is a cutout above the wing to place the 5g servos. I had to cut it deeper to fit my Hextronic servos in. Other than the servo location there are no recommendations in the instructions on where to place anything else.
The kit comes with "wicking" type CA hinges. I was originally going to use Blenderm tape hinges but the tape would not stick to the foam so I used the CA hinges. WMParkflyers recommends doing Foam Tac hinging. When beveling the control surfaces for hinging be sure to use a new blade as the spongy foam does not trim easily. Also do not trim edge super thin as small chunks will come out and make Foam Tac hinging more difficult.
I am waiting on a smaller Rx before proceeding with electronics installation. I hate to see stuff hanging on the sides so will explore how to hide the stuff.
Overall I am pleased with the kit and am guessing that it is going to be very durable.
Rickochet is offline Find More Posts by Rickochet
Old Jan 25, 2013, 03:31 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Rickochet View Post
One thing I wasn't thrilled with was the texture of the foam. It is not smooth and almost has a texture like a corn cob. ...
The texture is normal for EPP.
Jürgen
P.S.: I like your US ARMY style decor.
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 25, 2013, 04:43 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Jürgen
Thank you. Whenever I get a blue and yellow aircraft I always like to put that decor on it.
This is my first experience with EPP. I do have several Elapor Multiplex aircraft and the texture of the MR is nothing like the elapors I have. One of the side panels for the floats had not been hot wire trimmed and was three mm wider than the other three. It stil had the mold dimples like the Multiplex aircraft. I trimmed it down on my band saw and it came out super smooth, much unlike the hot wired surfaces of the MR. So, I don't think that it is the EPP itself rather a result of the hot wiring. Here are some pics of the piece of the float I trimmed off showing both sides. I also noticed that the external side of the piece is much brighter than the inner trimmed side. I wonder if the outer sides have been painted and the surface is the result of a reaction with a paint?
Old Jan 26, 2013, 03:17 PM
Joined Sep 2000
This is my first experience with EPP. I do have several Elapor Multiplex aircraft and the texture of the MR is nothing like the elapors I have. ...
Elapor is much different from EPP, especially as it is molded, rather than cut from a block.
The surface of your sample looks rather rough however. It should be a bit smoother. No paint is used in the process. The hot wire cutting emphasizes the color of the foam.
Jürgen
Old Jan 27, 2013, 08:53 AM
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Need CG Help
The instructions for CG say "65mm - 75mm from nose of stick."
I measurement from the wing leading edge would be more informative.
Help.
Old May 13, 2013, 07:01 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
We took one on holiday to the RC Hotel in Corfu for a little poolside action. Wonderful little plane and so relaxing.
Magnum Corfu (3 min 42 sec)
wildpalms is offline Find More Posts by wildpalms
Old May 27, 2013, 07:34 AM
VinceHaworth is offline
Find More Posts by VinceHaworth
VinceHaworth's Avatar
United Kingdom, England, Lancs
Joined Apr 2005
I saw that video and I just had to buy the Magnum! Got it from RobotBirds (UK shop).
Put the kit together and setup with my new Jeti DS-16. This will be great for indoor meetings as well as summer evenings.
VinceHaworth is offline Find More Posts by VinceHaworth
Old Jul 18, 2015, 02:50 AM
KristofferR is online now
Find More Posts by KristofferR
United States, CA, Redondo Beach
Joined May 2015
I got my Magnum built up from a Miniprop kit and put some hours on it.
It flies best with low weight; mine has flown with 2s 350 to 3S 900 and a Mobius on it. 300g or below IMHO.
I broke the wing near the fuselage several times due to hard "landings". The design with the landing gear puts strain on the wing. After glueing a carbon piece (included and recommended for crazy manouvres) and smearing UHU Por on the wing it has held up.
The Magnum is best for "flying around" in a relaxed style but encourages to try all kinds of crazy things. It starts from my porch. It can fly limbo under trees. Or just fly with the wheels touching long grass.
The 2S 350 and 500 are rated 25C. They only take full throttle for some seconds then the speed drops.
It's a super plane for flying in the evening when the wind has died. Five minutes is enough to stop a flying itch!
Magnum Reloaded RC plane by Miniprop with Mobius camera (3 min 10 sec)
I broke many props despite a propsaver. The GWS seems brittle. Not a problem except having to ream and balance the new ones.
KristofferR is online now Find More Posts by KristofferR
Old Aug 26, 2015, 04:41 AM
WMParkFlyer is offline
Find More Posts by WMParkFlyer
WMParkFlyer's Avatar
Jenison
Joined Nov 2009
Magnum reloaded - Das Original von Martin Müller - optionale Schwimmer. (6 min 10 sec)
Magnum Reloaded is back in stock
Www.wmparkflyers.com
WMParkFlyer is offline Find More Posts by WMParkFlyer
Old Nov 06, 2015, 04:45 PM
Joined May 2015
Magnum in a puddle :
Magnum Reloaded Miniprop on floats, schwimmerbausatz! (1 min 33 sec)
Old Nov 06, 2015, 04:59 PM
Krumpel is offline
Find More Posts by Krumpel
Crash tests done dirt cheap!
Krumpel's Avatar
United States, WV, Lewisburg
Joined Feb 2014
Had the Magnum out yesterday. I forgot how much fun this thing is to fly. Went through 4 batteries, the best was late in the day when the wind died down.
The BEST slow-flier yet, and almost indestructible.
My $0.02 worth. YMMV...
Krumpel is offline Find More Posts by Krumpel
Old Mar 15, 2016, 08:37 AM
JREEVES is offline
Find More Posts by JREEVES
Wayward Pilot
JREEVES's Avatar
USA, FL, New Port Richey
Joined Sep 2001
I'm in the process of building my Magnum, which arrived really fast, thanks Greg!
I've watched the vimeo build video a couple of timesand am wondering how you determined how much right thrust angle to put in? I see you just took a thin strip of off cut foam and stuck it in. Is it that easy?
I will be flying off grass and water, can I just glue on the floats or will I need wheels?
JREEVES is offline Find More Posts by JREEVES
Discussion magnum reloaded epp fun plane Flymax12 Waterplanes 33 Feb 15, 2016 08:59 PM
Discussion Magnum reloaded build instructions lotsofcats Foamies (Scratchbuilt) 1 Jul 21, 2012 11:56 AM
Discussion Magnum Reloaded BigD1961 Foamies (Scratchbuilt) 36 Feb 26, 2012 07:21 PM
