Espritmodel.com Heli Air
Old Jan 24, 2013, 06:20 PM
Hmm ... Smoke is bad, right?
Obake's Avatar
United States, VA, Waynesboro
Joined Dec 2005
Jon,
Where is the CoG on the plane? Perhaps leaving the top wing solid instead of 'holey' would help with keeping some weight forward?
I thnk it would be better to stay with the original tail setup and add weight to the nose. Some planes and some designes just seem to require that to happen. Cutting, skimping or changing a design just to avoid a few grams is not always wise.
Obake is offline Find More Posts by Obake
Old Jan 25, 2013, 01:22 AM
UAS Pilot/Tech Instructor
CryHavoc's Avatar
San Diego, California, United States
Joined Apr 2000
As this is the prototype, now is the time to make changes so I think lightening the tail is on the right track. Besides, anything you can do to lighten and reduce drag on a bipe is only a positive, especially at the small margins of error for a micro.
And..... the thinner tail surfaces just look right to boot.
CryHavoc is offline Find More Posts by CryHavoc
Old Jan 25, 2013, 02:45 AM
Microaces Wingman
deadbird's Avatar
UK. Dorset
Joined Jun 2009
Originally Posted by Obake View Post
Jon,
The COG is slightly forward of half way on the upper wing. Because of the aesthetic improvement on the tail I'm going to try it out first to see how she behaves in the air. We always have the fall back position.
I can't think it would cause any major problems but you never know unless you prototype! It also makes the build a little different and more interesting too I think. Hmmmmm - we'll have to see. Maybe a test flight this weekend.
deadbird is offline Find More Posts by deadbird
Old Jan 25, 2013, 04:36 AM
Gulf Breeze, FL
Joined Jul 2006
Deleted
speedy01 is offline Find More Posts by speedy01
Old Jan 25, 2013, 05:23 AM
Gulf Breeze, FL
Joined Jul 2006
Now there's an interesting, often discussed subject - determining the Center of Gravity for biplanes! RCGroups details everything from using the "shadow method" to using the attached. Those discussions often include settings for the incidence of top and bottom wings (decalage), as well as for the horizontal stab ... which leads to Center of Gravity versus Center of Lift discussions .. which leads to dihedral discussions, etc, etc.
My friend Pete (mtflyr) who can make anything fly, including his many small WWI bipes, uses the following scientific method: tosses the model onto his well padded bed, adjusting components (mainly battery) until he gets a good glide. Further adjustments are made after flying.
What method are you using, Jon?
Gene K
Old Jan 25, 2013, 08:30 AM
Microaces Wingman
deadbird's Avatar
UK. Dorset
Joined Jun 2009
I'm using the 'SAS' method Gene - Suck it And See!
Not having designed a biplane before I went off around the threads & looked at various CoG methods. I established from this that it should be somewhere slightly forward of the centre of the upper wing chord.
On the first build it turned out that the balance point was slightly behind the centre of the chord so I was prepared for a tail heavy aircraft on the maiden.
The first flight confirmed this as it took off after about a foot of runway. After wrestling it down gently I then start adding ballast until it flew right.
Because these aircraft are fairly tough I'm not too concerned about 'hard landings' due to instability so it give me every opportunity to employ the SAS method!
Jon
Old Jan 25, 2013, 08:52 AM
Gulf Breeze, FL
Joined Jul 2006
... the 'SAS' method - Suck it And See!
Must be an English expression.
Gene K
Old Jan 25, 2013, 08:58 AM
Microaces Wingman
deadbird's Avatar
UK. Dorset
Joined Jun 2009
One of those phrases you grow up with, but nobody else knows what the hell you're going on about.
It made it into the Cambridge on-line dictionary though
Old Jan 25, 2013, 06:21 PM
Obake's Avatar
Joined Dec 2005
Old Jan 25, 2013, 07:17 PM
Gulf Breeze, FL
Joined Jul 2006
I shall endeavour to never post again in this thread.
No, please continue to contribute. The expression of my opinions was over the top, and I apologize.
Gene K
Old Jan 26, 2013, 01:50 PM
Microaces Wingman
deadbird's Avatar
UK. Dorset
Joined Jun 2009
Well I'm not going to be doing any test flying this weekend on the Hawk as the wind has whipped up and we are forecast gales tomorrow.
I've also had a bit of an artistic block with the fuselage illustration. Stupid really but its a case of loosing the knack of it temporarily. Usually a good indicator that I'm knackered! Need to take a day off and go blow the cobwebs away I think.
Old Jan 31, 2013, 03:04 PM
MICROACES's Avatar
Joined Sep 2012
400mAh 1s 30C Lipo samples arrived this week.
They are a good fit in the larger cavity of the P-6E and will mean, if used, the majority of the additional ballast in the nose can go and the flight times should be as leisurely as the aircraft is to fly.
All I have to do now is wait for the wind to die down.
MICROACES is offline Find More Posts by MICROACES
Site Sponsor
Latest blog entry: Social Media
Old Jan 31, 2013, 04:17 PM
Chrizz
Chrizz's Avatar
Belgique, Bruxelles, Woluwe-St.-Lambert
Joined Nov 2009
Hmmm! Looks good! ...All I need now is a budget... of any kind :-)
Chrizz is offline Find More Posts by Chrizz
Old Feb 03, 2013, 02:32 PM
Joined Nov 2012
Aircraft Markings and Pilot
Change of subject back to the topic of aircraft markings and pilots. Here's what the US Air Force Museum website says about the aircraft they have on display:
The only original P-6E still in existence, this P-6E appears in the colors and markings of the airplane assigned to Capt. Ross G. Hoyt, Commanding Officer of the 17th Pursuit Squadron, 1st Pursuit Group, based at Selfridge Field, Mich. in 1933. Edward S. Perkins of Anniston, Ala., donated it to the museum, and the Department of Aviation Technology at Purdue University restored it in 1963.
And here's a link to this info:
http://www.nationalmuseum.af.mil/fac...eet.asp?id=337
Finally, here's a link to my favorite photo of the P-6E in flight:
http://www.nationalmuseum.af.mil/sha...-1234P-022.jpg
Enjoy!
--Hatman
Hatman is offline Find More Posts by Hatman
Old Feb 07, 2013, 02:52 PM
MICROACES's Avatar
Joined Sep 2012
Enjoy!
--Hatman
I think Captain Hoyt will have to grace the Hawk with his presence in the cockpit. He certainly cuts a dash with his fine facial whiskers! Thank you for the further research Hatman.
I have finally managed to find some time & inspiration to continue the fuselage illustration. It is proving to be a really slow render but the detail is so wonderful, what with zip fastners, buckles and even a combination lock. The illustration below still needs a lot of work in the light & shade department.
Jon
Site Sponsor
For Sale Royal Curtiss P-6E (Hawk) Kit rcrube Aircraft - Fuel - Airplanes (FS/W) 0 Sep 30, 2012 05:49 PM
For Sale Royal Curtiss P-6e Hawk Plans ama-hobby Aircraft - Fuel - Airplanes (FS/W) 0 Mar 21, 2006 06:45 PM
For Sale Royal Curtiss P-6e Hawk Plans ama-hobby Aircraft - Fuel - Airplanes (FS/W) 0 Feb 21, 2006 06:40 AM
Curtiss P-6E Hawk plans needed sgtdirt Free Flight 6 May 20, 2005 05:38 AM
Curtiss P-6E Hawk Gordon Scale Electric Planes 8 Dec 10, 2002 09:13 AM
