Old Dec 09, 2012, 05:49 AM
darynxbcoupe is offline
Find More Posts by darynxbcoupe
Joined Sep 2010
Question
digital servo
Hi all was wondering if you can use a hitec 5755hs digital servo for a sail winch and what drum would fit ? has anyone had any experience with doing this ?
darynxbcoupe is offline Find More Posts by darynxbcoupe
Old Dec 09, 2012, 08:36 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
If it's a lot like this - http://www.servocity.com/html/hs-5755mg_servo.html
it wouldn't use a drum. Just fit an extension to the horn supplied to make it the right length to give the throw required.
Is there a pressing need for a digital servo as opposed to a normal heavy duty one?
mfr02 is offline Find More Posts by mfr02
Old Dec 09, 2012, 08:38 AM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
That servo would normally be used as an arm winch, programmed for 180 degrees rotation. It can be modified for continuous rotation and a drum added, but why do that extra work?
The drum dia will depend upon the length of sheet line that you need to move, and the number of turns you want, More turns allows a smaller drum and more torque, but increases travel time.
Note that the servo uses the large 'D' size spline.
You can calculate the length of main sheet to be moved by the winch. Assume that the boom going from close hauled to full out to the shrouds, creates a 90 degree angle, then the length of the sheet line is the hypotenuse, and the base and side are the distance from the goose neck to the main boom attachment point - call it L.
the diameter of the drum is square root of (L squared*2) divided by Pi- divided by number of revolutions desired.
For example, Gooseneck to main sheet attach point L = 200mm, Three revolutions required
L squared (200*200) = 40000 times 2 = 80000
Length of main sheet movement is Sq root of 80000 = 282.8mm
Divide by 3.14 =90
Divide by 3 revolutions = 30mm
So the diameter of the drum is 30mm
John
hiljoball is online now Find More Posts by hiljoball
Old Dec 09, 2012, 03:11 PM
Joined Sep 2010
sounds very complicated
Old Dec 09, 2012, 05:31 PM
ggrrr is online now
Find More Posts by ggrrr
New Zealand, Northland, Kerikeri
Joined May 2011
Have a look at the" Drum for Hitec Sail Servo 67F" by Sailsetc
ggrrr is online now Find More Posts by ggrrr
Old Dec 10, 2012, 02:54 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
If it was simple, everybody would have one.
Old Dec 10, 2012, 08:26 AM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
I have a HS-5755 in an IOM, as a sailwinch. It is not a drum, but an arm about 2.75" long. It works fine. Let me know if you want photos
hew565 is offline Find More Posts by hew565
Old Dec 10, 2012, 03:10 PM
Joined Sep 2010
thanks but i dont have the room i think i might get a rmg thanks all
Old Dec 10, 2012, 03:39 PM
mrpenguin is offline
Find More Posts by mrpenguin
Australia, TAS, Penguin
Joined Mar 2012
RMG sailwinch is bulky, heavy and expensive if that matters.
It is also FAST and STRONG - watch you dont fold the boat in half.....
mrpenguin is offline Find More Posts by mrpenguin
Old Dec 11, 2012, 12:18 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Wrong quote
8387mike is offline Find More Posts by 8387mike
Old Dec 11, 2012, 12:19 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Darryn,
Whats the winch going into?
Old Dec 11, 2012, 01:11 AM
Joined Sep 2010
Originally Posted by 8387mike View Post
Darryn,
A tri i just built i had a cheap one from hk it worked great till the other day it just stopped working and i have read that they dont last
Old Dec 11, 2012, 12:12 PM
northernmike is offline
Find More Posts by northernmike
Joined May 2011
Is that a water bottle on top?
northernmike is offline Find More Posts by northernmike
Old Dec 11, 2012, 03:29 PM
Joined Sep 2010
yep so when it tips it doesnt go right over in the process of making something nicer
Sold Hyperion Digital DS-12 Digital Servos QuietRCFly Aircraft - General - Radio Equipment (FS/W) 4 Sep 16, 2012 07:31 PM
Sold 3 Hitec Digital 5065MG cyclic servos, 1 5084MG Digital tail servo Price reduced Sky_Dancer Aircraft - General - Radio Equipment (FS/W) 2 May 19, 2012 11:17 AM
Sold Hitec Digital 5065MG cyclic servos, 5084MG Digital tail servo Sky_Dancer Aircraft - Electric - Helis (FS/W) 1 May 18, 2012 03:04 PM
Discussion Servo Glitching Corona 919mg digital servo mick3485 Radios 5 Mar 21, 2012 03:04 PM
Sold Digital Servos (Metal Gear Micro Servo) ShokWaveRider Aircraft - General - Radio Equipment (FS/W) 2 Mar 18, 2012 02:49 PM
