Old Dec 08, 2012, 07:04 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
OSD resets
Hi,
I have the V4 logger and OSD pro installed on my Grim Reaper wing. For some reason when I throttle up on take off, and occasionally even with the ESC "bleeps" to indicate 'armed,' the OSD reboots. It cant be a loose wire because it has done this on the ground with no movement. And I've wiggled all the wires and boards and cant manually reproduce it.
The elogger connects to the battery directly and have regulators on the 'output' side for electronics. My camera doesnt glitch when this happens, so I doubt its actually losing power. I dont have RTH setup yet, so there are no other wires going to the OSD other than the GPS. This glitch does not happen in the air with the motor is turning, even if I go to idle (I dont have brake enabled, so the prop windmills).
Its some kind of feedback, but I dont know how that would affect the elogger. Nor do I know how to stop it. I"m using a CC50 btw.
Aazam
ashdec87 is offline Find More Posts by ashdec87
Old Dec 12, 2012, 01:44 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, and sorry for delay in getting back to you (bad cold).
The fact that it happens only on take off throttle up, and not in the air, suggests that it's either a brownout situation, or a LOT of noise is getting into the OSD (though I would be surprised if the latter could cause a reboot). The ESC can work much harder during launch than otherwise.
Can you confirm you have good ground connection between the camera, the video transmitter, and the OSD? ground wires from both camera and VTx need to be connected to the OSD.
When the OSD reboots, does anything look differently on the screen than when you do a normal boot (when power is applied)?
It might be good to post a quick sketch of your wiring diagram if nothing else helps.
billpa is offline Find More Posts by billpa
Site Sponsor
Discussion CL-OSD a open source osd software for E-OSD and G-OSD callelj FPV Equipment 4153 Yesterday 10:56 AM
Discussion any way to reset alt on a osd? smitty919 FPV Talk 4 May 14, 2012 10:19 PM
Discussion CAM Motor Reset dharban Electric Competition Soaring-F5J/ALES/e-Soaring 15 Mar 03, 2012 06:12 PM
Discussion OSD resetting in flight Gunnycig FPV Talk 0 May 17, 2011 12:12 AM
Discussion Gyro...to reset or not to reset...that is the question???? CSI Electric Heli Talk 5 Aug 26, 2010 03:16 AM
