Lets just say I have a Bird in mind and it Ain't an airliner!
Latest blog entry: Joe Nall 2013!
, but I will be building two. I've come up with a formula that should go well over 200 Miles per hour only question is will I be able to fly her visually or have to go FVP?So the rules are No rockets, No air or drop launch, And she must take-off & land under the power of electric 70mm fans only, . . . .O.K. and away I go Drawing up plans tonight on "Project-Superbird" Meep-Meep!
Just to give the non-readers something to look at.... Here`s a basic side view of my 35mm. If you print it out and enlarge it so that the fan housing area is about 78mm (large enough to hold a 70mm fan) it should be large enough to hold what you need to go 70mm.
I`m actually working on a fuselage that`s a little slicker for my 70mm, but the basic layout of fan and flying surfaces won`t change much. |
Latest blog entry: EDF, My First Six Years, mostly Pictures
The only addition to the rules would be a technical one stating the guidelines mirror the AMA flight rules of no pyrotechnics/rockets or sparklers!
Bungee? Heres one for you all! So an older guy is helping a younger fellow with a 40mm F-18, he's got the bungee stretched out to about 50lbs of tension and lets go. The little jet probably did 200 mph for 20 feet then disintegrated! Watch you bungee tension! New question to the masses: Would you all be opposed to allowing Twin 70mm to the Speed Chalange? We all know the difference and at the same time who cares? Its about going past 200 mph! A single fan would have just as many bragging rights and recognition as a twin fan, while the challanges are totally different electrically and wing loading. Keep em comming! |
| Thread Tools | |
| Discussion Speed contest 70mm/ 90mm EDFs | Rocketboy1030 | Scratchbuilt EDFs | 66 | Feb 12, 2013 05:29 PM |
| Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor | Dave Barrow | Aircraft - Electric - Jets (FS/W) | 0 | Aug 10, 2012 07:58 PM |
| New Product E-flite Hawk 70mm Class EDF w/ Fiberglass Fuselage | Bajora | Electric Ducted Fan Jet Talk | 263 | Feb 21, 2010 04:54 AM |
| Question 70mm class EDF rotor weight? | FNFAL | Electric Ducted Fan Jet Talk | 0 | Sep 23, 2009 11:32 AM |
