Old Dec 08, 2012, 06:50 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Contest
'70mm class EDF Speed Cup Challenge'
A speed competition with no airframe restrictions
Rule #1: Anything goes in an attempt to make your EDF Jet go 200 mph.
Modified stock airframe or one design scratch built airframe, refer to rule #1
Landing gear or belly slider, refer to rule #1
If you guys want to ad twins possibly as another class to the 70mm then lets do it
Prefer the airframe be carefully built as best possible by the builder to withstand the forces and pressure at triple digit speeds, motor torque and battery weight.
Multiple attempts allowed as well as multiple airframes.
Speed video should be clean and free of talk and IC noise as possible.
.wav sound file would be extracted of best passes left and right for averaging speed. Temperature is needed for the flight day.
Speed to be determined by a Wavoscope Doppler type program. By myself and or seconded by others for consensual assessment and agreement of speed. (to those concerned as to any qualifications to Doppler a video by me, not to worry, I have the time and a firm unbiased opinion of performing the duties with diligence and have been an AMA member for a very long time)
Leader board as of 2-26-2014
1st NEW RECORD!!! avg is 189.6mph for the Ergo jet of ApexAero 3-1-14
2nd Place is Team HabuBurners with avg speed of 186mph
3rd Place fh64_Lucky with avg speed of 185mph
4th
5th
ApexAero is offline Find More Posts by ApexAero
Last edited by ApexAero; Mar 03, 2014 at 05:42 AM. Reason: Thanks to JC and Gary's gentle nudge
Old Dec 08, 2012, 07:14 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I would think anything in the 200-299mph would qualify in the 200mph Cup Challenge....right......its when you go over 300mph that you are disqualified
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 08, 2012, 07:16 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
BuuuYaaa, baby! I`m ready to cut some balsa.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Dec 08, 2012, 07:17 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Good point, I`ll look into an rpm limiter so that I don`t break out.
Old Dec 08, 2012, 07:20 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
I just finagled a 160hv today for a secrete project
Old Dec 08, 2012, 07:22 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Yep all those 300mph 70mm jets need to go somewhere else. Don't even bother here! We're a classy bunch with no tolerance for crazies.
This is exciting! What a way for me to break into EDF's
I'm all in.
Thanks for heading this up, ApexAero!
murdnunoc is offline Find More Posts by murdnunoc
Old Dec 08, 2012, 07:25 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
I just did something to my 160HV today that started with an F. But it wasn't finagled.
Digging it out of the Spear now to see if I can figure out what caused it, but hopes aren't high.
It wasn't running even close to out of spec (122A) so I'm thinking my as-yet untarnished soldering has been the culprit, as I resoldered new motor leads to the board. We shall see...
Edit: Well, it's a little bigger mystery than that. This wasn't the one I resoldered.
But there is nasty gunk spattered all on the inside of the ESC, so something went wrong... will let Castle figure it out.
But at least my soldering reputation stays intact!
Old Dec 08, 2012, 08:53 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
I suggest someone mounting a high efflux speed fan in a pod on top of an electric pylon racer like the Viper, Jibe, or Swist. Those airframes are incredibly efficient.
Double E is offline Find More Posts by Double E
Old Dec 08, 2012, 11:29 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
[QUOTE=ApexAero;23477686Speed video should be clean and free of talk and IC noise as possible.
.wav sound file would be extracted of best passes left and right for averaging speed. [I]Temperature is needed for the flight day.[/I] [/QUOTE/]
The ambient temperature..... at the time of flight..... at the flight location needs to be recorded. Not high temp for the day
Higher temps increase the doppler analysis speed result.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 08, 2012, 11:33 PM
capt soap is online now
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Good, he didnt say anything about rocket assited 70mm .
capt soap is online now Find More Posts by capt soap
Old Dec 09, 2012, 12:46 AM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Capt, the sparks denote its location like a marker flare upon crashing!
Old Dec 09, 2012, 12:59 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
so, should we have a thermometer present for our speed runs, that is clearly a part of the video and should be clearly seen on the shot just before the flight? is that fair? sounds like it to me, so that someone can't gain an advantage by giving an incorrect temp.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 09, 2012, 01:07 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
What if your field is in the sun?
Have to go with a weather report from a reputable source then.
Old Dec 09, 2012, 01:38 AM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
I have a weather app keyed to my local area on the phone, the temp is usually from the airport. The phone's gps doesn't have the temp data. Before I got the phone there were friends that always had one.
Old Dec 09, 2012, 02:28 AM
Joined Jan 2009
my point is that I could say anything I like, knowing it'll change the outcome of the test. so shouldn't we somehow have to provide an accurate way of showing the temp at the time of the flight. just figured having a thermometer might be easier for some folks. if the sun is out, then obviously it's gonna affect the reading, but if you take it in the shade, it's gonna be a bit more accurate than in direct sunlight. I'm not suggesting that it's the best solution, just suggesting that there be a solution that is best for everyone that is also accurate for testing purposes.
Discussion Speed contest 70mm/ 90mm EDFs Rocketboy1030 Scratchbuilt EDFs 66 Feb 12, 2013 05:29 PM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
New Product E-flite Hawk 70mm Class EDF w/ Fiberglass Fuselage Bajora Electric Ducted Fan Jet Talk 263 Feb 21, 2010 04:54 AM
Question 70mm class EDF rotor weight? FNFAL Electric Ducted Fan Jet Talk 0 Sep 23, 2009 11:32 AM
