Old Dec 08, 2012, 05:30 PM
chip22 is offline
Find More Posts by chip22
Joined Dec 2012
Recommend best quadcopter in price up to $100.
Hi guys,
Help me to choose best quadcopter (stable,responsible,good flying range) in price up to $100(RTF?) ?
Or maybe i can build better quadcopter myself using $100 for electronics (motors,ESC's,props,battery) and board,is it possible?I have radio system.
Thanks.
chip22 is offline Find More Posts by chip22
Old Dec 08, 2012, 06:28 PM
vartaz is offline
Find More Posts by vartaz
Denmark, Central Denmark Region, Karup
Joined Aug 2012
The cheapest and best would be in my oppinion to build one your self. You dont specify what size but my best bet would be get these items from hobbyking
Q450 frame 15
NTM prop drive 2826 1200kv 15 x 4 = 60
Turnigy plush 25a esc 15 x 4 = 60
KK 2.0 flight controller 20
Some power board or make your own using a wire harness.
9x6 or similar props.
Some battery 3s 22 - 3200 mah
A little above the 100 loft but you can check it yourself www.hobbyking.com
I have built my own quad using these items. only i took the 30a escs, and have alot of different props.
vartaz is offline Find More Posts by vartaz
Old Dec 09, 2012, 03:33 AM
chip22 is offline
Joined Dec 2012
Q450 frame 15
Others agree with this setup? What would be the thrust of this setup?
Old Dec 09, 2012, 05:40 AM
echo75 is offline
Find More Posts by echo75
Anything can be made to fly
echo75's Avatar
Denmark, Capital Region of Denmark, Brondby
Joined Jun 2011
For $100 RTF as you request you are limited micro models like the MQX or the Hubsan.
echo75 is offline Find More Posts by echo75
Old Dec 09, 2012, 08:04 AM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
That's a really good and pretty standard setup that Vartaz suggested. 2200mah battery will be fine for that and save weight.
If this is your first quad, I wouldn't worry too much about thrust. Building one, getting it into the air and learning to fly will be your first challenges. Considerations of thrust can come later.
2400RDR is offline Find More Posts by 2400RDR
Old Dec 09, 2012, 08:08 AM
chip22 is offline
Joined Dec 2012
But i am interested, what would be thrust about with this setup?
Old Dec 09, 2012, 08:22 AM
2400RDR is offline
Joined Feb 2009
Sorry- I have no idea. I never worry about such things
Old Dec 09, 2012, 08:28 AM
2400RDR is offline
Joined Feb 2009
OK- I looked it up. DT750 motors with an 11x 4.7 prop will make a max of 1000 gm of thrust (probably on 3S), or 4kg for a quad with four. Keep in mind that most of your flying will be done at about 50% throttle if you've planned everything out right, so you'll be using 2kg thrust, which should lift your 3 lb frame ok.
Here's a link to the specs for the motor:
http://www.hobbyking.com/hobbyking/s...ner_750kv.html
Old Dec 09, 2012, 08:42 AM
chip22 is offline
Joined Dec 2012
Ok,then
4x http://www.hobbyking.com/hobbyking/s...ner_750kv.html
4x 11x 4.7 props (give me please link,can't find)
KK board
Fram i will make myself.
Recommend (with link) 4 ESC's + best battery for these motors and props?
Old Dec 09, 2012, 08:49 AM
2400RDR is offline
Joined Feb 2009
Ok,then
KK board
I think maybe you should do a little searching on your own- you'll learn a lot a long the way. Go to HobbyKing and look in their "Multi-rotors and Parts" section, and check "Propellors". Also, don't forget that you'll need ESCs also. The HK F30 escs are really good.
BTW, if you really can't find props, I'll help with a link. Give it a try yourself first though.
Old Dec 09, 2012, 09:59 AM
JohnVH is online now
Find More Posts by JohnVH
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
If you went tricopter you would have to buy one less esc motor and prop.
JohnVH is online now Find More Posts by JohnVH
Old Dec 09, 2012, 10:36 AM
chip22 is offline
Joined Dec 2012
Ok,what you say about this tricopter setup?
3x Motors http://www.hobbyking.com/hobbyking/s...247&aff=663102
3x 25A ESC's http://www.hobbyking.com/hobbyking/s...163&aff=663102
KK2 flight controller http://www.hobbyking.com/hobbyking/s...723&aff=663102
11x4,7 Props RH rotation http://www.hobbyking.com/hobbyking/s...451&aff=663102
11x4,7 http://www.hobbyking.com/hobbyking/s...452&aff=663102
Battery http://www.hobbyking.com/hobbyking/s...934&aff=663102
USBasp AVR Programming Device for ATMEL proccessors - http://www.hobbyking.com/hobbyking/s...occessors.html
Old Dec 09, 2012, 10:49 AM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
http://rcexplorer.se/projects/2011/0...ricopter-v2-5/
Old Dec 09, 2012, 11:34 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
a DT750 and ESC cost about as much as a decent servo. So the cost advantage of building a Tri doesn't really exist.
Your build list looks good. I fly with DT750's, 11x4.7" props & 2200 3s and am very satisfied.
AcroFPV is offline Find More Posts by AcroFPV
Old Dec 09, 2012, 11:52 AM
Qualified
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
I suppose, I have a bunch of servo's laying around so I didnt have to buy anything, didnt even use a fancy one.
Discussion What's the best RTF QuadCopter for under $500 in US? BenHayat Multirotor Talk 12 Jun 12, 2016 09:53 PM
Discussion Best Charger for around $100 that can charge 4 batteries at once up to atleast 6 cell chrisorbics Batteries and Chargers 38 Nov 29, 2012 10:16 PM
Sold NIB Solo Pro 180 RTF for $100 pick up in New York xzd Aircraft - Electric - Helis (FS/W) 1 May 16, 2012 06:07 AM
For Sale NIB Solo Pro 180 RTF for $100 pick up in Baltimore or New York xzd Aircraft - Electric - Helis (FS/W) 0 Apr 25, 2012 09:33 AM
Yippee! Recommend best 100" value for weekend pilot LWThompson Thermal 20 Sep 12, 2003 06:59 PM
