Old Dec 12, 2012, 06:11 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Pretty sure the Funjet uses a 2200mAh battery, so it's possible your plane is tail-heavy? I have flown a couple Funjets, and I found them easy to fly, no tendency to nose-down due to throttle because the motor is on the centerline. The RadJet and Funjet (Multiplex) are basically the same shape, so I would suggest looking up the CG number for the Funjet and use that. Also make sure you're measuring from the right place - I believe you measure from the point where the wing meets the body - not from the nose. IIRC, it balances pretty far back.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 12, 2012, 06:15 PM
FlyBoy20 is offline
Find More Posts by FlyBoy20
FlyBoy20's Avatar
United Kingdom, Lincs
Joined Aug 2012
Originally Posted by headlessagain View Post
Fly
if you have the chance, try to re-maiden into the wind over a slope (at the beach?)
The beach is a definite no-no - fatal for sand in the motor, but there is an ideal slope when the wind comes from the South-West, but this time of year it's from the Northerly direction..brrr
It might be best to try to source a replacement motor shaft than try the spare 1200Kv motor from your damaged Decathalon. Pusher jets need high kv motors unless running on a 6S pack! If you do decide on a different motor then I'd head over to the Radjet thread for some ideas..
Andy
New shafts are unavailable, especially since is a no-name motor (why don't they just use proper hardened steel...doh?).
I do have a suitable HK Donkey motor, but I can't get the circlip off the shaft to clean the sand out of it. Anyway I just ordered a nice Grayson 2212-06 because I've read such good things about it and like the look of it.
I'll keep that for when I've learned not to bend motor shafts!
FlyBoy20 is offline Find More Posts by FlyBoy20
Old Dec 12, 2012, 06:42 PM
FlyBoy20 is offline
FlyBoy20's Avatar
Joined Aug 2012
Originally Posted by jasmine2501 View Post
..Also make sure you're measuring from the right place - I believe you measure from the point where the wing meets the body - not from the nose. IIRC, it balances pretty far back.
I just wish it was mid-Summer, so I can go up the nearby hayfield and do a test glide for different arrangements without risk of more damage... meanwhile, devil-for-punishment that I am, I've got a cheapo HK Flying Wing kit.
Dead easy to assemble and looks really neat, and they even give you a tube of glue! At 300g flying wieght I figured it must have a super-low wing loading, so should be able to fly nice and slow. When I guesstimated it, it worked out to <6oz/SqFt.
When I get some 3mm nuts and bolts I'll fit the AX 1806-N to it...and see if it makes a good lawn dart..
Old Dec 13, 2012, 01:10 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Fly
you might find the 2500kv AX 1806-N will give you fairly lively performance if running on a 3 cell pack. Here is my Mini Swift using the same motor
Mini Swift on 2500kv motor (2 min 42 sec)
and my scratch 610mm built flying wing on a Blue Wonder 3000 kv 3 cell set up
Mini Wing KFm-4. 610 span. Shot with #16 HD Keycam (2 min 20 sec)
You have been warned
Andy
headlessagain is offline Find More Posts by headlessagain
Old Dec 13, 2012, 10:22 AM
FlyBoy20 is offline
FlyBoy20's Avatar
Joined Aug 2012
Fly
you might find the 2500kv AX 1806-N will give you fairly lively performance if running on a 3 cell pack...nd my scratch 610mm built flying wing on a Blue Wonder 3000 kv 3 cell set up..You have been warned.
Andy
Actually, it'll be on 1300 2S. I measured the output with various props @ 54w (APC 5x5), 66w (Graupner 5.5x4.3) and 79w (MA 6x3). I ran it full pelt for 60secs and it only got luke warm, so now I got to choose which for easy flying. The 6x3 gives me a modest 119w/lb, so I think I'll be OK with that.
Couldn't help noticing the pesky dog in your video..
Old Dec 13, 2012, 11:19 AM
FlyBoy20 is offline
FlyBoy20's Avatar
Joined Aug 2012
BTW Andy, how do you create a file for YouTube. I've got a Panasonic HD Camcorder and the format needs to be converted to MPEG4?
Guess I got to buy some software to do this?
Old Dec 13, 2012, 11:53 AM
Rocket Programmer
Joined Jul 2007
Adobe Premiere Elements can import the files from Panasonic cameras, I used to use one myself. YouTube seems to eat WMV files without too much trouble, so that's my final format. No video clip should ever be posted without at least minor edits - there's always something you don't need, and the less you can have in your video, the more likely it is to be watched, and it will take less time to upload. Raw HD video should never be sent to Youtube - always render it into another format first.
You can use Windows Movie Maker if you want something free.
Old Dec 13, 2012, 12:05 PM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
You should be able to straighten it if you're carefull. I've done it to my stock RadJet motor. If you shorten the shaft so the collet touches the motor housing you won't bend the shaft so easily.
A good RadJet CG is the front edge of the finger grip. Launch it into the wind full throttle.
Gohmer is offline Find More Posts by Gohmer
Old Dec 13, 2012, 12:18 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
I use Windows Movie Maker that was bundled with MS Vista Ultimate. It's easy to use and has enough features for my use. Camera is the #16 HD Keycam mounted on a foam wedge on my baseball hat peak.
Andy
Old Dec 13, 2012, 06:55 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I am entirely, profoundly confused by this. That plane should be up and flying, no problem.
The 2212/6 motor you ordered will change your luck for sure, though. I'd run a 5x3 or 5x4 prop on 3S to start out; it will have WAY more than enough power to get the thing up and hoofin' it even if you're not propped up to the max, and a less-aggressive prop will help reduce any possible torque roll issues. Even if the CG is in a bad place, that motor will be like strapping a rocket engine to the back of the plane. There is simply no way you'll have too little power to climb out this time around
Another nice setup for small parkjets and wings that I've really grown to respect is the Suppo 2208/12 (1800Kv) with an APC 6x5.5 on three cells. Excellent combination of thrust and speed for parkflyers in a less-power-hungry package than the 2212/6.
Piece is offline Find More Posts by Piece
Old Dec 13, 2012, 07:37 PM
FlyBoy20 is offline
FlyBoy20's Avatar
Joined Aug 2012
You and me both!
The 2212/6 motor you ordered will change your luck for sure...
Trouble is I'm reluctant to even try it, thinking it might result in another bent/broken shaft..and yet another wasted journey.
Old Dec 13, 2012, 08:05 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
That shaft is made of good 1/8" hardened steel. If it ever comes down to it, your props will break before you manage to bend the shaft. I've been flying and crashing those motors in various winds (930Kv - 2200Kv) for years and I've only managed to bend shafts when running the lower-Kv motors with bigger props on tractor setups.
To do anything at all to that shaft, you'd need a very hard direct hit to the prop adapter, and that... ain't gonna happen
Old Dec 13, 2012, 08:20 PM
Rocket Programmer
Joined Jul 2007
Naw, I've seen this play out at the club quite a few times with planes like the Funjet, Strykers, Zagi, etc...
The thing is, even with lots of power, these planes are kind of hard to launch. So, I have seen people give it a try and something goes wrong, and they crash for whatever reason... and break something critical, then go down a rabbit hole trying to fix it. I think the only thing you can really do is work on the launch, because even when under powered, these things still fly good after you get them going. We used to fly Strykers and Funjets with brushed motors and we did ok. So, it's not about the power level, the technique and setup are much more important.
Old Dec 14, 2012, 05:48 AM
FlyBoy20 is offline
FlyBoy20's Avatar
Joined Aug 2012
That shaft is made of good 1/8" hardened steel. ..To do anything at all to that shaft, you'd need a very hard direct hit to the prop adapter, and that... ain't gonna happen
Here's a couple I bent earlier..the one on the left is from the RadLawnjet.
Old Dec 14, 2012, 05:53 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
Good Lord, why is that motor missing its leads in such a vulgar fashion?
Discussion Radjet vs SkyFun Jet. Which one to get to replace my abused radjet. Koo Pusher Prop Jet Models 5 Mar 15, 2013 05:15 AM
Video Maiden Flight of the Noob 3 Wingman26 Electric Plane Talk 0 Aug 21, 2012 10:43 PM
Discussion Maiden with my Radjet 800! Koo Crash Discussion 16 Aug 15, 2012 08:02 PM
