Old Dec 27, 2012, 09:02 PM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
[/I]
I have three of these motors , what do you think about at 20/10 Prop ? Was going to run a three blade on my seafury but trying to keep my overall cost down on the spinner , seems like the range from these post are anywhere from 20 and above on 10 cells , 120 HV esc
Product reviews for;
HXT 63-74 200kv Brushless Outrunner (Eq:5240)
Amazing !!
Reinhold Wichert
I ordered this Motor, using the latest ratings as source for selecting this piece
for my Jodel Robin with 2,2m and around 9kg weight.This is a electrical " Rocket", absolutly great.Pushs a 20*10 Maro over 7000 rpm,thats about 10kg or 22lbs of thrust at 75Amps on 12S lipos.The motor gets warm, maybee 50 deg c, after 4 to 5 min full power..thats it.
Great Motor, great deal....keep on going !!
76 people like this review, do you? Yes | No
___________________
HXT63-74-200
Norbert
Testbench result:
Lipo: 9s2p 2200ma Hextronik (4s+5s Pack as 2P)
Speedcontroller: OEMRC Sentilon100A HV
Prop: 24x8 MenzS (wood)
Voltage under load: 31,4V (measured after 90s after starting the test)
Current: 60 A (at 80% throttle)
Rpm: 5250
Pull: 9,1 Kg / 20,2 lb (measured with digital balance)
All Measurments at 80% of throttle (60 Amp's) because the current capacity of my shunt is only 60 Amp's.
I have Pull of 10,5-11 Kg (only very short measuring 2-3 seconds without current control) without shunt at full throttle.
A well made and very powerfull Outrunner !!!
57 people like this review, do you? Yes | No
___________________
HXT 63-74 outrun
Bernard Chevalier
The 63-74 200kv is a very nice and very efficient engine, great sound! I fly the Taxi 2400 Graupner with. Here is may database with 6, 8 and 10S lipo (medium timing)
http://www.bungymania.com/imageshome...erf1.php?id=37
40 people like this review, do you? Yes | No
___________________
Certified Buyer Rated
xxxxx
I am thinking on mounting this brusless outrunner in a smaal electric scooter and the motor looks realy nice good bearing and thick wire from the motor! I recomande every one who buy this motor to buy the recomended esc on 100A whho you can see below the motor information.
15 people like this review, do you? Yes | No
___________________
Fantastic motor
Reinhold Wichert
Ldm is offline Find More Posts by Ldm
Old Dec 28, 2012, 03:59 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
A 20x10 should be just fine on that motor on 10s.
Ive got a couple of the old HXT 6364-230kv motors that I run 20x10 turnigy type E wood props on with 10s
kahloq is offline Find More Posts by kahloq
Old Dec 28, 2012, 08:43 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks BUddy !!!! , that makes more sence then the 18-8
Old Jan 24, 2013, 09:41 PM
Svrco is offline
Find More Posts by Svrco
Joined Jan 2013
Looking for experienced advice
Hi guys, last 2 months I look for ESM Lavochkin la7, one of my favourite birds...
http://www.esmmodel.com/inc/Enproduc...?productid=203
I have free eflite 110 motor, esc 120a HV, and 3 packs 10s 5000mah battery, it is free without any kit...
I guess it is little underpowered but want to now is it enough for safety flying, or thinking about gas engine?
All advices are welcome...
Svrco is offline Find More Posts by Svrco
Old Jan 25, 2013, 05:36 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
An e-flite 110 motor is not rated for 10s. Its an 8-9s motor. That LA-7 is an 80" plane and a little big for the 110. An e-flite 160 on 10s could fly it, but it'll be a bit sluggish. The flying weights ESM gives are always low. That plane will probably weight over 20 pounds when finished. You'd be better off using a 50cc gas or 50cc electric motor.
Old Jan 25, 2013, 06:41 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Electric looks like more of a PITA when you get into these big sizes. I'd go gas if you can stand the sound of it.
TTRotary is offline Find More Posts by TTRotary
Old Jan 25, 2013, 06:59 PM
Svrco is offline
Joined Jan 2013
I like electric, and fly eflite 110 on 10s without problems with my piper 1/4 scale...
I sell model and i have free this combo...
I like LA7 from esm and thinking to buy if it can fly
Old Jan 26, 2013, 05:48 AM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
piper is a high wing plane , will float and lift easier then a warbird , what airfoil do you have on your piper ?
I never seen an ESM at that size on a 110
Old Jan 26, 2013, 05:57 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Nah. Easy as can be. Rimfire 50cc or 65cc electric on 12s. My ESM fw-190 d9 flies beautifully on a rimfire 65 turning a 21x14. You could put a 26x12 3 blade on that motor and it'd be happy.
As far as running a 110 on 10s, sure it might do it ok when its not strained, but on a 20# plane that requires higher throttle to maintain flight the a lazy slow cub, you're gonna blow the motor and lose the aircraft.
Old Jan 26, 2013, 07:56 AM
Svrco is offline
Joined Jan 2013
I think similar, so I give up from that model and search another model...
LDM: piper was from Theworldmodels
Thanks to all for advices
Old Jan 26, 2013, 08:46 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
You don't have to give up on that la-7, just get a different motor. Turnigy has an easymatch g160 245kv for half the price of an eflite 160 at hobbyking.com and you could use your 10s batteries. A nice 18x12 or 20x10 prop would work nicely.
Old Jan 26, 2013, 02:49 PM
TTRotary is offline
Joined Mar 2010
In the electric power classifieds, a guy is selling a 50cc electric outrunner. Might be just the ticket, though i know nothing about that brand.
Sold 2 like new Eflite motors powers 110 and 160 hidaven Aircraft - Electric - Power Systems (FS/W) 6 Jul 09, 2012 04:51 PM
Wanted MonsterPower .160 or Tacon.160 or 6364 245kv SmokeDogg Aircraft - Electric - Power Systems (FS/W) 3 May 03, 2012 11:33 PM
Sold 2X E-Flite 110/160 prop adapters 100mph Aircraft - Electric - Power Systems (FS/W) 1 Mar 03, 2012 08:10 AM
Found power 110 or 160 collectivepitch Aircraft - Electric - Power Systems (FS/W) 0 Aug 03, 2011 09:36 PM
Wanted WANTED E-Flite 110/160 prop adapter and firewall mount for a power 160 mechengineer03 Aircraft - Electric - Power Systems (FS/W) 3 Apr 18, 2010 10:12 PM
