Old Dec 20, 2012, 08:23 PM
fly20 is offline
Find More Posts by fly20
L.I. NY
Joined Dec 2006
LDM. the ARF spans 62.5" and weights 8.5-9.5lbs and recommends either a OS 65ax abl 2stroke or a OS fs95 v four stroke. I actually did a search, but only came up with kit corsair power setups which I think were a bit heavier than the arfs, thats why I posted my question. Thanks for the pm. Gary
fly20 is offline Find More Posts by fly20
Old Dec 20, 2012, 08:59 PM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Gary , at that weight I have seen two options , the eflight power 60 and Power 90 .
Obviously you can use any brand but the size suggestion is the same , 60 will be pushing the limits , 90 is better and 110 is over kill .
I would use an 80 amp esc so you have more then enought power with zero risk of a meltdown .
Corsair jock has flown many in this size with 60 power motor , but I like to have more power so that is I would suggest the 90
Ldm is online now Find More Posts by Ldm
Old Dec 21, 2012, 08:08 AM
fly20 is offline
L.I. NY
Joined Dec 2006
Sounds like a plan, thanks.
Old Dec 23, 2012, 02:24 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
For the Corsair: LDM is right, the P90 is just right.
LDM, for the 160, you may want to look into a Zinger 18x16.
TTRotary is offline Find More Posts by TTRotary
Old Dec 23, 2012, 05:45 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks TT ,
I am going to ask a stupid question but from my glow days i have about 11 totally new and about 13 used props from ,
Can wooden props designed for glow be used on eletric motors ?
Old Dec 23, 2012, 06:14 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I've seen it done.
TripleW is offline Find More Posts by TripleW
Old Dec 24, 2012, 07:38 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Originally Posted by Ldm View Post
Thanks TT ,
I do it all the time. Most of the props Im running on larger electric planes are wood.
kahloq is offline Find More Posts by kahloq
Old Dec 24, 2012, 02:07 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thats great to know , I have too many to trash !!!
Old Dec 24, 2012, 04:49 PM
warbirdfan2 is offline
Find More Posts by warbirdfan2
Joined Jan 2011
Thanks TT ,
I was asking the same question to TBM a week ago. They have the 3 and 4 blade props from Biela that are awsome looking. He told me that thay have a lot of guys doing it. I just need to figure out what size I need for my P51.
warbirdfan2 is offline Find More Posts by warbirdfan2
Old Dec 24, 2012, 05:24 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Ive got a 20x14 3 blade Biela prop I'll be using on a 65cc rimfire mounted to an ESM do-335. I bought the prop initially to use on the esm fw-190d9, but maidened with a two blade and decided to leave it that way.
Old Dec 24, 2012, 08:25 PM
Joined Jan 2011
Are you only running one motor in your DO335? Both those planes are 80" correct? I have the 73" mustang,and am planning on a tacon160,10s setup, with a hv120 esc. I'm thinking something around 18-10 or 12 on a 4 blade. any thoughts?
Old Dec 24, 2012, 09:46 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
I am using a three blade Bella on my LX 79" P40.
Eflight 100 , I am think it was a 17-6 three blade , not sure right now , too much egg nog .
Never knew the Bella were used for fuel planes , the Bella prop was actually lighter then the supplies three blade LX Prop
Old Dec 24, 2012, 09:47 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
sorry eflight was a 110
Old Dec 25, 2012, 12:09 AM
TTRotary is offline
Joined Mar 2010
Me too. Have gotten good performance from the Zingers and also the APC pattern, which are designed for glo. The only props I don't like for e power are the MAS.
Old Dec 26, 2012, 09:52 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
No running a 65cc rimfire up front with the 20x14 3blade Biela and a power 60 with 16x10 3blade at the tail.
As for props...I have no problems using MAS on electric motors but hate APC as they're not that efficient at producing thrust.
Sold 2 like new Eflite motors powers 110 and 160 hidaven Aircraft - Electric - Power Systems (FS/W) 6 Jul 09, 2012 04:51 PM
Wanted MonsterPower .160 or Tacon.160 or 6364 245kv SmokeDogg Aircraft - Electric - Power Systems (FS/W) 3 May 03, 2012 11:33 PM
Sold 2X E-Flite 110/160 prop adapters 100mph Aircraft - Electric - Power Systems (FS/W) 1 Mar 03, 2012 08:10 AM
Found power 110 or 160 collectivepitch Aircraft - Electric - Power Systems (FS/W) 0 Aug 03, 2011 09:36 PM
Wanted WANTED E-Flite 110/160 prop adapter and firewall mount for a power 160 mechengineer03 Aircraft - Electric - Power Systems (FS/W) 3 Apr 18, 2010 10:12 PM
