Old Dec 10, 2012, 11:30 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Think I'll stick with going with a H9 Spitfire and paint it while using the g60. Ive got several 8s birds already and the H9 DVII is already balanced etc with the monster 110.
Besides, the H9 Spit will be cheaper to get going and wont take much time to build. The whole reason I was looking for something was I have a saito 72 lying around unused....and the g60 was originally intended for my 80" .40 J-3 Cub. But a .72 will fly that fine and I wont need to do any weird conversion stuff for an e-conversion. Its not a racer so a power 60 motor would be overkill.
I still want a gee bee r3 though.
kahloq is offline Find More Posts by kahloq
Old Dec 10, 2012, 08:32 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
LDM, you'll definitely want Power 160 for those 70" plus birds. As you know, I'm flying my "little" 66" Will Hobby Sea fury on a Power 110 using about the fastest prop I can lay my hands on (16x16 APC pattern prop) and that feels just about right. Definitely faster than scale on low passes, but boy does it look good, and it has a mean whistle as it goes by.
TTRotary is offline Find More Posts by TTRotary
Old Dec 10, 2012, 10:27 PM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Thanks , yes i am going with the 160 size motors .
kai , that is not the adapter I was thinking about , you hooked me up with one that has a hole in it and allows the spinner to bolt into the prop shaft and easily bolts onto the Monster 110 with the 4 set screws. I will try to look it up for you .
Love that Bee , seen that years ago when Hobby Lobby was importing one from graupner , was a very cool plane , I think Hobby King sells one at this time
Ldm is offline Find More Posts by Ldm
Old Dec 10, 2012, 10:31 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks for the fliteskin link , i dont know if he is out of the G10 or what but he did not suggest it for reinforecing a fuse and that is unlike Jose
Old Dec 11, 2012, 01:48 PM
TTRotary is offline
Joined Mar 2010
That plane is the 30cc size ARF in the R3 series that was sold years ago by Donuts models. Hobby Lobby carried the 20cc 59" ARF for a while. The HK price is actually incredibly good, but as we all know, you're on your own if there is shipping damage. Giant Model Products carries these planes stateside. There are also 50 and 100cc versions. They are reputed to be a handful. I have the 20cc ARF, not yet built. Super nice airframe, but the hardware is not ideal and the instructions are nonexistent.
Old Dec 12, 2012, 10:58 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
The 20cc 59" gee bee r3 is rather heavy on the wingloading. It also has to have a good amount of speed in corners and lands fast. The 30cc at hobbyking is the same one sold at GMP, but version 1 without the upgraded hardware and carbonfiber wing tube. It carries a lighter wingloading though, then the 20cc size.
The 50cc and up sizes have flaps.
Old Dec 13, 2012, 12:41 PM
TTRotary is offline
Joined Mar 2010
I'll be adding split flaps to mine. I'm also going to try a 4S or max 5S build to keep the weight down. No reason why this can't come in at 6.5lb all up with some creative solutions.
Old Dec 20, 2012, 05:20 AM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
What prop are you guys using on your 160 ??
I want to go three blade , I am using 2 -5 cell 5000 batteries .
These (now discontinued) Turnegy 160ties were rated at 200kv i know I should not take that with major consideration but its a simple starting point .
Old Dec 20, 2012, 11:01 AM
fly20 is online now
Find More Posts by fly20
L.I. NY
Joined Dec 2006
Hope you don't mind me jumping in here. I just picked up a top flite corsair [60 size] that tower has on special. It will be my first 'big' electric conversion. Supposed to come in around 10 lbs when ic powered. Could you please recommend a suitable motor battery, prop combo? Thanks.
fly20 is online now Find More Posts by fly20
Old Dec 20, 2012, 05:36 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
There are several dedicated threads in this forum. Using advanced search, search on Top Flite Corsair and select Glow to Electric Conversions from the search in forum(s) box.
This is the result: http://www.rcgroups.com/forums/searc...lite%20corsair
scirocco is offline Find More Posts by scirocco
Old Dec 20, 2012, 05:41 PM
fly20 is online now
L.I. NY
Joined Dec 2006
Thankyou.
Old Dec 20, 2012, 06:28 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
That KV is lower then an e-flite 160@245kv. I have used 16x13 3 blades on an e-flite 160 as well as a turnigy sk 6364 245kv motor. I am quite sure a 160 can spin an 18x12 3 blade as I can easily turn a 20x10 2 blade on a power 110.
But since your 200kv is a little low for 10s, you might have to bump up the pitch and lower the diameter.
Old Dec 20, 2012, 08:28 PM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
My friend has a very nice Kyosho 90 size spitfire with a power 160 on 9s with a 18in 3 blade prop and flies very nice
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Dec 20, 2012, 09:04 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Thanks Kah , I was comeing close to those numbers.
Twiz nice spit !!!
Old Dec 20, 2012, 09:07 PM
Ldm is offline
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Fly20 , if you check out RC Universe , Corsair Jock has converted many corsair in this size to epower and in most cases was in the 90 size motor and even 60 size .We would need to know the weight as your kit is the new ARF , not the kit build versions that are sp prevalant in these threads
Sold 2 like new Eflite motors powers 110 and 160 hidaven Aircraft - Electric - Power Systems (FS/W) 6 Jul 09, 2012 05:51 PM
Wanted MonsterPower .160 or Tacon.160 or 6364 245kv SmokeDogg Aircraft - Electric - Power Systems (FS/W) 3 May 04, 2012 12:33 AM
Sold 2X E-Flite 110/160 prop adapters 100mph Aircraft - Electric - Power Systems (FS/W) 1 Mar 03, 2012 09:10 AM
Found power 110 or 160 collectivepitch Aircraft - Electric - Power Systems (FS/W) 0 Aug 03, 2011 10:36 PM
Wanted WANTED E-Flite 110/160 prop adapter and firewall mount for a power 160 mechengineer03 Aircraft - Electric - Power Systems (FS/W) 3 Apr 18, 2010 11:12 PM
