Originally Posted by Makdaddy
Hello,
I am not new to flying, fly WL V911's and have the V939 and V929 quads.
Looking into getting my first plane.
I believe I am advanced enough to go with something a little more acrobatic then a trainer. Do not want to break the bank but something smaller that has good response and can handle a crash without disintegrating. Also something that can handle a little wind.
I have a 9x with er9x firmware and also the new transmitter to fly Spectrum/JR protocols.
Also have Accucell 6 battery charger so charging batts is not an issue.
Any suggestions would be appreciated.
The WL V911 is very easy to fly with that stabilizing flybar and quadcopters are nowhere near the difficulty of flying real CP helis. I'm not trying to hold you back, but IMO your heli experience is very limited. Now, if you had been flying CP helis successfully for a while then you could probably skip the high-winged trainer and start with something more advanced. I started with helis and after flying CP helis for nearly three years, I wanted to give airplanes a try. My first airplane was a 32" EPP 3D foamy. I adapted very quickly and no doubt, my CP heli experience helped, but still, flying airplanes and helis are different.
My second airplane was the Parkzone T-28 (44" version). The T-28 is a great low-wing aileron trainer. However, I remember I crashed the T-28 once by turning sharply downwind...stalled and crashed hard. That crash taught me two important lessons about flying airplanes...the first being that just because I flew helis doesn't' mean that airplanes are a cinch to fly and the second lesson being that airplanes can get out of hand very quickly just like a heli.
My third airplane was the Precision Aerobatics 58" Extra MX...my first balsa airplane. Forth was 3DHS 72" Extra 330SC. Fifth was Extreme Flight 60" Edge 540T. Sixth was Aerobeez 87" Sbach 300. As you can see, I've gravitated towards 3D airplanes. There is no doubt that CP heli skills help in flying 3D airplanes, especially those high-alpha maneuvers and hovering.
Lastly, as you fly larger airplanes, you learn that you need to prep and setup your landings earlier because heavier airplanes require more room to land. Obviously, airplanes are also much more difficult to land versus helis.
Anyway, go with what you are comfortable with. I'm just trying to give you some things to consider.
