Old Dec 08, 2012, 05:04 AM
bomberhat is offline
Find More Posts by bomberhat
Joined Dec 2012
Question
v911 tail rotor
I can turn right and left in the first 30 seconds of flight after that no more turning right and with full throttle it spins out of control but at about half throttle its fine and stable the tail motor sounds fine do you think the motors bad thanks for the help
bomberhat is offline Find More Posts by bomberhat
Old Dec 08, 2012, 06:56 AM
PhilMcCracken is offline
Find More Posts by PhilMcCracken
Joined Apr 2012
sounds like the tail rotor engine dying? or a dry solder
PhilMcCracken is offline Find More Posts by PhilMcCracken
Old Dec 17, 2012, 10:51 AM
georgeintexas is offline
Find More Posts by georgeintexas
United States, TX, St Paul
Joined Dec 2012
I had a similar problem and it turned out to be a long hair wrapped around the tail rotor shaft adding drag.
George
georgeintexas is offline Find More Posts by georgeintexas
Discussion Hobbyking tail rotor shaft 42.8mm - cheap extended tail rotor shaft Atomic Skull Mini Helis 2 Sep 29, 2012 02:01 PM
Discussion V911/ V929 ...Amazing flying Rotor Machines !! dankar04 Micro Helis 1 Jul 16, 2012 03:00 PM
Sold ALIGN TREX 700 Metal Tail Pitch Assembly / / Metal Tail Rotor Control Arm Set helifreak592 Aircraft - Electric - Helis (FS/W) 0 Apr 05, 2012 06:36 AM
Sold Align cnc tail rotor & Steel Tail rotor hub Orion_V Aircraft - Electric - Helis (FS/W) 1 Jan 03, 2006 03:30 PM
RPM of Aerohawk tail rotor and tail rotor motor? Lynxman Micro Helis 0 Feb 01, 2004 08:01 AM
