Old Dec 08, 2012, 03:05 AM
srepfler is online now
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
SIX Glass Fiber Hexcopter Frame 600mm
I am flying this frame for some time and could not find thread with it so decided to post some info and flight footage.
HobbyKing Daily - Glass Fiber Hexacopter (1 min 57 sec)
some flight footage
SIX Hexcopter flying in the mist with position & altitude hold ( KK2 ) (11 min 9 sec)
KK2 1.4 firmware test - THANKS Kapteinkuk! (4 min 20 sec)
SIX HEXcopter weekend high wind flight part 2 (4 min 50 sec)
srepfler is online now Find More Posts by srepfler
Old Dec 08, 2012, 03:08 AM
srepfler's Avatar
Joined Jul 2011
Set up
Latest setup
RCTimer Carbon Fiber 10x4.5" CW CCW Counter Rotating Propellers
frame
http://www.hobbyking.com/hobbyking/s...514&aff=448825
board
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board
http://www.hobbyking.com/hobbyking/s...723&aff=448825
motors
NTM Prop Drive Series 28-26A 1200kv / 250w
http://www.hobbyking.com/hobbyking/s...345&aff=448825
ESC
HobbyKing 30A BlueSeries Brushless Speed Controller
http://www.hobbyking.com/hobbyking/s...429&aff=448825
Batt
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/hobbyking/s...911&aff=448825
Previous props
props
http://www.hobbyking.com/hobbyking/s...445&aff=448825
http://www.hobbyking.com/hobbyking/s...442&aff=448825
Old Dec 08, 2012, 03:11 AM
srepfler's Avatar
Joined Jul 2011
Build log pictures
Log pictures part 1
Old Dec 08, 2012, 04:42 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
I have the same frame, got it flying for a bit. Tried to make it work with my Crius AIO Pro + GPS. Sadly, the power distribution interferred with the compass and it never flew well. Also, the Arducopter firmware just wasn't anywhere near as easy to tune as Multiwii. The frame is very very sturdy and will definitely survive a crash or two. Mine is currently stowed away, won't use it again anytime soon... I don't have enough motors and the only hexa I want right now is the S800, for crazy fast flying I have an F330 and F550.
WiseDuck is offline Find More Posts by WiseDuck
Old Dec 11, 2012, 02:51 AM
srepfler's Avatar
Joined Jul 2011
Power meter
Some power meter findings ( in flight test)
Power meter on HEX SIX (8 min 17 sec)
Old Dec 11, 2012, 02:55 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I suggest you buy Hobbykings new power distribution board, (MAX 20A per motor) put that between the plates, solder all the ESCs to that. It'll make it look MUCH better and will also eliminate multiple possible points of failure, all those XT60 connections.
EDIT: Oh I see that you have a distribution board already. There is no reason to have an XT60 plug between that and the ESCs like that. Just extend the ESC wires a bit and add a bullet connector to that. I would still go with a more traditional power distribution board though.
Old Dec 11, 2012, 03:01 AM
srepfler's Avatar
Joined Jul 2011
Originally Posted by WiseDuck View Post
I suggest you buy Hobbykings new power distribution board, put that between the plates, solder all the ESCs to that. It'll make it look MUCH better and will also eliminate multiple possible points of failure, all those XT60 connections.
I agree.
At first I was not sure will it fly or crash, ESC if crashed would go to planes and XT60 is for planes.
Was planning to put Simon ESC later or reprogram this ones.
Have are quad with same XT60 and to have spare on HEX and easy replace if needed.
But Yes not good with so many connectors, much better if solder all.
Only good thing in case of crash just reconnect on new frame.
From some reason even I expected crash, no crash on quad or hex after many hours of flying.
Old Dec 11, 2012, 03:23 AM
srepfler's Avatar
Joined Jul 2011
With way to many wires,
additional 4*12 + 2=50 LEDS
Old Dec 11, 2012, 03:24 AM
srepfler's Avatar
Joined Jul 2011
Video with 50 LEDs
UFO (NLO) in Valpovo (6 min 25 sec)
Old Dec 14, 2012, 02:56 AM
srepfler's Avatar
Joined Jul 2011
gopro test
Gopro on it
HEXcopter SIX gopro FPV (7 min 41 sec)
Old Dec 19, 2012, 05:34 AM
srepfler's Avatar
Joined Jul 2011
lots of weigth
With 4x 2200 3s around 900g battery
4 x 2200mAh 3s on SIX Glass Fiber Hexcopter Frame 600mm (4 min 52 sec)
Old Feb 10, 2013, 05:14 PM
SimonJux is offline
Find More Posts by SimonJux
Joined Feb 2013
Great review...... so good I bought one! Just mid build at the moment. Going to use the KK2 board to start.
SimonJux is offline Find More Posts by SimonJux
Old Feb 10, 2013, 05:18 PM
Fernando89 is offline
Find More Posts by Fernando89
Joined Feb 2013
very good, congratulations the setup!
Fernando89 is offline Find More Posts by Fernando89
Old Feb 10, 2013, 05:29 PM
SimonJux is offline
Joined Feb 2013
I think I am going with 28-30 750Kv 10A Brushless Outrunner, 18Amp Turnigy Plush ESC with a KK2 board.
For Sale HEXA ATG X6 700mm Dual Arm Carbon Fiber Hexcopter AirCraft Frame-Dual Track Go4it Aircraft - Electric - Multirotor (FS/W) 1 Jun 25, 2013 10:30 PM
Sold Set of Align 600E Silver Fiber glass Main frames NEW!! HD Hucker Aircraft - Electric - Helis (FS/W) 2 Jun 07, 2012 11:12 PM
New Product Hobbyking Y650 Scorpion Glass Fiber Multi-Rotor Frame 650mm Erknie Multirotor Talk 2 Apr 03, 2012 02:02 PM
Sold Fiber Glass Spider Style Frame 635mm - $35 shipped Merkin77 Aircraft - Electric - Multirotor (FS/W) 3 Mar 24, 2012 08:28 AM
Discussion carbon fiber frame vs fiber glass frame? ChatXT Multirotor Talk 1 Feb 09, 2012 02:38 AM
