Old Dec 07, 2012, 11:13 PM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Nxy
I recently aquired a new NYX, its fuse is carbon kevlar fuse, I am using JR I have a carbon receiver with a carbon satellite, I have the satellite receiver antenai exiting the fuse through the launch peg hole in bottom of fuse, now I am trying to figure out where to have the two antenai on the main receiver exit, before the hatch or behind the hatch 2" in front of the wing, any suggestions would be appreciated, I will have pictures tomorrow. Ian
bluffman is offline Find More Posts by bluffman
Old Dec 08, 2012, 12:21 AM
tpczx6 is offline
Find More Posts by tpczx6
tpczx6
tpczx6's Avatar
USA, CA, Fremont
Joined Oct 2005
I have a NYX with Fr-sky and i put my exits right at the end of the hatch about mid way down. I have had the NYX at spec hight whendoing some F3B with no issuse. Hope this helps
tpczx6 is offline Find More Posts by tpczx6
Old Dec 08, 2012, 11:11 AM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Mine also usually end up midsection or towards the rear of the canopy and about 20-30mm down from the opening and out on a 45*. Attached is a good article on the subject.
Vic
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Dec 08, 2012, 11:55 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Whats a NXY?
OK, so just bustin Ian's chops on the typo....
Ian-
On carbon/kevlar+carbon fuses, use the 9300 or 9310 Rx and run the two ant's from the main Rx out the sides at 45 degree swept back angles, on the horizontal plain, ahead of the wing.
The satellite can go aft of the wing somewhere, poking straight out.
Some guys have mounted satellites in the vertical fin, extending the connecting wire to the main Rx as needed, and that works well also.
R,
Target
target is offline Find More Posts by target
Old Dec 08, 2012, 08:21 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
I thank you guys for your input on my NXY, I should always wear my glasses. NYX
For Sale Nxy Furio F3F V-tail Eddie.C Aircraft - Sailplanes (FS/W) 8 Aug 17, 2010 05:28 PM
