Pusher props are fairly rare, so the standard is to reverse the motor. A sensorless brushless motor just requires 2 wires to be swapped and you can fly.
A brushed motor or a sensored brushless will require the timing to be changed by rotating the endbell (the brush holder). Some can motors (like the Graupner Speed 400 7.2V) are neutrally timed and can be used in either direction. Depends on your motor. I suggest you check the FAQ for information about timing. The FAQ is on the links at the bottom of the page. http://www.ezonemag.com/pages/efaq.htm Rick. PS I see you got 2 answers at the same time. Helpful people here. |
| Thread Tools | |
| what is the fastest pusher type plane???? | rumme | Parkflyers | 3 | Mar 19, 2005 01:38 PM |
