Old Dec 23, 2012, 07:42 PM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by Throttlejunkie View Post
Hey Guru, are you running the gyro on 3s as well or a separate 2s.
Lol, you want more power than that Tenshock TJ?
chktm is offline Find More Posts by chktm
Old Dec 23, 2012, 08:22 PM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
No mate the tenshock has plenty & i still have not turned the power up in the esc yet, just curious if he was running 3s on the gyro as it would be spinning a lot faster.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Dec 23, 2012, 08:31 PM
chktm is offline
Joined Jul 2012
Yea even more stability although getting it to turn well may be an issue. If you want more after you turn it up just gear up a little more. Doesn't sweat pulling a 13 anywhere and I'm sure it would pull more easily for an insane speed run lol.
Old Dec 23, 2012, 08:54 PM
Sydney, Australia
Joined Mar 2010
It's not for the vmx mate that is perfect the way it is the other one i think needs to spin faster.
I have just about lost hope of my pinions turning up i sent them an email i have to wait until it has been 45 day's before i can lodge a lost parcel claim.
Old Dec 24, 2012, 12:15 AM
chktm is offline
Joined Jul 2012
Oh, fair enough. Bugger about the pinions .
Old Dec 24, 2012, 07:55 PM
chktm is offline
Joined Jul 2012
For those chasing more grip and consistent handling on the slippery dry hardpacked broken up dirt and also better bad jump landings this is the insert I use. The bike can be pushed harder into the corners and also has more grip coming through and out of them meaning you can really put the power down well even when its super slippery.
It's made of the foam from ideally a Losi ( this one is proline and does work although softer and shorter lifespan ) stadium truck cut with scissors both ways and glued with contact adhesive.
http://www.rcgroups.com/forums/newat...anageattach&p=
Old Dec 24, 2012, 07:58 PM
chktm is offline
Joined Jul 2012
This is installed into a slightly cut ( also with scissors ) and super glued front tyre which is mounted onto the plastic ring.
Old Dec 24, 2012, 08:00 PM
chktm is offline
Joined Jul 2012
Looking like this. This forms the inner tube, I then work the tyre over the top using the same technique as a big bike tyre being fitted. Some baby powder helps the tyre slip into place. The foam in this insert will last me 4 or 5 tyres worth and the cut down front will last forever virtually. This is my favourite insert for rough and dry slick conditions.
Old Dec 24, 2012, 08:04 PM
chktm is offline
Joined Jul 2012
Everything has to be made as well as possible and cut straight and evenly. Also glued evenly. Be as careful as you can to make it as straight and wobble free as possible.
I have one made up with a 1/5 HPI front insert cut to fit but have yet to try it. This insert is quite a bit harder and also taller and more rounded than the 1/10th foams so may be more suited to a more grippy or loamy surface.
Old Dec 24, 2012, 08:07 PM
chktm is offline
Joined Jul 2012
The bike in this vid is using the insert in the pics.
Atomik MM450 berm railing wheelies slow mo (4 min 38 sec)
Old Dec 24, 2012, 08:54 PM
chktm is offline
Joined Jul 2012
By the way don't use a new tyre. Wait until you replace the front and use the old worn one. I have tried a SM front and it worked but not as well.
Old Dec 26, 2012, 04:45 PM
chktm is offline
Joined Jul 2012
Here's a Losi foam I made up today. This one came out of a used tyre but will still work well for quite some time.
Old Dec 26, 2012, 04:55 PM
chktm is offline
Joined Jul 2012
This one has done its job and lasted a long time. Occasionally they need re gluing, you can check this when changing tyres over. This one has come unglued at one end and almost at the other, once they are to this point there isn't much good gluing again. The foam is quite deteriorated but not like the way the std foam falls apart.
Old Jan 01, 2013, 09:08 PM
chktm is offline
Joined Jul 2012
Here's a couple of vids of the MM from someone who just got one. The first one has the std optional alloy shock. The second vid has a Hot Bodies big bore set up as described here.
http://www.rcgroups.com/forums/showt...1784958&page=3
See what you guys think.
First std shock
MVI 8182 (5 min 22 sec)
Second big bore shock
MM450 Run 3 (6 min 10 sec)
Old Jan 02, 2013, 05:06 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Hey its 2013 and trying to get off my lazy arse and get some motivation going. I was able to update the big bore shock treatment just as you wrote it Chris. Thanks. http://www.rcdirtbikeaction.com/303/...-vmx450-mm450/
While Im here, Chris, do you mind if I put up your steps for the front brake?
JohnnyMc is offline Find More Posts by JohnnyMc
Discussion Atomik Metal Mulisha MM450 with E-Gyro Chris Nicastro Motorcycles 6327 Jun 24, 2016 06:48 PM
Sold Atomik metal mulisha vmx bikes for sale. Both new in box fgbasher Cars - Motorcycles (FS/W) 17 Jan 11, 2013 04:40 PM
Sold ALIGN TREX 700 Metal Tail Pitch Assembly / / Metal Tail Rotor Control Arm Set helifreak592 Aircraft - Electric - Helis (FS/W) 0 Apr 05, 2012 06:36 AM
Blade CP FAQ - and set-up tips - taken from all of the threads bstock Micro Helis 3 Jun 03, 2005 05:54 PM
New Flier Tips on set up of Wingo Chesie2 Beginner Training Area (Aircraft-Electric) 8 Sep 17, 2001 09:45 AM
