Old Dec 11, 2012, 10:19 AM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
On the vmx, inside where the steering stem sits, it comes right up to the inside of the frame so there is no space for the stem to move making those rubber grommets kind of pointless. I followed TopDave's advice long ago when he pointed this out and did some minor dremmeling to the frame and stem a little play for the grommets to be effective. I wonder if the mm450 frame changed to accomodate what Dave found?
JohnnyMc is offline Find More Posts by JohnnyMc
Old Dec 11, 2012, 01:22 PM
TopDave is online now
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Yeah Johnny, I was amazed that there was no comment from Chris N/Venom about that issue. Believe it or not, that was the first thing I checked when I opened my new MM450, lol. Since that mod I have tons of crashes and endo's on the VMX without breaking that part again! (not that it's not possible to break ) . They must have designed clearance there because my Deegan bike steering bracket does float on the grommets. I still like the idea of the third mounting screw too.
TopDave is online now Find More Posts by TopDave
Old Dec 11, 2012, 01:50 PM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
I had a feeling you would have checked it out haha. Its good to know the new bikes got your 'find' as part of the design now.
Old Dec 12, 2012, 07:09 AM
chktm is offline
Find More Posts by chktm
Australia, QLD, Burua
Joined Jul 2012
Here's a driving tip I have learnt with the MM.
On slippery dirt you need to change you style of driving to when the grip is available. It's more so the front end that you have to worry about losing than the rear as with the gyro that will never really happen. When exiting a slow corner instead of trying to stand the bike up by using opposite lock you need to keep the steering mainly straight ahead and use the throttle to stand the bike up. The problem is worse when there is like a chicane or a corner opposite to the last one quite soon as you tend to start to try and steer the bike into the next corner before its stood up fully. The trick is to wait until the bike is almost stood up and then back off for an instant you can even dab the brake and start your next turn and power on. Be smooth with the throttle and try not to lift the front until again almost stood up as if you put the front wheel down while leant over too much it will wash or cause some wobble as it try's to grip when it comes down at the least. The bike handles really well on the dry dusty dirt you just need to be smooth and have a little more patience with the bike.
chktm is offline Find More Posts by chktm
Old Dec 12, 2012, 08:04 PM
chktm is offline
Joined Jul 2012
The optional front brake makes a difference in handling by not only giving better braking but it also settles the rear end under braking allowing better control entering corners. I use the standard front brake caliper and disk, only replacing the pads with 1/8 buggy pads when they wear out. You can use the std brake cable until it breaks then I upgrade to push bike cable using an antenna from a buggy as an outer cable. Remove the adjusters from the caliper and the servo end and drill the hole in the red caliper brake actuator slightly bigger. For stoppers I use throttle brake linkage ones again from a buggy. I use the hole closest to the servo centre for more leverage and more power in the brakes. Plus its easier on the servo. I use the std brake servo and dail in as much or as little brake as I want with the brake mix percentage. If you happen to bend the disk remove and sandwich between two thick flat pieces of fairly hard wood give it a few clouts firmly with a large hammer until the disk looks good.
To set up the brakes leave the servo horn off to start. Set up the cable as per instructions. Turn on the radio and bike ( disconnect one gyro ESC wire to stop the gyro spinning up ) turn on the aux channel switch on top of the radio. Go into the brake mix ( no 11 in the menu ) and turn it on and set this to 110 to start. Go into the EPA settings and set channel 3 high end to 120% and the low end to 0%. Fit the servo horn getting rid of as much free play in the cable as possible without causing any binding of the brake. Spin the front wheel and then adjust up the low end until the pads just rub and back off until the wheel moves free. Use this low end EPA adjustment to keep the pads close to the disk. As they wear adjust this until you run out of adjustment then return the setting to zero and either adjust the cable or the servo horn position. Check and make sure the pads are still ok. Final setting of brake strength is done with the brake mix %. The higher the % the greater the strenght of front brake. Try not to use over 110% with the std servo. Just a tip for slippery dirt you don't want either the front or the rear brakes to completely lock as this only causes the bike to get out of control. I also back the rear brake off slightly to reduce locking on the slippery stuff. I set my EPA at 95%.
http://www.rcgroups.com/forums/newat...ach&p=23513281
Old Dec 13, 2012, 04:09 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Nice! I'll be hitting this thread up Xmas day!
Teamsherman is offline Find More Posts by Teamsherman
Old Dec 13, 2012, 04:27 AM
chktm is offline
Joined Jul 2012
No worries dude. There'll be some bike action this Christmas, I know of a few more too .
Old Dec 13, 2012, 05:04 AM
Throttlejunkie is offline
Find More Posts by Throttlejunkie
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Do you guy's dremel clearance & run the third bolt or still just the 2 bolts & have they changed the design on the stem on the mm to 3 bolts as my mates mm only has 2.
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Dec 13, 2012, 06:43 AM
chktm is offline
Joined Jul 2012
I only run two as per std. Have done some testing but on my rough track with three and didn't really like it. Any bad bumps the front took instead of isolating it more to the front the shake it seemed to transfer it more through the bike. Didn't really try it anywhere else. Will maybe do some more testing elsewhere.
Old Dec 13, 2012, 09:32 AM
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Here's the original post:
http://www.rcgroups.com/forums/showt...0#post17349369
Old Dec 13, 2012, 12:40 PM
Rellik is offline
Find More Posts by Rellik
Joined Mar 2012
Good thing to add is a switch to the E-gyro esc so it can be controlled (turned on/off) and also put plastic dip on the tiny E-gyro wires coming out of the wheel to protect them from chafing and shorting out on each other. zip tie them so they don't contact the rear wheel .
Can't wait for the step by step big bore shock write up
Rellik is offline Find More Posts by Rellik
Old Dec 13, 2012, 03:41 PM
chktm is offline
Joined Jul 2012
Thanks for the tips Rellik, I'll pull my finger out soon and get it done lol.
Old Dec 13, 2012, 09:26 PM
Rellik is offline
Joined Mar 2012
no problem, im sure you have a life out side of this forum and the rc world lol. i wasnt trying to hint or push that comment towards you haha.
Old Dec 13, 2012, 09:33 PM
chktm is offline
Joined Jul 2012
Yea I try to join the real world at times lol. I know you weren't pushing but others want it too so I'll do my best to get it done in the next week or two probably.
Old Dec 15, 2012, 05:59 AM
Rellik is offline
Joined Mar 2012
merry xmas from you to the rc moto world
Discussion Atomik Metal Mulisha MM450 with E-Gyro Chris Nicastro Motorcycles 6346 Jul 31, 2016 08:43 PM
Sold Atomik metal mulisha vmx bikes for sale. Both new in box fgbasher Cars - Motorcycles (FS/W) 17 Jan 11, 2013 04:40 PM
Sold ALIGN TREX 700 Metal Tail Pitch Assembly / / Metal Tail Rotor Control Arm Set helifreak592 Aircraft - Electric - Helis (FS/W) 0 Apr 05, 2012 06:36 AM
Blade CP FAQ - and set-up tips - taken from all of the threads bstock Micro Helis 3 Jun 03, 2005 05:54 PM
New Flier Tips on set up of Wingo Chesie2 Beginner Training Area (Aircraft-Electric) 8 Sep 17, 2001 09:45 AM
