Old Dec 07, 2012, 05:43 PM
f111 is offline
Find More Posts by f111
Joined Jul 2011
ESC fow/rev code
Hey has anyone ever seen home made code for the atmel controlled unidirectional BLDC ESC's that allows fow/rev ? something like 1mS =full reverse, 1.4mS-1.6mS=stop, 2mS=full foward. no brake delays or anything like that. the reason i ask is because unidirectional esc's cost way less than bi directional ones. even though the fets are assembled in the same manner.
f111 is offline Find More Posts by f111
Old Dec 13, 2012, 03:02 PM
HoverX is offline
Find More Posts by HoverX
HoverX's Avatar
France, Pays de la Loire, Pornic
Joined Mar 2008
This would be a dream come true.
There seems to be a few people able to mess with esc code. Unfortunately, most of them are quadrotor addicts, not ROVS.
HoverX is offline Find More Posts by HoverX
Old Dec 21, 2012, 07:18 AM
hargard is offline
Find More Posts by hargard
R.O.V. Man
hargard's Avatar
Devon UK
Joined Jan 2006
Hi.
You cannot use standard ESC's (Forward only) and program them for multi direction.
They have a compleatley different electronicks inside.
What language are you using or thinking of using ?? I.E. "C++" or "Arduiono" Basic.
There are ways of making your own.##'###
Better of buying some from E-Bay Item number :- 230837016803 320 Amp For Brushed motors or Item Number :- 180582675073 30 Amp for Brushless motors.
Regards Hargard.
hargard is offline Find More Posts by hargard
Old Jan 03, 2013, 08:31 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Originally Posted by hargard View Post
Hi.
Regards Hargard.
Brushless escs are the same electronically for forward and reverse, a brushless esc only changes the order of the motor drive pulses to change direction.
There are plenty of cheap escs with reverse now, check out the Hobbyking car and boat escs, 30 amp for $15, a bit more than a plane esc of equivalent rating but for $15 its not worth the hassle.
http://www.hobbyking.com/hobbyking/s...w_Reverse.html
This one works exactly as you want (with no brake) straight out of the box
Nick
nick_75au is online now Find More Posts by nick_75au
Old Nov 11, 2013, 06:46 AM
Aeroeng92 is offline
Find More Posts by Aeroeng92
Joined Sep 2012
I've had good success using the HobbyKing Blue Series brushless controllers (various amp sizes) and re-flashing them with the SimonK firmware. This firmware has specific compile options that allow a brushless esc to be set up with proportional foreword and reverse control, and no braking if so desired. The following link is what I primarily followed to do this.
http://www.rchacker.com/diy/simonk-e...mware-flashing
Aeroeng92 is offline Find More Posts by Aeroeng92
Sold BNF Rusty's Rev-8, OP coptercontrol, Tmotors, Nextlevel Esc's, CM-1 LG and extras kicekilla Aircraft - Electric - Multirotor (FS/W) 0 Sep 05, 2012 11:46 PM
Discussion Low rev big prop, high rev small prop? -james- Electric Sailplanes 7 Apr 11, 2012 09:16 PM
Discussion Buddy Code for Turnigy Plush 30amp ESCs artvscommerce Multirotor Talk 2 Mar 16, 2012 11:25 PM
Discussion Is it possiblke to re-code an esc for fwd/rev operation? rjwims DIY Electronics 7 Aug 19, 2010 09:12 AM
Bipe plan or kit fow GWS-A motor JamesD Parkflyers 2 Mar 18, 2002 12:20 PM
