Old Dec 18, 2012, 12:02 PM
doxilia is online now
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Originally Posted by lfinney54 View Post
the 10MM carbs will work fine without a pump, but using a vp 30 is ok too, the idle needles have gone through several iterations. the long stroke 3+2 engines with Macs quiet pipe will turn a apc north of 17k , I setup one for a friend and he was sceptical of using a larger prop, we used a 12x9 apc in the end, and it was horrifically fast...so pattern is flown at half throttle and it met sound checks easily. I use 8-32 pressure taps on the 60 size motors
Lorin,
For tank position flexibility, I've been interested in running the 10 mm carb with a Perry backplate pump. I'm not sure whether these are more VP20 like or VP30 like but I've assumed it's a direct pressure feed VP30 conveniently located on the backplate - OS style.
That said, it sounds like there is no "fuel issue" combining the two. I question whether the carbs might "spit" fuel if overdriven, so to speak. Likewise with the OPS carbs and RE red Ursus and gold Super engines. OPS has both 8 (or 8.5) and 9 mm carbs.
Fact is, I intend to use these engines on a Deception (Rossi) and Arrow (OPS), respectively.
David
PS By the way, you're not saying you can get a 3+2 to turn an APC 12x9 at over 17K are you? I think Rossi suggests they can tach a 3 port two piece case old style RE at over 17K on an 11x7.5.
doxilia is online now Find More Posts by doxilia
Old Dec 20, 2012, 09:49 PM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Lorin,
I sent you a PM. If you have the time.
Thanks, David
Old Dec 21, 2012, 10:20 PM
computermonkey is offline
Find More Posts by computermonkey
computermonkey's Avatar
United States, OK, Tulsa
Joined Jan 2010
Hello, I've been following this thread, pretty interesting. I have a Rossi 60 FIRE black head 3+2 one piece case engine and I am wondering what prop to use on it. Are people calling this engine a long stroke?
I also have a Rossi 60 silver head side exhaust engine, is this a short stroke?
computermonkey is offline Find More Posts by computermonkey
Old Dec 22, 2012, 08:50 AM
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Pictures?
Old Mar 05, 2013, 09:53 PM
Joined Jan 2010
Better late then never. Sorry for not posting these sooner.
One is a silver head, one is a black head side exhaust and one is a black head rear exhaust. All have one piece crankcases.
I think the silver head is a short stroke. The back plate is smaller in diameter then the black heads.
The black head rear exhaust manual says it is a 3+2.
I would appreciate any information/performance that people with these engine have.
Thank you.
Old Mar 05, 2013, 11:48 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas, AMA 42520
Pitstop000's Avatar
United States, CT, Norwalk
Joined Aug 2008
Thatís fine, I have been promising to post some info for monthís on another subject.
I've been watching with some interest myself on this one.
Pitstop000 is offline Find More Posts by Pitstop000
Old Mar 15, 2013, 11:50 PM
Kevin2035 is offline
Find More Posts by Kevin2035
Kevin S. Gribben
Kevin2035's Avatar
Joined Mar 2011
I have a couple of those 2 piece case RE...... they were the staple back in the day. we ran em 10 3/4 x 7 1/2
Oh memories....... they were not really sensitive to nitro, thats one memory I have.
Kevin2035 is offline Find More Posts by Kevin2035
Sold New Rossi 61 ABC 3+2 Port Rear Exhaust Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 21, 2013 09:06 AM
Sold Rossi 61 rear exhaust header pipe #61/24f new in bag hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 30, 2012 02:49 PM
Sold ROSSI 61 FI R/C Rear Exhaust New in the Box hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 29, 2012 02:05 AM
Sold New ops 60 super spa rear exhaust r/c pattern model airplane engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 02, 2012 08:40 PM
Sold Tuned pipe system for OPS .60 rear exhaust tnt123 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 13, 2012 07:08 PM
