Old Dec 07, 2012, 04:32 PM
Steve Parsole is offline
Find More Posts by Steve Parsole
Joined Jun 2010
Looking for Rossi 61 or OPS 60 Rear Exhaust
Hi Guys,
I was just give a beautiful EU1A that was set up for a Rossi 61 Rear exhaust. I need an
engine, anyone have one they would part with? I think this is called a FIRE (front intake, rear exhaust)
Steve
Steve Parsole is offline Find More Posts by Steve Parsole
Old Dec 07, 2012, 06:43 PM
exf3bguy is offline
Find More Posts by exf3bguy
exf3bguy's Avatar
United States, CA, Sacramento
Joined Oct 2011
currently on Ebay This is one of the most powerful Rossi made. I have one, slightly modded turning an APC 11X11 at 13K on the ground.
http://www.ebay.com/itm/ROSSI-61-FRO...item1e751b5df7
exf3bguy is offline Find More Posts by exf3bguy
Old Dec 07, 2012, 07:35 PM
Ed S. is offline
Find More Posts by Ed S.
Joined Jun 2012
Hey Steve,
He is right, that one up there on Ebay was one of Rossi's best. I have one of those in a Hipo Tipo and it pulls that monster straight up. Should be great in the EU1A. Looks like a steal right now, but it still has a day to go.
Eiddie
Ed S. is offline Find More Posts by Ed S.
Old Dec 07, 2012, 10:28 PM
dhal22 is offline
Find More Posts by dhal22
United States, GA, Alpharetta
Joined Dec 2007
I have a rear exhaust OPS or 2. Let me post some photos.
David
dhal22 is offline Find More Posts by dhal22
Old Dec 08, 2012, 01:23 AM
Huang is offline
Find More Posts by Huang
United States, CA, SF
Joined Sep 2001
Can someone in the know explain which Rossis are short stroke and which are long stroke? I think all the 61 rear exhausts were short strokes, but some of the side exhausts .60s were long strokes? How can you tell?
Thanks!
Huang is offline Find More Posts by Huang
Old Dec 08, 2012, 07:46 AM
doxilia is offline
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Matt,
One thing's certain. If the engine was made ~1990 or earlier, it is a SS. I don't think the Italians made LS engines until the 90's; maybe even later.
I think there are LS RE Axe Rossi's though built this century.
David
doxilia is offline Find More Posts by doxilia
Old Dec 08, 2012, 11:45 PM
edh13 is offline
Find More Posts by edh13
edh13's Avatar
United States, AZ, Mesa
Joined May 2003
Here's a new 60 FIRE now in stock for us classic pattern fans...
http://www.planethobby.com/product.p...&cat=29&page=1
This engine pulls this 10.3 pounds of screaming bondo like a Japanese bullet train. In comparison the Tipo next to it is 8 pounds powered by a pumped and piped ST 60x...
Well... there is no comparison.
edh13 is offline Find More Posts by edh13
Old Dec 09, 2012, 08:49 PM
doxilia is offline
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Thanks!
Matt,
By chance I've exchanged some emails with an ex-Rossi USA employee. I was told that Rossi made a LS RE engine in 1993 (I was on target) and was distinguished by a light gray head.
They also made a "square" engine which was denoted a SS but apparently didn't perform and they continued with the typical 24/22 geometry shorties.
There were also 3 port and 3+2 (boosted) port versions. The latter tached lower on the ground but unloaded better in the air. 14.5K on 20% and an 11x9, extra head shim - not bad!
I have "new and old" production SE and RE Rossi's and would like to find the full specs and info on each of them.
David
Old Dec 09, 2012, 08:54 PM
doxilia is offline
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Originally Posted by Steve Parsole View Post
Hi Guys,
Steve
Steve,
For the EU-1A, you might want to consider going with a bored out Rossi or Webra. They made 81's and 90's in 61 cases. A new Rossi 81 was on auction recently for a couple of hundred - a reasonable price.
It might just give you that extra oomph on the large bird. Others have used Jett 90's and 100's as well.
David
Old Dec 09, 2012, 08:56 PM
le fou is offline
Find More Posts by le fou
United States, OH, Cuyahoga Falls
Joined Apr 2006
Hi everybody,
What is the difference between long stroke and short stroke. I have a YS 60 long stroke that I plan to put in my atlanta. Also, where can I find the header for it and a pipe?
Le fou
le fou is offline Find More Posts by le fou
Old Dec 09, 2012, 09:18 PM
doxilia is offline
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
Le fou,
Short stroke, square and long stroke denote engine displacement geometry. If the bore is greater than the stroke, it is considered short stroke, the converse would be a long stroke. Can you guess what a square engine is? Right, bore = stroke.
David
Old Dec 09, 2012, 09:20 PM
le fou is offline
Joined Apr 2006
Thanks!
Old Dec 09, 2012, 09:31 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas, AMA 42520
Pitstop000's Avatar
United States, CT, Norwalk
Joined Aug 2008
Hey Le Fou, Here’s some more info for you.
When referring to the YS engines.
Short stroke engines think small props with high revs, Long stoke engines larger props less revs.
You will need a MACS left hook header part # 3817 for the YS
and the 10cc muffled pipe part # 1260 for your install in the ATLANTA.
Pitstop000 is offline Find More Posts by Pitstop000
Old Dec 09, 2012, 09:54 PM
Pitstop000's Avatar
Joined Aug 2008
One other thing Prop it with an APC 11/10 -11 and keep the rpm around 12000 or so if it’s just a long stroke 61 and not the AR.
Old Dec 10, 2012, 08:46 PM
le fou is offline
Joined Apr 2006
Thanks!
Sold New Rossi 61 ABC 3+2 Port Rear Exhaust Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 21, 2013 09:06 AM
Sold Rossi 61 rear exhaust header pipe #61/24f new in bag hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 30, 2012 02:49 PM
Sold ROSSI 61 FI R/C Rear Exhaust New in the Box hobbyfun100 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 29, 2012 02:05 AM
Sold New ops 60 super spa rear exhaust r/c pattern model airplane engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 02, 2012 08:40 PM
Sold Tuned pipe system for OPS .60 rear exhaust tnt123 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 13, 2012 07:08 PM
