Old Dec 07, 2012, 12:09 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
FAQ
So you need help with setting up your boat?
I figure I'ld start a thread on this since this is the most frequently asked question.
You want to know what materials and gear you should use to build and set your boat up with.
In order to receive effective help, you must have the following information.
Length:
Hull Type: (mono/vee, tunnel/cat, hydro, rigger, airboat, heavier types)
Application: (race, easy build)
Running Environment: (pool, lake/pond, ocean)
Length:
- How big of a boat are you interested in building?
- How long is your hull?
Hull Type:
- The hull type can provide others with some additional basic information such as width and approximate driveline setup.
Application:
- Are you looking for something high performance to race with? Remember that the faster you strive for, the more likely it is for things to go wrong.
- Are you looking for something simple that you can just toss in a pond during your lunch break and have a little fun? Reliability is one of the biggest headaches I've noted with micro boats.
- Where you intend to run will play a big role on the way your boat is designed and built. If you are running on a murky lake, I don't think you would want to lose anything. However, you don't have to worry about waves.
- If you are running in pool, you can always retrieve a damaged or missing boat/part. A pool is the best area for testing. A pool also restricts the size of your boat.
- If the ocean is for you, you're going to want to have a very sturdy and built boat. Trust me, I lived in it.
So what all do you need to build a functional boat?
1) Hull
2) Rudder Hardware
- rudder blade
- mounting bracket
- control linkage
3) Drive Hardware
- drive shaft
- coupler
- stuffing tube/box
4) Prop
5) Motor
6) ESC
7) Servo
8) Receiver
9) Battery
boredom.is.me is offline Find More Posts by boredom.is.me
Joined Nov 2007
reserved
Old Dec 07, 2012, 12:16 PM
Joined Nov 2007
eh, why not...
Old Dec 07, 2012, 10:26 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
boredom.is.me:
Looking forward to this thread. I will be building a 14 inch Lil Salty tug out of 3mm foam. I will use a Johnson 250 brushed motor and a 10 amp brushed esc w/reverse. That's all the info I have right now as I'm still considering various other drive train parts. I am a motorized boat new bee.
Regards;
Dave-
foamdave is offline Find More Posts by foamdave
Old Dec 15, 2012, 10:43 AM
jmolwitz is offline
Find More Posts by jmolwitz
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
You will need a gearbox 5 or 6 to 1 for that salty also only run on one cell lipo . I think that motor is near 5ooo kv
jmolwitz is offline Find More Posts by jmolwitz
Old Dec 15, 2012, 01:08 PM
Joined Nov 2007
If it's a tug, then a little bit of extra weight wouldn't kill you. If you have some 5s NiMh, those would work great. That's a pretty big motor too for such an application. If you can't gear it, just make sure to at least have a low pitched prop.
Old Dec 15, 2012, 05:28 PM
foamdave is offline
skumgummi dave
Gresham, OR.
Joined Mar 2004
Thanks for the tips guys
Old Feb 07, 2013, 03:07 PM
angelicgundam is offline
Find More Posts by angelicgundam
United States, TX
Joined Jul 2010
my plan is to build a micro-rio. im aiming to pretty much just half the dimensions of the mini rio.
hull type is a mono/vee
hull length 7.15"
electonics:
losi micro crawler brushed esc/rx combo
stock motor(might switch to bb2)
some cheap servo
2s lipo
running gear:
dual rudders (3d printed on my up!)
links music wire or similar
wanting to dosurface drive just like the origional but just dont know what to do for a prop and prop coupler. any ideas?
also hull will be made with a vacumm form and sandwiched together just like the origional. also might go for brushless if needed but i ithink the brushed will be better for size and wieght. also not trying to race it just wont somethingni can keep in my backpack to run in the 1 1/2 ft deep fountains at school.
angelicgundam is offline Find More Posts by angelicgundam
Old Feb 07, 2013, 10:37 PM
Joined Nov 2007
Sounds sweet, but why dual rudders? As far as I know, no one is having steering issues with single rudders.
Some thick walled silicone tubing will work for a coupler. As for the prop, if you can, try and find some Kyosho Mini-Z props. They are stupid rare, but after days of searching, you might find a set. (An alternative would be for me to scale my props up from 12mm to about 16mm, but that would require further testing.)
Old Feb 09, 2013, 06:12 PM
hoffy1980 is offline
Find More Posts by hoffy1980
Hoffy1980
United States, IL, Maroa
Joined Jan 2013
I dont know if you will help but I need some help with a 21" deep vee.
I know it is not a micro. I would only run on pond or lake . Just for fun.I am guessing about 2s lipos not sure of anything else. I will be getting a 3 channel radio from hobby king. I am also wondering about a linberg ptboat it has a dumas 6 volt motor in it. everything else has been removed, 1 drive shaft, prop is probly to small, it was one from the dual setup. Thanks for any input.
hoffy1980 is offline Find More Posts by hoffy1980
Old Oct 25, 2014, 03:12 PM
daveymm is offline
Find More Posts by daveymm
Joined Aug 2012
Help with 1:350 scale Borodino
I have never built an RC ship before, so maybe I have bit off more than I can chew, but here it goes ....
Boat size/length/etc:
1:350 scale Russian battleship "Borodino"
34 cm bow to stern
max width 6 cm midship
max draft to waterline 2.3 cm
Hull type: Flat bottom hull
Application: Leisurely cruising in pool or on ponds. No need to high-speed, but realistic battleship motion
Running environment: Pool or decorative ponds around my housing development.
daveymm is offline Find More Posts by daveymm
Discussion Needing help setting up Nano with DX7S kushal_22 Beginner Training Area (Heli-Electric) 31 Nov 01, 2012 12:26 AM
Discussion Need help setting up ER9-X with Naza tgreening Multirotor Talk 34 May 15, 2012 10:58 AM
Discussion Need help setting up Tricopter with Spektrum DX7s with gyros Easyrider717 Multirotor Talk 35 Apr 19, 2012 11:50 AM
Discussion Need help setting up stryker with dx6i. John S. Electric Plane Talk 2 Mar 28, 2012 03:35 AM
Discussion Need help setting up stryker with dx6i. John S. Beginner Training Area (Aircraft-Electric) 6 Mar 27, 2012 07:12 PM
