Old Dec 07, 2012, 10:30 AM
Bob6831 is offline
Find More Posts by Bob6831
United States, FL, Fernandina Beach
Joined Sep 2012
How Perfect does Perfect Have to Be?
I have a Champ that I just glued the tail feathers back on ....... and I notice that the Vertical Stabilizer is not exactly 90 degrees from the Horizontal Stabilizer.
My question is: how exact does this have to be, and if it is say 5-10 degrees off from 90 degrees, what will be the flight characteristics?
Bob6831 is offline Find More Posts by Bob6831
Old Dec 07, 2012, 10:36 AM
alibongo is offline
Find More Posts by alibongo
alibongo's Avatar
United Kingdom, England, Dorset
Joined Apr 2010
As long as it is not at an angle laterally (ie acting like a rudder) it will have NO effect.I have flown planes with an end wing panel missing, just by moving the wing further over the fuselage (in the days when I flew ic powered gliders with wings held on by rubber bands).It is the non-fliers who obsess about everything being perfectly square.Even they decide to fly with a non-perfect model after they have knocked their planes about a bit.
alibongo is offline Find More Posts by alibongo
Old Dec 07, 2012, 10:40 AM
Lost_Dawg is offline
Find More Posts by Lost_Dawg
S.E. Michigan
Joined Feb 2006
I agree with the above poster for the most part. It might not look as good as you'd like but probably won't affect flight characteristics all that much. Remember your dissappointment and try to get a better repair better next time. Go out and fly it!
Lost_Dawg is offline Find More Posts by Lost_Dawg
Old Dec 07, 2012, 12:39 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
You can trim out any slight error.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 07, 2012, 12:55 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
While what people are saying is true - small errors in alignment don't affect a plane like the Champ very much - I have seen cases where the rudder was bent in such a way that it didn't move correctly, put undue stress on the servo, and made the plane hard to fly because the rudder would 'snap' from one side to the other. As long as your rudder is moving smoothly, it should be fine, but be sure to check for that.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 07, 2012, 02:52 PM
Edmond Y is offline
Find More Posts by Edmond Y
Canada, BC, Port Coquitlam
Joined Nov 2008
if 5-10 degreed, that is too much, or you will find the plane will lean one side.
Edmond
Edmond Y is offline Find More Posts by Edmond Y
Old Dec 07, 2012, 03:48 PM
alibongo is offline
alibongo's Avatar
Joined Apr 2010
Edmond
Why would the plane lean to one side?
Old Dec 07, 2012, 08:05 PM
Edmond Y is offline
Joined Nov 2008
I had the same problem with the op, I fix the tail without have it true at a right angle, the plane keep move into the side that the stab leaned, it is not the rudder problem but surely I can tell because I did some not good enough.
Edmond
Old Dec 08, 2012, 02:50 AM
alibongo is offline
alibongo's Avatar
Joined Apr 2010
Edmond
From wikipaedia:
"The vertical stabilizers, vertical stabilisers, or fins, of aircraft, missiles or bombs are typically found on the aft end of the fuselage or body, and are intended to reduce aerodynamic side slip and provide direction stability. It is analogous to a skeg on boats and ships.
On aircraft, vertical stabilizers generally point upwards. These are also known as the vertical tail, and are part of an aircraft's empennage. The trailing end of the stabilizer is typically movable, and called the rudder; this allows the aircraft pilot to control yaw...
A V-tail has no distinct vertical or horizontal stabilizers. Rather, they are merged into control surfaces known as ruddervators which control both pitch and yaw. The arrangement looks like the letter V, and is also known as a butterfly tail. The Beechcraft Bonanza Model 35 uses this configuration, as does the F-117 Nighthawk, and many of Richard Schreder's HP series of homebuilt gliders."
The fin does not have to be at 90 degrees to provide stability and pitch control.I am sure an off-set fin would not cause noticeable control problems in a model, provided it is still vertical enough to act as a stabilizer, and the rudder moves freely.I am not advocating our putting planes together in a slap-dash way, but suggesting it is possible to worry too much about perfection.
Old Dec 08, 2012, 11:55 AM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The main effect for flying with a tilted vertical stabilizer is that there will be some pitch coupling with rudder input. At the extreme, with the vertical stab tilted 90 degrees, it would then be a horizontal stab and the rudder would become the elevator. The pitch coupling from one or two degrees of tilt would not even be noticeable in most RC planes. And since most RC flyers seldom, if ever, use the rudder while flying it really would have no effect at all.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Dec 09, 2012, 01:29 PM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Larry
True, except that the OP will have to use rudder since the Champ is a 3ch plane...
Withe the vertical stab 5-10 deg. off vertical from the horizontal stab, the plane will have a wider turning circle to one side (and keep the altitude a tad better while turning) and a narrower turning circle loosing altitude a bit faster in the other direction - the effects of the pitch coupling mentioned by Lnagel...
How I know? From countless hours of flying Champs in various states of repair
KaiWE is offline Find More Posts by KaiWE
Old Dec 09, 2012, 02:23 PM
alibongo is offline
alibongo's Avatar
Joined Apr 2010
Even at 10 degrees the change should not be noticeable - it is a model with a 22 inch wingspan, not a fast jet!
Old Dec 09, 2012, 05:58 PM
Edmond Y is offline
Joined Nov 2008
You better know what you are talking about, try use a degree measure to see how large is ten degree and make your plane the same way and go fly and see how it flies, we are seeking true informations to learn with. As the other member said, one or two degree may not affect much but certainly not ten degree.
Edmond
Old Dec 09, 2012, 10:20 PM
alibongo is offline
alibongo's Avatar
Joined Apr 2010
I agree we are looking for accurate information- I shall indeed test this out in the next few days and report back!Look at this tailplane, flew just fine.I shall glue it on straight and see if there is any noticeable difference:
Discussion RC flying at Peaceful Valley does not have to only be at the NEAT FAIR FPVJOCKEY 2012 NEAT Fair 1 Sep 19, 2012 09:40 PM
Discussion I guess we'll see how well the Times does to try and be more unbiased... logan5 Life, The Universe, and Politics 4 Apr 23, 2012 04:27 PM
How Small Does A Heli Have To Be To Be Classed As A Micro Heli? littleport2003 Micro Helis 24 Nov 10, 2005 07:00 PM
How secure does the canopy have to be? treelander Beginner Training Area (Aircraft-Electric) 3 Oct 15, 2005 10:52 PM
